Permitted file types. — Parallax Forums
abecedarianabecedarian Posts: 312
edited 2014-05-29 21:42 in General Discussion
BRD and SCH files are permitted files. This post has both types of files uploaded but clicking on either of them results in the browser prompting to save "attachment.php". If I choose "Save As...", it puts "attachment.php" as the file name, but I can rename the file to what it's supposed to be and enclose the name in quotes and it saves the file properly. As well, I can save the file first then rename it and that works as well. This is IE11 on Win 8.1.
Is the problem on my end or a server MIME type error?
*edit - solved, sort of. It appears the site does not properly handle IE11 and tries to serve code intended to accommodate earlier IE browsers and their quirks modes.
    edited 2014-05-25 13:23
    Both files behave as expected using Chrome and Win7.
  • abecedarianabecedarian Posts: 312
    edited 2014-05-25 15:18
    Duane Degn wrote: »
    Thanks for the reply. I won't use Chrome but it's nice to know it's likely browser related.
    I changed IE11's compatibility settings and now it works as expected, so it's likely the site is using some IE conditionals that are not properly handling IE11.
  • NWCCTVNWCCTV Posts: 3,629
    I had this same issue after an IE 11 update. That plus several more. I am really getting annoyed at MS's "breaking" ten things to fix one.
