Help needed for choosing appropriate sensor
Hi guys,
Can anyone please suggest possible sensors which I can make use of to measure the dimensions of Playmobil plastic parts such as hats, caps and wigs the fastest way possible? I was thinking about vision cameras but I don't know if it is the optimal solution.
Thanks for your time.
Neville.
Neville.
Exactly what are you trying to do?
Thanks for your help
Thanks for your reply.
Without more details, including a drawing or photo, any attempts to offer advice is just speculation. You never stated what the tolerance is. Since you are already manually handling the hat to put it on a jig, maybe the jig itself is the crude measuring device alone. The hat moves down a graduating center section, when the hat no longer moves downwards, you look at marks on the jig to see where it stopped.
Hope this helps.
Each Lego piece must be manufactured to an exacting degree of precision. When two pieces are engaged they must fit firmly, yet be easily disassembled. The machines that make Lego bricks have tolerances as small as 2 micrometres.
http://www.itargetsensors.com/html_products/spring-load-LVDT-position-sensor-62.html
There are various precision QC and automation sensors on the market. In your case, you likely need to place the hat on a jib, then enter the hat opening from some angle with the sensor in one direction, this will require some type of linear actuator for an automatic process. Since you are not specifically mentioning the Propeller, I will suggest that the Propeller would be an easy platform to set this up with.
1. Move the actuator to the plastic surface
2. Read the sensor position for change.
3. On a change( contact ), stop the actuator, reverse the actuator until the sensor is back to zero,
4. Take a reading of the actuator position.
5. Repeat with separate actuator and sensor for the other side of the part.
This is pure speculation on my part as to the best way to do it.
http://www.amazon.com/Measurement-Tolerances-Manufacturing-Engineering-Processing/dp/0824701631
Would this firm's product line be of interest to you?
http://www.laserlinc.com/
cheers, David
