Have spin main wait until a newcog pasm is finished.
Hello,
I have some pasm code, one main routine and about 10 subroutines, all is working fine,
in my main pasm routine i exit with
/CODE
mov ctra, #0
cogid cog_label
cogstop cog_label
CODE/
in my spin code i have:
/CODE
pst.Start(115_200)
waitcnt((clkfreq*4) + cnt)
pst.Str(String(" ",pst#NL))
pst.Str(String("Starting Head firing",pst#NL))
cog := cognew(@Head_interface,0) 'launch new cog for pasm
'do nothing while the cog is working, then continue
pst.Str(String("Stopping Head firing",pst#NL))
PUB Stop''Stops the Cog and the PID controller
if Cog
cogstop(Cog~ - 1)
/CODE
What I am trying to do is =====>
In the spin code, I want to do nothing until the cog (pasm exits), then continue
but as expected, the pst.string "stopping" displays right after the start, which makes sense
but i want the newcog to act as a subroutine, block the current cog while the other cogs executes, then continue
regards
Jeff
/CODE
mov ctra, #0
cogid cog_label
cogstop cog_label
CODE/
/CODE
pst.Start(115_200)
if Cog
cogstop(Cog~ - 1)
/CODE
regards
Jeff
It would also be helpful if you posted your entire program.
CON 'Set up the clock mode ' _clkmode = xtal1 + pll16x ' _xinfreq = 5_000_000 '5 MHz clock * 16x PLL = 80 MHz system clock speed _clkmode = xtal1 + pll16x 'Set up the system clock mode with 16x PLL _xinfreq = 6_250_000 '6.25 MHz clock * 16x PLL = 100 MHz system clock Frequency3 = 30_000_000 VAR long cog OBJ pst : "Parallax Serial Terminal" PUB Main {launch cog } pst.Start(115_200) waitcnt((clkfreq*4) + cnt) pst.Str(String(" ",pst#NL)) pst.Str(String("Starting Head firing",pst#NL)) cog := cognew(@Head_interface,0) 'launch new cog PUB Stop''Stops the Cog and the PID controller if Cog pst.Str(String("Stopping Head firing",pst#NL)) cogstop(Cog~ - 1) DAT ORG 0 'Begin at Cog Ram addr 0 Head_interface mov dira, dira_mode 'mov outa, dira_mode '============================================ leds =============== or outa, Pin13_Power 'Turn on Power Pin ' or outa, Pin15_Trap1 'Turn on trap led '============================================= turn on traps ===== 'Turns on trap one ' andn outa, Pin12_Pin36 ' enable low turns on traps signal ' andn outa, Pin14_Pin22 ' enable low, turns on traps signal 'Turns off trap one or outa, Pin12_Pin36 ' enable high turns off traps signal or outa, Pin14_Pin22 ' enable high, turns off traps signal 'Turns on trap two ' andn outa, Pin16_Pin34 ' enable low turns on traps signal ' andn outa, Pin18_Pin20 ' enable low, turns on traps signal 'Turns off trap two or outa, Pin16_Pin34 ' enable high, turns off traps signal or outa, Pin18_Pin20 ' enable high, turns off traps signal 'Turns on trap three ' andn outa, Pin20_Pin32 ' enable low turns on traps signal ' andn outa, Pin22_Pin18 ' enable low, turns on traps signal 'Turns off trap three or outa, Pin20_Pin32 ' enable high, turns off traps signal or outa, Pin22_Pin18 ' enable high, turns off traps signal 'Turns on trap four ' andn outa, Pin24_Pin30 ' enable low turns on traps signal ' andn outa, Pin26_Pin16 ' enable low, turns on traps signal 'Turns off trap four or outa, Pin24_Pin30 ' enable high, turns off traps signal or outa, Pin26_Pin16 ' enable high, turns off traps signal '========================================= init for tx transmission 'mov time,cnt 'add time, long_wait5 '5 second wait 'waitcnt Time,Period200us 'wait for 5 seconds ' mov time, cnt 'add time, Period200us ' 200 us '============================================= ' testing io pin 15 thru propeller 'or outa, Pin3_Pin15 'set pin 15 high next time is 500ns 'jmpret cp_Pin15_ret, #cp_Pin15 '============================================ jmpret run_init39_ret,#run_init39 jmpret run_traps_ret,#run_traps mov ctra, #0 cogid cog_label cogstop cog_label run_init39 'xor outa, Pin10_Pin39 'Make pin 39 high TX transmission jmpret Init_P39_ret, #Init_P39 jmpret Init_P39_ret, #Init_P39 jmpret Init_P39_ret, #Init_P39 run_init39_ret jmp# 0 '========================================== init for data send 'xor outa, Pin0_Pin37 'make pin 37 high 'xor outa, Pin1_Pin38 'make pin 38 high ' jmpret run_traps_ret,#run_traps ' cogid cog_label ' cogstop cog_label run_traps '=================================================================================== '=============================== send data subroutine ============================== '=================================================================================== '================================================ turn on trap1 led and run routine 'Turns on trap one mov Transmit_t,#0 add Transmit_t,Transmit_r andn outa, Pin12_Pin36 ' enable low turns on traps signal andn outa, Pin14_Pin22 ' enable low, turns on traps signal '==================================================================================== 'Turns on led and sends data, then turns off led or outa, Pin15_Trap1 'Turn on trap led jmpret Send_data_ret,#Send_data andn outa, Pin15_Trap1 'Turn off trap led 'now Turn off trap one or outa, Pin12_Pin36 ' enable high turns off traps signal or outa, Pin14_Pin22 ' enable high, turns off traps signal '=================================================================================== '=================================================================================== '=================================================================================== '================================================ turn on trap2 led and run routine 'Turns on trap two mov Transmit_t,#0 add Transmit_t,Transmit_r andn outa, Pin16_Pin34 ' enable low turns on traps signal andn outa, Pin18_Pin20 ' enable low, turns on traps signal '==================================================================================== 'Turns on led and sends data, then turns off led or outa, Pin17_Trap2 'Turn on trap led jmpret Send_data_ret,#Send_data andn outa, Pin17_Trap2 'Turn off trap led 'Turns off trap two or outa, Pin16_Pin34 ' enable high, turns off traps signal or outa, Pin18_Pin20 ' enable high, turns off traps signal '=================================================================================== '=================================================================================== '=================================================================================== '================================================ turn on trap3 led and run routine 'Turns on trap three mov Transmit_t,#0 add Transmit_t,Transmit_r andn outa, Pin20_Pin32 ' enable low turns on traps signal andn outa, Pin22_Pin18 ' enable low, turns on traps signal '==================================================================================== 'Turns on led and sends data, then turns off led or outa, Pin19_Trap3 'Turn on trap led jmpret Send_data_ret,#Send_data andn outa, Pin19_Trap3 'Turn off trap led 'Turns off trap three or outa, Pin20_Pin32 ' enable high, turns off traps signal or outa, Pin22_Pin18 ' enable high, turns off traps signal '=================================================================================== '=================================================================================== '=================================================================================== '================================================ turn on trap4 led and run routine 'Turns on trap four mov Transmit_t,#0 add Transmit_t,Transmit_r andn outa, Pin24_Pin30 ' enable low turns on traps signal andn outa, Pin26_Pin16 ' enable low, turns on traps signal '==================================================================================== 'Turns on led and sends data, then turns off led or outa, Pin21_Trap4 'Turn on trap led jmpret Send_data_ret,#Send_data andn outa, Pin21_Trap4 'Turn off trap led 'Turns off trap four or outa, Pin24_Pin30 ' enable high, turns off traps signal or outa, Pin26_Pin16 ' enable high, turns off traps signal '=================================================================================== '=================================================================================== andn outa, Pin13_Power 'Turn off run light run_traps_ret jmp# 0 'add Transmit_t,Transmit_r ' or outa, Pin15_Trap1 'Turn on trap led ' jmpret Send_data_ret,#Send_data ' andn outa, Pin15_Trap1 'Turn off trap led '==================================================== Send_data mov time, cnt add time, Pin15_20us 'zero_job '========================================== Start of data send Send_data_L 'xor outa, Pin3_Pin15 'toggle pin 15 next time is 20us or outa, Pin3_Pin15 'set pin 15 high next time is 500ns waitcnt Time,Pin37_38_500ns 'wait on pin 15 20us 'xor outa, Pin3_Pin15 'toggle pin 37 next time is 500ns ' or outa, Pin3_Pin15 'set pin 15 high next time is 500ns andn outa, Pin3_Pin15 'set pin 15 low next time is 500ns 'delay between pin 15 and pin 37 waitcnt Time, Pin37_38_1us 'wait 1 us ' waiting over turn on pin 37 xor outa, Pin0_Pin37 'toggle pin 37 next time is 1 us waitcnt Time, Pin37_38_500ns 'wait 1 us xor outa, Pin0_Pin37 'turn off pin 37 and wait for ping 38 500ns ' turn off pin 37 and wait 500 ns before turning on pin 38 waitcnt Time, Pin37_38_1us 'waiting for 500ns 'waiting is over turn on ping 38 and wait for 1 us xor outa, Pin1_Pin38 'toggle pin 37 next time is 1 us waitcnt Time, Period 'setting up for next loop xor outa, Pin1_Pin38 'now turn off pin 38 and wait for next cycle waitcnt Time,Pin15_20us 'after waiting get ready to turn on pin 15 20us next loop ' jmp #:Send_data djnz Transmit_t,#Send_data_L Send_data_ret jmp# 0 '========================================================== init subroutine Init_P39 mov time,cnt add time, Wait_620ms waitcnt Time,Period200us 'wait for 5 seconds xor outa, Pin10_Pin39 waitcnt Time,Period105ms xor outa, Pin10_Pin39 waitcnt Time,Period200us xor outa, Pin10_Pin39 waitcnt Time,Period105ms xor outa, Pin10_Pin39 waitcnt Time,Period200us xor outa, Pin10_Pin39 waitcnt Time,Period105ms xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period640us xor outa, Pin10_Pin39 waitcnt Time,Period210us xor outa, Pin10_Pin39 waitcnt Time,Period320us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period540us xor outa, Pin10_Pin39 waitcnt Time,Period280us xor outa, Pin10_Pin39 waitcnt Time,Period105ms xor outa, Pin10_Pin39 waitcnt Time,Period220us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period640us xor outa, Pin10_Pin39 waitcnt Time,Period200us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period200us xor outa, Pin10_Pin39 waitcnt Time,Period420us xor outa, Pin10_Pin39 waitcnt Time,Period300us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period100us xor outa, Pin10_Pin39 waitcnt Time,Period210us xor outa, Pin10_Pin39 waitcnt Time,Period200us xor outa, Pin10_Pin39 Init_P39_ret jmp# 0 cp_Pin15 mov dira, dira_modeIO 'pin 6 is output 'pin 5 is input :loop_15 test inmask, ina wc waitpeq Pin5_pin15I,inmask muxz OUTA,#outmask ' xor OUTA,Pin6_Pin15O jmp #:loop_15 cp_Pin15_ret jmp# 0 '===================================================================== Pin3_Pin15 long |< 3 Pin0_Pin37 long |< 0 Pin1_Pin38 long |< 1 Pin10_Pin39 long |< 10 '=================================== data pins Pin12_Pin36 long |< 12 Pin14_Pin22 long |< 14 Pin16_Pin34 long |< 16 Pin18_Pin20 long |< 18 Pin20_Pin32 long |< 20 Pin22_Pin18 long |< 22 Pin24_Pin30 long |< 24 Pin26_Pin16 long |< 26 '================================================== '============================= led pins =========== Pin13_Power long |< 13 Pin15_Trap1 long |< 15 Pin17_Trap2 long |< 17 Pin19_Trap3 long |< 19 Pin21_Trap4 long |< 21 '=================================================== Pin5_Pin15I long |< 5 Pin6_Pin15O long |< 6 long_wait5 long 50000000 ' 5 second wait Wait_620ms long 62000000 ' 1 second wait tmp long 0 'Transmit_t long %00100111_00010000 ' 10,000 cycles 'Transmit_r long %00100111_00010000 ' reset to 10,000 'Transmit_t long %10011100_01000000 ' 40,000 cycles Transmit_t long %00000000_00000000 ' 00,000 cycles Transmit_r long %10011100_01000000 ' reset to 40,000 cycles 'Wait_620ms long 6200000 ' 1 second wait 'Period long 100000 ' 1.25 ms 'Period long 50000 ' 500 us 'Period long 10000 ' 100 us 'Period long 5000 ' 60 us 'Period long 2500 ' 28 us 'Period long 2300 ' 24 us 'Period15_on long 2000 ' 20 us 'Period15_onb long 5000 ' 20 us 'Period15_off long 50000 ' 500 us 'Period15_offb long 60000 ' 500 us 'Period15_offa long 40000 ' 500 us 'Period37_on long 2000 ' 20 us 'Period37_off long 2000 ' 20 us 'Period38_on long 2000 ' 20 us 'Period_38off long 2000 ' 20 us 'Delay37_38 long 1000 ' 10 us 'Delay37_38_1 long 100 ' 1 us 'Delay37_38_2 long 50 ' 500ns 'zero_job long 10 '====================================== init cycles ============== Period100us long 10000 ' 100 us Period200us long 20000 ' 200 us Period205us long 20500 ' 205 us Period105ms long 104000 ' 1.05 ms Period150ms long 150000 ' 2 ms Period640us long 64000 ' 640 us Period220us long 22000 ' 220 us Period210us long 21000 ' 210 us Period280us long 28000 ' 280 us Period300us long 30000 ' 300 us Period320us long 32000 ' 300 us Period510us long 51000 ' 510 us Period540us long 54000 ' 520 us Period104ms long 100000 ' 1.04 ms Period420us long 42000 ' 420 us '======================================= delays ================== Period long 50000 ' 500 us Pin15_20us long 2000 ' 20 us Pin37_38_500ns long 50 ' 500ns Pin37_38_1us long 100 ' us Pin15_next_C long 50000 ' 500us '================================================================= dira_mode long %00001111_11111111_11111111_11111111 dira_modeIO long %00000000_00000000_11111111_11011111 test_modeIO long %0010_0000 inmask long %0010_0000 outmask long %0100_0000 outa_mode long %00000000_00000000_00000000_00000000 outa_P3_1 long %00000000_00000000_00000000_00001000 outa_P3_0 long %00000000_00000000_00000000_00000000 outa_P0_1 long %00000000_00000000_00000000_00000001 outa_P0_0 long %00000000_00000000_00000000_00000000 outa_P1_1 long %00000000_00000000_00000000_00000010 outa_P1_0 long %00000000_00000000_00000000_00000000 Time res 1 cog_label res 1should read
Before you have the cog commit hari-kari, write zero to this variable
pasm_exit mov r1, #0 wrlong r1, par ' alert Spin cog cogid r1 ' get this cog id cogstop r1 ' stop it jmp #$The only thing the cog variable is telling you is that you did in fact launch the cog -- you don't need this to shut-down as that's being done in PASM.
thanks,
makes sense, I'll set it up tomorrow,
regards
Jeff
works very well, thanks
Jeff
var long stack[16] pub main term.start(RX1, TX1, %0000, 115_200) waitcnt(cnt + (clkfreq >> 3)) cognew(toggle_portb, @stack) repeat term.tx("0" + inb[16]) waitcnt(cnt + (clkfreq >> 3)) pri toggle_portb dirb[16] := 1 repeat !outb[16] waitcnt(cnt + (clkfreq >> 1))Yes, I did try it with the A port and it works fine.
