Announcing, 21st Century Robot "Jimmy"
http://21stcenturyrobot.com/
21st Century Robot Manifesto - A Robot Is: Imagined first. Easy to build. Completely open source. Fiercely social. Intentionally iterative. Filled with humanity and dreams. Thinking for her/him/itself.
Jimmy may not be all those things yet, but he definitely is exciting. For starters, he wasnt built in some secret lab at Intel HQ. Much of Jimmys construction took place at Trossen Robotics, a name well known to Hackaday. [Matt] and [Andrew] at Trossen describe all the details in their video down past the break.
This version of Jimmy is a research robot, which means hes not going to come cheap. Jimmy sports an Intel i5 NUC motherboard, 20 Dynamixel servos, a 5052 aluminum frame and a host of sensors. A 4S 14.8v 4000mAh LiPo battery will power Jimmy for 30 to 60 minutes between charges, so be sure to budget for a few spare packs. The most striking aspect of Jimmy is his 3D printed shell. The 21st Century Robot Project gave him large, friendly eyes and features, which will definitely help with the social aspect of their goals.
Jimmy is all about open source. He can run two flavors of Linux: Ubuntu 14.04 LTS or a custom version of Yocto Pokey. There is a lot to be said for running and developing on the same hardware. No specialized toolchains for cross compiling, no NFS shares to move binaries around. If you need to make a change, you can plug a monitor (or launch an VNC session) and do everything with Jimmys on-board computer. Jimmys software stack is based upon the DARwIn OP platform, and a ROS port is in the works.
Were excited about Jimmy, but at $16,000 USD, hes a bit outside our budget. Thankfully a smaller consumer version of Jimmy will soon be available for around 1/10th the cost.
I thought the same thing - not too smooth...
Ignoring the fact that they're using servos instead of even cheaper DC motors, its not really all that much more advanced than the RoboSapiens toys.
What do you think?
Lost an "s" in there to make it 'psychoandrotics,' but seriously, all I can think about with "psycho" in the name is Norman Bates. Thank Hitchcock for making "psycho" a loaded word.
