Researching BLDC w/ Hall sensors
                    Hi All,
I'm in sales, and a customer of mine found out about my interest in electronics and tasked me with designing a BLDC controller to drive 4 motors (Maxon or Anaheim automation).
This is for a piece of farming machinery and has extremely simple requirements. Power applied, run all 4 motors at a constant 500RPM (ramp up 1 second). Power of, stop. Every off the shelf product is too feature rich and thus too expensive.
As I have no experience designing motor power circuits and firmware I'm wondering if there is a thread anywhere on this board I could read to get some prop specific tips. I'm busy reading everything i can on the Web.
I'm using search function but there are allot of threads which mention BLDC to get through and not many mention Hall sensors.
I explained I am not a qualified engineer and hes happy for me to give it a go anyway
 quite excited really
The solution is to use an mc33035 bldc driver into an hip4086 MOSFET driver. Irf540 mosfets.
This may not go ahead once he gets to production, but in improving his product he'd like to consider all options.
Nothing complicated at all really. 24VDC supply (truck batteries), single external toggle switch to turn on/off. Single Pot to adjust RPM (same for all motors), single pot to adjust ramp.
Motors are the only 90W each, peak draw is under 5A from memory.
I might think about a small LCD to display the 4 actual RPM readings and thats all.
Oh and an ESTOP.
That's along the lines of what I am thinking. I like the idea of using a prop to control the pwm voltage and closed loop as it allows me to easily fine tune in software.
Ive been reading a few whitepapers from TI, Atmel and freescale among others and it doea indeed sound straight forward.
in the model aircraft section you can get motors up to 500W. 3-phase BLDC driver circuits for 10A start at $10 / piece.
The only thing I do not know exactly is if the already give rpm-feedback to get a constant rpm under changing loads.
But this can be done by the hall sensors. So all your propeller-chip has to to is create a model-servo-compliant signal
pulswith controlled be hall-sensor rpm-feedback. Or even use a magentic encoder-chip from austria microsystems
http://www.ams.com/eng/Products/Magnetic-Encoders
https://forum.sparkfun.com/viewtopic.php?f=5&t=20813
so most parts can be bought right of the shelf. What cost-limit do you want to stay below?
best regards
Stefan
If I can halve his costs he would be happy. The current controller from Anaheim is $179USD and he would need 4 per truck, so I have a rather easy goal of coming under $360USD for my 4 motor controller. I'm aiming for under $300.
The key with this application is that it needs to be reliable. It will be operating for years on a piece of farming machinery inside a sealed enclosure (to protect from fertiliser). This means heat tolerant, vibration tolerant, etc. Industrial grade essentially.
I have mentioned non-industrial grade products but my customer is not happy with that suggestion for the above reasons, and to be honest i wouldn't be happy selling them to him. This is why brushless motors were chosen as opposed to cheaper brushed motors. And why Maxon/ Anaheim motors and controllers were chosen despite their relatively high price compared to hobby products. Yes, this is price sensitive, but within reason
The load on the motor can and will vary, hence the need to a closed loop system and using motors will hall sensors.
higher, perhaps even 100A. You'll need to implement current sensing and over-current limiting/shutdown.
Finding the right 3-phase controller chip would be a smart move, there's probably one
that does all you need.
There are some good MOSFET drivers for 3-phase, I've used the FAN7388 before and it
seems to perform well, its a reasonable back end (add 6 n-channel MOSFETs, 3 caps and 3 diodes).
For reliability make sure everything runs nice and cool, pay attention to fault conditions (fast
response to overcurrent, TVS to suppress over voltage, generous voltage ratings on MOSFETs).
PS I'd be very surprised if the hall-switch outputs aren't open-collector - should be easy to
interface too - be sure the hall sensor signals come in one a separate cable from the motor
windings, and a shielded one if possible.
This is the hall on Anaheim motors.
While we are testing an Anaheim motor, they are leaning more towards the Maxon motor due to the flat construction(EC FLAT 90W). It has a starting current of 69A (we are using the 36V motor sorry), 4.76A nominal.
Ill start a search. That's looking like the way to go, with the prop telling it what to do.
Thanks for the tips.
Initially 10-15 systems will be built, after that maybe 10-20 per annum would be a conservative estimate. Our volumes over here aren't quite up to US standards
I intended to put all 4 drivers on a single board. I considered individual boards so if one driver fails just that board can be replaced. But ultimately I don't want anything to fail so...
Cable length is currently 3-4 meters, but this was not my idea. I will be recommending he move the controller much closer to the motors (say within 1m) and separate the hall from the motor cables.
Controls (on/off switch as it relates to this project) will be in the cab, motors at the back of the truck. So there will be a single cable running the length of the truck, but its only for a push button/toggle so no big deal.
From the point of view of the motor, the load is a flywheel with varying mass (+/- 10% while operating), I need to keep the RPM constant. I cant go into details as i'm under various confidentiality agreements sorry but I hope this is enough of a description.
There is no gearbox to remove a point of failure. Even sealed gearboxes dont like hanging out on the back of a fertilizer truck.
And why do they have such high voltage and current ratings if all they are doing is turning on/off the MOSFET?
This questions is due to my lack of understanding of how FET's work...
They perform several functions in one package, saving a lot of complexity:
Drive the gate hard - charge up and discharge the gate capacitance with high
currents to get fast switching - with power electronics you seek to tame the
switching losses which go up as the load power and PWM frequency and switching
time.
Provide a bootstrapped supply to a floating high-side driver (some chips can handle 600V
or more). This is because you use all n-channel MOSFETs in a high performance bridge,
p-channels are about 3 times worse in performance due to the low mobility of holes compared
to electrons. An all-n-channel bridge requires bootstrapped floating supplies to the high-side
switches - typically you add a few diodes and capacitors.
Handle shoot-through prevention and or dead-time generation to prevent catastrophic
device failure due to shoot through current / power spikes. Chips differ a lot in what
they provide here.
Provide hysteresis on the inputs to help prevent false triggering due to induced
switching noise
Provide under voltage shutdown for the gate driver supplies. Without this the gates
might float into the linear region if the 12V supply was failing, causing the MOSFET to
explode as its dissipation jumps to kW levels.
Allow the bridge to be separately powered from the gate drivers without
any special interlock.
Some also have zener protection on the gate/source drive to guard against gate
oxide punch-through.
Thanks Mark, ill try translate and digest that!
Sounds like it makes life easier picking a MOSFET. I won't have to worry about input voltage being too low for output voltage for example. Low Rds on not as critical etc etc?
So in otherwords, for my application with a 100A peak (5A nominal) and 24V supply, I can just choose a suitable MOSFET with higher voltage and current capabilities (and thermal considerations) and ill be ok?
I guess switching time would be another considerations which brings me to another question.
To control speed/torque, looks like ill need to provide a PWM signal to whichever phase is active. Is there a nominal frequency? Or should I just go as high as the driver/MOSFET will allow?
Great thanks
I have a plan in mind which would use 4 pwms anded with various masks to give me the required 6 outputs per motor. Shouldn't be too hard on the prop.
And no, noise isnt a concern haha
