electromagnetic relays and electric magnets
I am trying to shop for 5V or 9V mechanical relays and set/ release electromagnets. Not to good on web searches, probably vocabulary weakness. I need shafts to move at the touch of a button, or when set high, spring return should work; A plunger in and out of a coil. Needed to latch the jib on a model crane, for automated setup, and to switch spindles from tilt to lift. I also need magnets to use as hooks, or like a salvage yard crane's magnet. Surely these are retail items, but I am having no luck with internet searches. Are there particular names I should be searching for to find these devices?
"relays" for mechanical relays
"solenoids" for the shaft/plunger electromagnet
"electromagnetic gripper" for the crane magnet
There are latching relays that were not mentioned above. But the reality is that you might find that the best days of electro-magnetic devices have come and gone. There were a lot used in early daisy-wheel printers or teletype equipment, but no longer. You may have to design and build your own electro-magnets if your needs are very specific. Plastic bobins are available and enamel wire comes in a wide range of sizes.
Here is a Hong Kong supplier for electro-magnets for lifting. http://www.ebay.com/itm/DC12V-OD60mm-154LB-70-0kg-Electric-Lifting-Magnet-Holding-Electromagnet-Solenoid-/150883909052?pt=LH_DefaultDomain_0&hash=item232161bdbc
Sizes go down to a small 2.4 watts at 6 volts. For 9volt and lower, try miniture solenoids.
