Boe Bot: Missing Parts?? Green LED?
My son and I just cracked open a Boe-Bot Robot Kit with USB and we were going to work through the activities in the "What's A Microcontroller v3.0" pdf. In "ACTIVITY #1: BUILDING AND TESTING THE LED CIRCUIT" it says to use a Green LED .. and nowhere in our box is a green LED. We have -- what we think -- are two different "clear" LEDs and -- what we think -- are two Red LED's but nowhere are there green ones.
Are there supposed to be green ones?
This is a major let-down considering how excited we were...
Different color LEDs theoretically need slightly different resistor values, but this doesn't matter for your kit. The only difference you might notice (and you probably won't notice and it doesn't really matter) is different color LEDs will be slightly darker or brighter than other colors.
electrodude
Make sure you use a resistor as shown in the instructions.
Just substitute the Red Led instead of the green one.
There are other experiments in "What is a Microcontroller" that use parts that are not listed in the BOE-BOT kit. There is a package of parts for that book, but it shows out of stock until 30 April. You can find those parts at this link:
http://www.parallax.com/product/28122
Hope this helps
Tom
Very true. A common trick to "see" IR light from an LED is to look at it through your (phone's) camera. The image sensor sees IR even if your eyes can't.
The Boe-Bot Robot Kit has all of the parts required to do the activities in its tutorial "Robotics with the Boe-Bot." Here's a list of the electronic components in that kit (follow the link and click Details):
http://www.parallax.com/product/572-28132
The "What's a Microcontroller?" tutorial has its own baggie of parts. The book, parts, and a BASIC Stamp board are included in the "BASIC Stamp Activity Kit:
http://www.parallax.com/product/90005
Or, you can buy the parts separately from the BASIC Stamp board and book, if you like. Go to the link below and click Details to see what is in it:
However, there are a lot of things you can do from "What's a Microcontroller?" using the parts from your Robotics kit, though you will need to substitute the red LED for other colors as you discovered. It is such a common request that I posted a list here:
http://learn.parallax.com/teach/wam-activites-boe-bot-parts
I hope this helps!
