no answer from parallax
I bought the stamp board homework board USB, everthing works fine, what do i need now to program a basic stamp
so it can work stand alone ? and where in europe (belgium) can i buy this ?
greetings
Dirk
greetings
Dirk
Not sure what you mean by "everything works fine" but there is a lot of information to help you get started.
You need the Basic Stamp editor software of course http://www.parallax.com/downloads/basic-stamp-editor-software
and the manual http://www.parallax.com/downloads/basic-stamp-manual
Other info:
http://www.parallax.com/go/BASICStampStartHelp/
http://www.parallax.com/downloads/homework-board-usb-product-guide
To locate a distributor in your area, please use our "Locate Distributor" page on Parallax.com: http://www.parallax.com/company/distributors
Once you have loaded a program into your HomeWork board from the computer, the program is stored so that it can be run even when not connected to the computer. Just disconnect from the programming cable, attach a 9V battery and turn on the power to run the loaded program. Ron has provided great links to important information about your product; please check out those resources to help you get started and feel free to contact technical support if you run into an issue again in the future.
is it possible to to an analog digital canversion with the homeworks board ?
greetings
Dirk
This A/D http://www.parallax.com/product/adc0831has tremendous support from our Basic Analog and Digital book, a download. I suggest you order it from Andre' and Willeke at Antratek, next door in Netherlands.
greetings
Dirk
Please check any spam folders you may have for your e-mail. The message you sent to us on the 14th was answered the same day about 1/2 hour after we opened by Beau Schwabe.
