Which manufacturer can do pcb and smt soldering for small sampling volumes?
Hi,
I have designed a board with some SMT components like Prop QFP, 24LC256 SOIC EEPROM, FT230XS, USB Mini-B SMT connector and MicroSD holder.
I need a sampling of 9 pcs for testing.
I know I will not be able to hand solder the samples, especially the FT230XS chip.
Which manufacturer is willing to quote for a sampling of 9 pcs only?
Other than that approach...
I believe that Futurlec and Sparkfun have both used mainland Chinese board makers for customer ordered board. I found the prices through Futurlec to be about the same as direct ordering. And they will do partial or full assembly. They even have the chip inventory on hand.
http://www.futurlec.com/PCBService.shtml
I will try to give you some other names later after digging through old Nutz and Volts. I may have to go back 5 or more years to find the ads.
Coincidently I just came across this great video by Dave Jones of the Electronic Engineering Video Blog http://www.eevblog.com
that discusses issues related to designing a PCB for production or prototype run.
http://www.youtube.com/watch?v=VXE_dh38HjU
No mention of shops that can do that but you may find it useful anyway.
http://www.asktechnology.co.uk/
Prices were reasonable and they did a very good job.
http://superpcb.com/services.html
I am sure there are others, but you may have to search for contacts in Chinese, or even visit Shenzhen to meet face-to-face.
http://www.made-in-china.com/products-search/hot-china-products/Printed_Circuit_Boards.html
Years ago, I made a board in China and was very happy with the price for a run of 25 boards (about $4/each). We did have some delays due to the need to verify information, but I'd much rather have the delays than to receive the wrong item. At that time, I did look into producing them in Taiwan and the person I talked to wanted about $250 USD for a small run done locally. My impression was that if there was any production in Taiwan, they were doing big runs and not wanting to deal with sampling runs that might or might not reorder.
I am not having much luck going through an August 2004 or May 2007 Nuts & Volts. But Googling "printed circuit boards in China" provides a lot of leads. I have more magazines, but the company English names may have changed from then.
Most PCB manufacturers I know do not do assembly work as they deem it too risky. For example, what if the board doesn't work?
Anything below 1000 or more boards to assemble is likely a low-volume assembly... labor intensive and more costly.
You might Google "circuit board assembly services" for companies... and add 'in China' if you want to see local services.
http://futurlec.com/BoardAssembly.shtml
http://www.made-in-china.com/products-search/hot-china-products/Assembly_Circuit_Boards.html
I don't have a stencil printer so I don't think I can stencil align such a small board by hand.
This board is still work in progress. It is supposed to plug directly to PropCam-DB.
http://forums.parallax.com/showthread.php/149285-QFN-chip-solder-points-on-both-bottom-and-edges?p=1197786&viewfull=1#post1197786
And a slightly nicer one here:
http://forums.parallax.com/showthread.php/149285-QFN-chip-solder-points-on-both-bottom-and-edges?p=1200517&viewfull=1#post1200517
With these I was able to reliably stencil and solder parts with 0.4mm pitch.
It will probably take you 3 or 4 boards to get the hang of it, but that's likely to be much cheaper than sending it off to be made.
You can make 9 units in a day.
Order 3 sets of the same board from Oshpark.com = 9 boards.
order 1 stencil + jig from oshstencils.com, and paste from digikey.com
Get helpinghand+magnifier: http://www.radioshack.com/product/index.jsp?productId=31849356
With a steady hand use tweezers to place your parts on the solder pasted board.
In the oven for 7minutes, done.
Maybe Malaysia or Singapore would be a good place to get this done.
Sorry I meant call/email them and ask who they would recommend for assembly. So I did this for you and they recommended Silvtronics in KL. They may be related entities, I don't know. Their address is different
Their online quote tool suggests assembly of 9 boards, each with 8 smd components, would be US$146. You would hand solder the 2 through hole parts yourself. Or you could pay them about an extra $50 to take care of that.
I've also had good luck manually applying solder-paste with a syringe. I then re-flow in a toaster oven. The chips usually have a solder bridge or two, but solder-wick cleans those up quickly.
Marty
One might find an electronics student that desires to provide the service cheaply at a local university.. but that is a bit of a hustle.
Your suggested method is very interesting and simple.
Will be solder placed on the pads make the surface uneven for placement of parts?
How long do you put them in the oven?
Then use the hot air rework station I mentioned. The solder melts and the parts drop down to the PCB while the solder wicks up onto the device pins/pads.
