About to begin robotics
                    Hi, I have spent a couple of days rtrying to find a robot that I could afford esp;ecially as its all new to me. The parfallex robots were out of my reach just now so i looked at something cheasper to begin with.
There was the Bot 120 from Spark fun powered by the brains of a picaxe chip. Since Ive made several projects using the picaxe and that irts programmed in basic i very nearly bout it for $75 dollars.
There were a few others but the price was always out of my reach. I settled on a robot that used a rasberry PI because I had one not being used. I had to purchase a chassis to give it movment and a robotboard for it as well. The cost was only $45 dollars + $30 IF I COUNT THE RASBERRY PI THAT WAS NOT BEING USED.
Magician Chassis
Out of stock ROB-10825
$14.95
RaspiRobot Board
Only 10 left! KIT-11561
$29.95
I could have bought the bot 1q20 with the picaxe brain for the same amount. I hope i dont end up regretting it but the robot im putting together can be progtrammed using python which im only just learning. I have searched the internet for code rthat learns. You give the robot a job to do but the code doesent contain routines that solve the problem , it is code that allows the robot to learn and try to decide the best course of action on its own.
Is this becoming the standard way for hobbyists to try and program there robots ?
Waht sort of things have you been able to make your own robots do ?
Thankyou, Mike.
Magician Chassis
$14.95
RaspiRobot Board
$29.95
Thankyou, Mike.
http://www.picaxeforum.co.uk/showthread.php?25836-Starting-Robots
yes, that is me ?.. I wish i jad checked back at this forum because i missed so many good replies. I want the boebot or the scribbler !!!! Alas Ive just used the credit card to buy the package Magician Chassis
$14.95
RaspiRobot Board
$29.95
However as the magic is out of stock (even though i paid for it) if i write a convincing email there may be a slight chance i can cancel the order. Ill try and post you the result
Ecro, the seconhand bots you speak of can be powered by basic stamps or the prop ..true ?
Just out of curiosity, what do you think of the Lego mind storm as a robot ?
The original (blue) scribbler and the BOE-BOT both include the BS2 chip. The new Scribbler (red) has a Propeller on board.
I agree with erco. The BoeBot would be the best to go with for learning.
If i do end up getting the Boe Bot and its prop powered, I hop[e i find some interesting code in the obex. Perhaps there might even be some code that helps the robot to Learn , rather than just follow code line by line ? Here an idea off the top of my head at 2.38 in the morning
Try eBay for a used BOE Bot. Keep your eye out for a deal -- you can often find something in the $50 range, especially now as school is getting out.
There's nothing wrong with LEGO bots, but they're no less expensive than anything you'd cobble together. You'll learn more with a BOE Bot or system you put together. Stick with a robot that uses servo motors; you won't need motor bridges that way.
The PICAXE is a fine chip and all you really need for your first bot is an 08M2 ($3), download cable, a mini breadboard, some jumper wires, long 3-pin headers (to more easily connect your servo motors to the breadboard) and a small assortment of resistors. Total cost for these parts shouldn't be more than $10.
Anyway, there are always ways to do it on the cheap, but there's a greater chance of failure when you put everything together yourself. The world is full of robot first-timers that turned out to be only-timers. If you can save up a little bit more, my preferred choice would be a used BOE Bot chassis with a Parallax Activity Board.
I have a thread about making an inexpensive robot. It doesn't take much money to start learning about robotics.
If you do decide to use the Propeller (and you'd be nuts not to), I have a list of links to Propeller tutorials in post #3 of my index (see signature). While you're there (in the index), you ought to check out some of the projects listed in post #2. I'm not positive all the projects use a Propeller, but I'd be surprised if any of the listed projects don't include one. There's a Scribbler 2 project on the list, there's also a BOE-Bot on the list. The BOE-Bot isn't a BS2 version it's a PropBOE-Bot.
If you're looking for a ready made kit, I'd suggest the Activity Bot (though I think I'd still use Spin to program it) or the Scribbler 2.
The standard BoeBot is BS2 powered. There is a new Bot that is propeller powered:
http://www.parallax.com/product/32500
Might be hard to find used as it is kinda new.
Sorry, I missed posts #8 and #9 while I was typing #10.
While my PropBOE-Bot didn't learn to like tuna, it could remember the course it took while under remote control.
And sure a robot can learn. As long as the line by line code tells it to do so.
Lots of the Propeller boards Parallax sells will fit on the BOE-Bot just fine. Off the top of my head I can think of the Propeller Proto Board, Project Board, PropBOE, and Activity Board.
My first Propeller powered BOE-Bot used an upside down Proto Board. I attached a breadboard to the back of the Proto Board and used female headers to bring all the IO pins up around the breadboard.
This upside down Proto Board is now used to control my omni-bot. (Make sure and check out the "OmnibotSpinningStraight" video.)
http://www.ebay.com/itm/ROBOTICS-BOE-BOT-ROBOT-MODEL-KIT-/171307713413?pt=LH_DefaultDomain_0&hash=item27e2bc4385
If you decide to switch to the Propeller then all you need to do is take the Board of Education off the Boe-Bot and replace it with a Propeller Activity Board. There are instructions and code on the Learn website on how to do this.
The Boe-Bot manual has instructions on how to assemble and program it. You should first read What's a Microcontroller, which can be downloaded from the Parallax website before you stat with the Boe-Bot text. What's a Microcontroller (WAM) will show you how to use and program the BASIC Stamp 2, which is the Microcontroller the Boe-Bot uses.
If you have any questions you can always post them here and someone will help you out. Good luck on Ebay.
Thanks for the tip about the Magician, I was able to cancel the order. They told me there should be as new improved chassis in several weeks, I think they didn't think too highly of it either
.Some of the robots about a foot in height were very high end looking with many types of sensors and servo motors, no price, you had to ask and if i have to ask, I'd think i can't afford it ! There were multiple sellers of the lego MindStorm which can be programmed in its own graphical way or MS Robots C# and other methods. I found it curious the prices were around $150 yet ebay and other places want over $400 ?? but I'm sure you have too buy a fair number as the site is wholesale.
So I have taken your advice and bought a Scribbler with a basic stamp microcontroller. It cost me only $20 like you thought. It looks like such a tight, closed case for anything i might want to add on, but i guess I'll see what is possible soon. Ive never used a basic stamp so im downloading the manual and will have a pretty reasonable idea by the time it arrives.
The boe bot you linked to was looking reasonable even with freight cost but since I bought the scribbler at such a low price i dont want to get into a potential bidding war. This all started out because i had a rasberry Pi and wanted to do something with it. Well I'll just hang on to that for the moment. And anyway the robots Ive noticed on searching the Pi seem to always have another microcontroller as part of the setup, a picaxe or an arduino> It was not easy to search for robot building without running into Arduino.... So Im happy getting the scribbler to make a start. Ive got a few general questions but i'll ask in the general forum. Thanks everyone who wrote a response to my post.
regards,
Mike.
Playing with a Scribbler can be fun but a Boe-Bot is customizable with over a dozen add-ons.
Some of the people on the Forum also use other products such as the Raspberry Pi so someone might know what to do with it or might trade it for something else.
The BASIC Stamp has been around for years so there are many nice books on it.
If you download the BASIC Stamp Editor, What's a Microcontroller and the Stamp Reference Manual are both inside. Many of the WAM activities can be done with the Boe-Bot parts.
Robotics is just one of the areas that the BASIC Stamp is used.
Plenty of info out there and in the forum. Hopefully you get all the documentation with your bot. See info.hobbyengineering.com/specs/PX-ScribblerHackHint.pdf
Here's an article I wrote: http://www.botmag.com/index.php/take-charge-of-your-scribbler-robots-ir-capabilities
This question is way premature but i'll ask anyway. How do you make the robot LIKE doing something . a very simple way would be to increase a value and have it repeat the action until it reaches any arbitrary value you have assigned. but that's just following a loop that's pretty fake . There would be some kind of reward algorithm that's not complex that would be better than that ?
I'll try to find a link to the project and post it here.
I thought it was a cool project but one downside to his approach was the need for redundant sensors.The non-contact obstacle sensors had to have a corresponding bump sensor for the robot to make good use of the non-contact sensor.
Let's face it, no matter what sort of algorithm one comes up with for a robot to feel "pain", the algorithm will be "pretty fake".
It's so much easier to adjust some software values then spend 2 or 3X more for higher quality components.
Jim has more information about the project on Let's Make Robots.
That was great, I'll be trying out a version for the Scribbler , I though the led turning on when its Afraid was a funny trick ! maybe if i find another $20 Scribbler I could put them in a room together and soon see who was a brave or cowardly robot, taking note of what Genetix said about sensors being not perfectly uniform
Champagne tastes and a beer budget. For your $20, your S1 will keep you busy for a bit while you save up for an Activity Bot.
The first link in post #10 leads to thread on how to make an inexpensive Propeller robot. One could get a Propeller robot up and running for about $50.
Avery excellent resource ,thank you for showing it to me. That looks like the way i will go next , probably sooner than i even think. Because i do have Champlain tastes on a light beer budget !
I didnt think my local electronics store had robots but they do from going to their website. Even a simple platform with wheels is dirt cheap however your ideas may make that unnecessary.
I'm glad to see you thinking straight.
With some extra IC chips the Prop should be able to control 144 servos (with a single cog).
The guy, he was going to let me know Monday the postage , it wont be much because hes only a few hundred miles away in Australia has still not got back to me, ill just keep waiting.
