Very extremely simple basic clueless Question about Transistors
I wanted to order some LED's because I found I had absolutely none and they are way helpful to signal my programming is OK..., and a few other bits so that the order would at least equal the postage cost and I can play around with my breadboards and re learn things I haven't done for years...just a bit of fun!!!
I wanted to get a few cheap transistors just to play with and try and remember how they work, npn and pnp. ( i remember one is more popular than the other) but the list of transistors to tick was very very long and the info beside them was similar and the price range was 16 cents to $1.29 (futurelec australia) http://www.futurlec.com.au/Components.jsp They deliver fast and postage is always minimal.
There are basically General Purpose Transistors, Switching, Power transistors.I used them long ago to turn on a led or a relay, the most voltage I used was 6 volt i *think* and the relays i used were in clear casing so i could see them work, but i dont remember what they were i just ordered a couple randomly and got them to work . So if I just want to play with turning leds on and relays can you give me a hint, will General purpose be all i need with both NPN and PNP ?
BTW. Are not Power Transistor Mosfets ?
I would also like to get a relay or two but not the ones in clear casing as they are much more expensive. Can you also suggest the type of inexpensive relay i might use to turn on a 6 volt motor ?
http://forums.parallax.com/showthread.php/154266-Parts-every-hobbyist-should-have
The small devices 2n3904/2n3906 are handy and don't waste enough power to bother with shifting over to MOSfets. I like the 2N2222/2n2907 as well.
There are lots of other transistors, but these are the only ones that you will need for most micro-controller stuff.
The 2N3055 is a real sizzler that once was a work horse of controlling synchronization of the the high voltage in televisions. But to use it properly, you really should have a heat sink that is about 6" x 6" and 1" tall... not exactly small. Adding a fan might be wise too.
Weird thing happened, my pc was acting hopelessly slow. ,i got a phone call after a couple of hours from some indian sounding accent offering their concern and a way to fix it. i said "excuse me did you say u were from my exetel my sevice provider", no he told me it was microsoft calling, spent a good half an hour with me telling me commands to type to clean system and he could see my screen. Then to finish off he took control of my machine while i watched. there was a trojan. So after it all my PC was blazing fast again and all fixed.
he offered me different priced sevice packages, i declined and the call ended. After a while i realized that microsoft has never done that out of the blue and ive never heard of anyone else having such a spontaneous call and help and taking over their computer.
So i reformatted the drives , put win7 and liux back on and changed all my passwords while laughing at myself for being taken in like that.nothing close to that has ever happened to me before.
Still. It had a positive outcome. The scammer got nothing for his effort and you became aware of the holes in your machine. Mind you I'm not sure putting the same buggy OS back on there prevents that guy or someone else getting in a again.
9
It's off to ScamWarners.com for the both of you...
The funny thing about transistors, is they don't seem to handle short circuits very well, not very well at all...
http://forums.parallax.com/attachment.php?attachmentid=92496&d=1336959728
-Tommy
http://www.microsoft.com/security/online-privacy/avoid-phone-scams.aspx
You were right to reload everything after that. But I just stay away from Windows altogether. Nobody would every call to say they are the Linux Tech Support.
yes your right but this is my laptop not the destop with the microsoft scam.
And how did he het my phone number and know my internet privider and and have control of my pc before he even rang? Anyway Ive got kaspersky and microsoft essentials on the desktop and i wount be downloading from torrent sites again.(uning windows)
ps. Firefox is the best, second ....not sure.
Iwill fix the laptop with a reinstall but its a dell fromebay, Its a harder thing to reinstall because you have to go to the dell site and click on your laptop model and then click all the drivers you need and then it will be fine. Its just a bit more work,
