Wireless Ethernet Extender
JonnyMac
A friend lives in a small housing association that wants to have a video feed at the entrance of their community. They have power, but that's it. The system they want to use is intended to be connected to a wired router for remote monitoring. He's hoping to find a wireless Ethernet extender -- think using a XBee module in pass-through mode.
Any suggestions?
Any suggestions?
(I'm sure someone will ask that so it may as well be me!
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=wifi+bridge
My own is hacked with custom Linux firmware. You might try OpenWRT to get an idea of how well supported this is.
I do know that groups have set up temporary networks for gathering of mobile homes that completely eliminate the need for ADSL. I just can't think of how to search for a link right now.
I am sure that OpenWRT can modify any supported wifi router into becoming a wifi bridge. But there are the advantages of having more LAN ports to plug into, maybe a few USB slots as well. If you want a printer server at a remote end, that can be done too.
Here is the Wikipedia entry.
http://en.wikipedia.org/wiki/List_of_wireless_router_firmware_projects
Just be sure to buy a wifi router that has a lot of the features you desire AND can reload its firmware.
This shows connecting an HDTV, but it should work with other devices.
Another alternative is power line adapters, if the power that runs out to the entrance comes from the building with the network gear something like this is better than wifi -
http://www.newegg.com/Product/Product.aspx?gclid=CIXV_6ujmr4CFU5afgodgjIAUA&Item=N82E16833704164&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Powerline+Networking-_-N82E16833704164&ef_id=UumYZAAAAPtt3QfB:20140507165352:s
Goes up to 900'. There may be other better power line adapters for your situation, the above is just an example.
