operating temperature range
I've been asked recently to list the operating temperature range of the Propeller ASC+ and I don't know how this is typically done. Does a sample of the board need to go though some certified testing procedure, or is it sufficient to use the rating for the least robust silicon component on the board?
Yes, the least robust componet at high temperature AND the least robust at low temperature would be needed.
You might want to clarify that the Propeller itself is tolerant of -55 degrees centigrade to 125 degrees centigrade, and offer wider temperature range support by special order.
You could start with your freezer, and then try a cooler box with dry ice (freezes at -109.3 degress F or about -78.5 degrees C.). Liquid CO2 might even be ideal as it is supposed to be at -55 degrees C at 30bar. Not sure how to deal with the liquid being open to the atmosphere though... maybe blasting with a fire extinguisher.
You can get a bottle of CO2 at any Coca Cola, Pepsi, or beer distributor. I use to use it to drive nail guns and a variety of air tools without the racket or electrical hookup that a compressor requires.
I got the 150 degree limit for silicon off of power BJT thermal limits. I guess it is the junction that fails at 150 degrees.
http://scifun.chem.wisc.edu/chemweek/pdf/CarbonDioxide.pdf
http://www.interfacebus.com/Transistor_Derating_Guide.html
If you need to this testing then use at least 3 samples though 5 or 10 would probably be better. For best results use product that was built at different times.
Thanks for the input. I may pursue professional(ish) testing to expand that rating at a later date.
