"best" power MOSFET
I am not an EE. I struggle reading part spec sheets. I have some surface mount MOSFETs claiming a 100 amp continuous rating. As I dissect the sheet further and further it appears the authors consider on-times of 100 ms to be proof of continuous ratings. For my application I now reject surface mount designs simply because I can't bolt on extra heat sinks and because the small size /form factor makes a 100 amp true rating even hard to achieve with affordable copper board (even if you could set aside the cruel laws of thermodynamics). Back to through-holes. My application involves draining a 60 Ah battery from 4.12 volts to 2.5 volts through a .1 ohm resistor controlled by a bottom balance Propeller program. Continuous current would be about 40 amps that declines as the voltage of the cell drops. I'd like to avoid having to buy expensive SSRs or paralleling power MOSFETs (although it can be done) if possible. What would be the favorite power MOSFET in such a case. Due to thermodynamics, bigger size and beefier tabs are better. I'm willing to solder #10 AWG solid copper wire on to the board to avoid spending the big bucks for heavy copper greater than 2 oz/ft^2.
Pics or it didn't happen (e.g show schematic)
As I don't know what you mean when you say draining. what is this 4.12v to 2.5v conversion all about?
In general, for electrical material... the higher the volts, the more insulation is required. And the higher the amps, the larger the copper wire diameter.
I strongly suspect that nothing over about 3 amps should really be on a printed circuit board unless there are some serious modifications to the heavy current runs. And so... it seems to me that a MOSfet that is rated at 100 amps continous on and is surface mount, tends to be paradoxical. The MOSfet migth run cool, but the leads on the circuit board may just burn up under load.
Use a mosfet with extreme low on Resistance, if rapidly switching the mosfet use 4amp gate driver.
Use SMT heat sinks to aid the copper pours dissipating of heat.
But until we know what you are trying to accomplish your DIY voltage regulator or what ever it is, may not be the best way to go about it anyway.
Just a hardware switch is needed for that.
But I guess with some controlled intermittent power burst testing, a mosfet is needed.
Or is this a under-voltage protection circuit that is gone be in final design?, maybe it's better to implement that on the individual lipo cells.
Just parallel the MOSFETS - it is what eveyone does.
- they are cheap enough, and splitting the load resistor also helps spread the heat.
eg 5 FETS with 0.5 Ohm loads will be ~ 8A per fet, and at that level a 10mOhm fet is under 1 watt. (640mW)
sub 5mOhm fets should be cheap enough, and lower the cluster heating effects.
The power dissipated by the transistor will be 1600 x Rds on ( I squared x R) rating of the transistor. The 0.1 ohm resistor will be dissipating the balance so it should be at least a 150W.
PSMN1R1-30PL
RDSon = 1.3mΩ
So at 41.2A
41.2A2 * 1.3mΩ = 2.2W of power dissipation in the MOSFET
OK it has a 10V gate.
But seriously low RDSon is best done with 10V gate drive.
Duane J
Thanks, I will. I've also found out Spec sheet writers are a lot like math teachers. The really bad ones have you thinking you are the thick one. I've found that International Rectifier has better spec sheets. IRF1324PbF is in a TO-220AB package. I've got some new solid copper bar stock here I can bolt all the tabs to. They list a "package limited" current of 195 amps. I fully agree on the 10 volt gate charge-to-voltage. I'm going with two wall worts driving a +12 regulator and a -12 volt regulator so I have sources I can run through optos to the gate pins. Yup, it's a poor man's DC-DC isolation. The package limit or wire bond limits listed more fairly address the issues Beau Shawb was referring to above. Silicon limited on these spec sheets doesn't matter if one burns off the leads.
http://www.mouser.com/ProductDetail/Ohmite/DV-T263-201E-TR/?qs=sGAEpiMZZMttgyDkZ5WiurC9qN77dzSraAkYy3aT9dM%3d
http://www.mouser.com/ProductDetail/Aavid-Thermalloy/7109DG/?qs=sGAEpiMZZMttgyDkZ5WiujTlBOILjl7xi4aoVUO77j4%3d
Forget PCB, use proper packages with screw terminals for that sort of current:
http://uk.farnell.com/ixys-semiconductor/ixfn200n10p/mosfet-n-sot-227b/dp/1427322
