Slave Output Pin using counters?
I have an application where i'd like to parallel multiple output pins in hardware, if possible.
I was wondering whether there is a way to do this using the counters, but the nearest I can come up with would be a POS or NEG mode with feedback, where the B pin output would be inverted (!A, delayed 1 clock). I could then pass that inverted output through a second counter to achieve my goal, it would just use 2 counters instead of one.
I'm not using the counters for anything else this time. I don't mind the one or two clock delay. It might even be useful.
Anyone know of a way to achieve this using just a single counter?
One dedicated cog; 8 to 12 clock delay.
It just occurred to me perhaps it makes sense just to invert the software controlled "master" pin, in code, but not connect that to anything. Just have multiple slave hardware counter pins feeding off that one inverted master, inverting their outputs back to positive logic. That would allow up to 16 hardware slaves (spare counters permitting) at the expense on 1 wasted pin, an "overall win"
Thanks for the input
What's your overall objective here? Give us the big picture. And I'm not sure what you mean by "... the counters seem to recover from low voltage excursions somewhat automatically ..."
There are three applications that I've mucked around with in the past, and am now revisiting:-
1) Decreasing the drive resistance at low operating voltages (below 1.5 volts). The P and N fet resistances increase up above 100 ohms, and they are no longer symmetric.
2) Increasing the drive current at nominal 3v3, to drive very small motors (ie the Prop's pins are ganged 6 or 8 way to create a dual H-bridge).
3) Decreasing the drive resistance at higher voltages (3v6, perhaps nudging 4v). I've been experimenting with combining power and high speed data onto 2 wires - data/power and gnd, and rectifying to recover power at the other end. That's working nicely but the clear limit is the P fet resistance.
I'll get back to this thread later and drop in links to other posts scattered across the forums. I'll try your loop code, thanks for that.
One advantage is using obex objects as-is, just using any spare cog counters to reinforce the output. Some might feel safer with a hardware approach to mirrored pins. Apart from that it's just interesting to see how much can be done inside the chip, especially anything taking advantage of counters.
I need to revisit some experiments at very low voltage (Lawson's thread). My memory is that the counters keep toggling, even after the software driven outputs have given up. Whether that difference just applies to NCO mode, or POS/NEG mode with feedback, would be good to know.
