Source for CHEAP 4PDT or 4PST dip relays
I am looking for 8 dip relays for a Prop project where I have one microphone and want to switch it between 4 different radios. The mic cable is 8 pins and the radios also are 8 pins. Some of the pins have actual voltage on them, typically 8 VDC and some have ground etc.
There are plenty pf relays on Ebay but the price is through the roof, usually north of $20.00 EACH!. Anyone know of a source for 8 of these guys that won't break the bank?
OR
is there another way to switch 8 lines under Prop control that doesn't require mechanical relays??
Thanks, Mike B.
OR
Thanks, Mike B.
OK, my bad. These are communication microphones and radios ( amateur radio) and they are indeed 8 pin connectors, some 8 pin round and some are RJ45 connectors..
Mike B.
This is a cheap place to buy some things, maybe you will see a part that works for you.
and
Jameco
It may take more pins from the micro but they are very chip relays from many surplus places.
cheers,
rich
I located some 8 channel relay boards on Ebay for $7.50 each that would do the trick and I actually have one here in front of me which I may just use. I wanted something a bit smaller but even with four boards space wouldn't be an issue. The price is right so I'll probably just do that as 4PDT relays are just too expensive and I'd need 16 of the stupid things..
Mike B
