Are the 27ohm resistors and 47pF capacitors really really necessary?
william chan
I am referring to the components usually placed near the USB connectors of course.
I am running out of PCB space and are wondering if I can "get away with it" by excluding these 4 components.
Of course everyone knows the safest answer would be "They Are Required", but what is the not-so-safe answer?
I attached it after I modified for better visual.
The 47pf caps are there to filter out noise on the line, and the 27ohm resistors will help with signal bounce and impedance of trace/wire.
The 47pf caps and also the 10nF cap and ferrite-bead I would eliminate first.
445-10226-2-ND
Some EE at some point made a choice to put these in there for stability in some for or another .
I would not cut out any parts that are for things of time sensitive nature . Be it RF or digital at more then a 100 k Baud.
The resistor/capacitor form a low pass filter with a cut-off near 125MHz ... the exact reason for targeting 125MHz I am not exactly clear on except it's well below any PC or computer interference that might be likely to potentially cause problems.
You can even get a combination in a single package, eg
http://www.digikey.com/product-detail/en/EZA-DLU01AAJ/PDLU01CT-ND/385399
Loads of info on USB impedance and all its qwerks .
http://www.mouser.com/Passive-Components/EMI-RFI-Components/EMI-Filter-Beads-Chips-Arrays/_/N-bw7paZscv7?Keyword=USB&Ns=Pricing|0
If they have built-in 15K Ohm pull-down resistor, then it's for downstream (eg this chip goes in your computer) and is not what you're looking for.
You want a upstream without built-in 1.5K pull-up resistor , as the fdti (and all other) have this resistor in their IC's nowadays.
This one seems really good at 20cents with 0.5mm pin-spacing small but not to small.
NUF2042XV6T1G
http://www.mouser.com/ProductDetail/ON-Semiconductor/NUF2042XV6T1G/?qs=%2fha2pyFaduhA8A9SoVEwnuNfvXo%2fHfo948NpzPQqNL0%3d
I've worked with engineers in the past who have spent weeks or months testing and tracking down intermittent problems with electronics. Then the fix to those problems many times is an extra resistor here or an extra capacitor there. Then end of problem - the customer is happy with the "trouble free" gizmo.
They are happy many months and many years after the sale. When they purchase something again, they will go back to your company because your products are trouble free.
On the other hand, people who buy products which have intermittent problems each time you run the vacuum cleaner, turn on the blender, or a police officer nearby uses his radio, will return those products to the store and NEVER buy another product from your company again!
Having satisfied customers is a good thing for the future of a company!
The need for filtering might in some cases be due to quirks of how the board routed its wiring. And one engineer might prefer items such as ferrite beads, while another prefers coils. There are some real hazards with presuming you can download a schematic from the internet provided by the manufacturer and expecting to always get a perfect solution for a small run of boards for personal use.
