Please post source code for smooth roaming with Ping)))
Hello,
I just·got my boe-bot and am new to programming this thing.· I'm trying to figure out how to have the boe-bot roam with ping, but not stop to take measurements.· There is an example code file I tried, but the robot moves forward in a jerky manner.· Is there a way to keep the robot rolling smoothly, while the ping servo scans around. Or is that just too much for the basic stamp?
I had the same problem with my Boe-Bot. I tried to write a program that rotates the ping and keep the servos going at the same time. The trick is to keep the time between your wheel servos to about 20-30ms. Anything more than that and your bot will be slow and quick to stall. It is not hard to keep the wheel servos going and taking ping measurements and perhaps just stopping swivelling around the sensor only when it detects something.
What code are you using?
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
I am working on some code right now that will lunge towards targets when it detects them within a certain range. It's for a SumoBot that I intend to implement on a Prop, as soon as I get the parts for it. I will post you the code when I have it finished. It is written for the BoeBot in with the BS2.
If you are new to the BasicStamp, I cannot emphasise enough to go through the Boe-Bot book that came with the package. The sensor stuff can be a little daunting if you don't fully grasp the basics yet. There are also some other PING))) experiments in the Smart Sensors book. You can download it here: http://www.parallax.com/dl/docs/prod/sic/SmartSensors-v1.0.pdf . It's a great read. The code for the book can be found here: http://www.parallax.com/dl/sw/SmartSensorsv1.0code-v1.zip
Remember Jason-san, you must learn to walk before fly!
Mightor Myagi
Post Edited (Mightor) : 7/22/2007 8:10:36 PM GMT
' {$STAMP BS2} ' {$PBASIC 2.5} Ping PIN 15 PingServo PIN 14 LeftServo PIN 13 RightServo PIN 12 rawDist VAR Word sweepcount VAR Word x VAR Byte pulseCount VAR Byte Main: FOR sweepcount = 350 TO 1150 STEP 200 FOR x = 0 TO 5 PULSOUT 14, sweepcount PAUSE 20 NEXT GOSUB GetSonar NEXT FOR sweepcount = 950 TO 550 STEP 200 FOR x = 0 TO 5 PULSOUT 14, sweepcount PAUSE 20 NEXT GOSUB GetSonar NEXT GOTO Main GetSonar: LOW Ping PULSOUT Ping, 5 PULSIN Ping, 1, rawDist IF (rawDist < 600) THEN IF (sweepcount < 750) THEN GOSUB Turn_Left ELSEIF (sweepcount > 750) THEN GOSUB Turn_Right ELSE GOSUB Back_Up ENDIF ELSE GOSUB Forward_Pulse ENDIF RETURN Forward_Pulse: FOR pulsecount = 0 TO 5 PULSOUT LeftServo, 850 PULSOUT RightServo, 650 PAUSE 20 NEXT RETURN Turn_Left: FOR pulseCount = 0 TO 10 PULSOUT LeftServo, 650 PULSOUT RightServo, 650 PAUSE 20 NEXT RETURN Turn_Right: FOR pulseCount = 0 TO 10 PULSOUT LeftServo, 850 PULSOUT RightServo, 850 PAUSE 20 NEXT RETURN Back_Up: FOR pulseCount = 0 TO 3 PULSOUT LeftServo, 750 PULSOUT RightServo, 750 PAUSE 20 NEXT FOR pulseCount = 0 TO 7 PULSOUT LeftServo, 650 PULSOUT RightServo, 850 PAUSE 20 NEXT RETURN
If you don't stop when you take a measurement with the PING))) every measurement taken that way will be inaccurate. What's the point of having the PING))) then?
Bruce Bates
It can be very handy to know if there is an object while moving, for example if I detect an object with 20 cm in front of my 'bot, I stop and take a more accurate reading. It can also be usefull for room mapping and tracking. Sometimes just knowing that the object is there is important.
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
As I remember the following phrase was mising from Jason's post:
"I stop and take a more accurate reading"
OTOH, I'm not sure that the following is going to happen accurately and repeatably if you're moving:
"if I detect an object with 20 cm in front of my 'bot"
'Nuf said -
Bruce Bates
' File...... RoamingWithPING.bs2
' Purpose... Roam And Scan Using PING))) Mounting Bracket
' Author.... Parallax, Inc.
' E-mail.... support@parallax.com
' Started...
' Updated... 12-21-2005
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This programs demonstrates roaming with the Parallax PING))) Mounting
' Bracket, which allows you to pan-scan with your Parallax PING))) sensor.
' This program assumes you have already set your BOE-Bot up for roaming
' with IR sensors. You must also have the PING))) Mounting bracket
' installed as per the instructions, with the servo connected to P14 and
' the PING))) sensor connected to P15.
' Due to the way the PING))) bracket mounts you may have to trim your IR
' detectors down so that they don't stick up in the way of the moving
' PING))) bracket as it rotates. It's best to angle them off at 45
' degree angles so that the BOE-Bot doesn't run into anything while
' moving along a wall at a narrow angle.
' The BOE-Bot will now roam around and when it senses an object, it will
' scan within a 180 degree field of view for the clearest path, which it
' will then navigate scanning for an object again. The IR Sensors prevent
' hitting a wall when coming at it from a narrow angle where the PING)))
' might have trouble seeing it due to the lack of reflection of sound.
' Calibration is important to this code working properly. If you do not
' have the correct values for your servos then you may get strange results
' from your BOE-Bot. The necessary calibration information is listed in
' each section of the code where it is required.
[noparse][[/noparse] Revision History ]
' This code is basically a modified version of the Roaming With IR code
' from the Robotics With The BOE-Bot Manual, written by Andy Lindsay.
' Much of the original code was left untouched so you can see how it was
' altered.
[noparse][[/noparse] I/O Definitions ]
Piezo PIN 4 ' Piezo Speaker
RightServo PIN 12 ' Right Servo
LeftServo PIN 13 ' Left Servo
PingServo PIN 14 ' PING))) Servo
Ping PIN 15 ' PING))) Sensor
[noparse][[/noparse] Variables ]
irDetectLeft VAR Bit ' Variable For Left IR Input
irDetectRight VAR Bit ' Variable For Right IR Input
pulseCount VAR Byte ' Used For Measuring Turns
distance VAR Word ' Current Distance Of Object
oldDistance VAR Word ' Old Distance Value
counter VAR Word ' PING))) Cycle Counter
task VAR Nib ' Current Task
[noparse][[/noparse] Initialization ]
FREQOUT Piezo, 2000, 3000 ' Signal Program Start/Reset
[noparse][[/noparse] Program Code ]
Main:
DO
FREQOUT 8, 1, 38500 ' Emit 38.5 kHz IR To Left
irDetectLeft = IN9 ' Store IR Detection Values
FREQOUT 2, 1, 38500 ' Emit 38.5 kHz IR To Right
irDetectRight = IN0 ' Store IR Detection Values
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Forward
ELSEIF (irDetectLeft = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Left
ELSEIF (irDetectRight = 0) THEN
GOSUB Ping_Around ' Object Detected via IR Right
ENDIF
counter = counter + 1 ' Increment Passive Counter
IF counter > 10 THEN ' Wait For 10 Servo Pulses
GOSUB Ping_Out ' Activate PING)))
ENDIF
IF (distance > 30) THEN ' Is Object Farther Than 30 cm?
GOSUB Forward_Pulse ' If Yes Go Forward
ELSE
GOSUB Ping_Around ' Otherwise Scan For Clear Path
ENDIF
LOOP
[noparse][[/noparse] Subroutines ]
' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE FORWARD *
' * WHILE THE PING))) IS FACING FORWARD. *
Forward_Pulse: ' Send A Single Forward Pulse
PULSOUT PingServo, 750 ' Ping Servo Forward Pulse Value
PULSOUT LeftServo, 850 ' Left Servo Forward Pulse Value
PULSOUT RightServo, 650 ' Right Servo Forward Pulse Value
PAUSE 20 ' Refresh Delay
RETURN
' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN LEFT 90 *
' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. *
Turn_Left: ' Left Turn, About 45 Degrees
FOR pulseCount = 0 TO 7 ' Number Of Pulses To Turn
PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value
PULSOUT RightServo, 650 ' Right Servo Left Pulse Value
NEXT
RETURN
' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN RIGHT 90 *
Turn_Right: ' Right Turn, About 45 Degrees
PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value
PULSOUT RightServo, 850 ' Right Servo Right Pulse Value
NEXT
RETURN
' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE BACKWARD *
Back_Up: ' Back Up
FOR pulseCount = 0 TO 40 ' Number Of Pulses To Backup
PULSOUT LeftServo, 650 ' Left Servo Backup Pulse Value
PULSOUT RightServo, 850 ' Right Servo Backup Pulse Value
NEXT
RETURN
Ping_Out: ' PING)))
counter = 0 ' Reset Passive Delay Counter
LOW Ping ' Force PING))) Line Low
PULSOUT Ping, 5 ' Activate PING))) Pulse
PULSIN Ping, 1, distance ' Receive Return Pulse
distance = distance ** 2257 ' Calculate Distance
RETURN
Ping_Around: ' Start 180 Degree Pan-Scan
oldDistance = 30 ' Current Old Distance Values
task = 0 ' Current Task Priority
' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) *
' * TURN 90 DEGREES LEFT. *
FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin
PULSOUT PingServo, 1085 ' Ping Servo 90 Left Pulse Value
PULSIN Ping, 1, distance ' Receive Distance Value
NEXT
distance = distance ** 2257 ' Calculate Distance In cm
IF distance > oldDistance THEN ' Is distance > Last Clear Path
oldDistance = distance ' Update oldDistance Value
task = 1
ENDIF
' * TURN 45 DEGREES LEFT. *
PULSOUT PingServo, 850 ' Ping Servo 45 Left Pulse Value
NEXT
task = 2
ENDIF
' * TURN 45 DEGREES RIGHT. *
PULSOUT PingServo, 400 ' Ping Servo 45 Right Pulse Value
NEXT
task = 3
ENDIF
' * TURN 90 DEGREES RIGHT. *
PULSOUT PingServo, 225 ' Ping Servo 90 Right Pulse Value
NEXT
task = 4
ENDIF
ON task GOSUB Task0, Task1, Task2, Task3, Task4
distance = 50 ' Prevent Scan From Looping
RETURN
Task0: ' Forward Was Clearest Path
GOSUB Turn_Right ' This Could Mean Narrow Path
GOSUB Turn_Right ' So We'll Turn Around
GOSUB Turn_Right ' You Can Change The Behavior
GOSUB Turn_Right ' Of Any Of The Tasks
RETURN
Task1: ' 90 Degrees Left Was Clearest
GOSUB Turn_Left
GOSUB Turn_Left
RETURN
Task2: ' 45 Degrees Left Was Clearest
GOSUB Turn_Left
RETURN
Task3: ' 45 Degrees Right Was Clearest
GOSUB Turn_Right
RETURN
Task4: ' 90 Degrees Right Was Clearest
GOSUB Turn_Right
GOSUB Turn_Right
RETURN
Here's a link.
http://www.parallax.com/Portals/0/Downloads/src/prod/RoamingWithPING-V1.0.zip
Make sure your batteries are fresh. Weak batteries can cause the Boe Bot to behave erratically.
I'm approaching the problem a little differently ... I'm including the concept of the TableBot 1 Challange ... that is not just to roam, but to roam around on a table top and not fall off the table ...
I have my new robot design set and it works pretty good;
http://www.brainless.org/lrobotorium/Products/BOE-Bot/IMG_1886-20140418-PING-HeadBOE-Bot-c.jpg
The 3D CAD Model;
http://www.brainless.org/lrobotorium/Products/BOE-Bot/PingHead-BOE-Bot3-c.jpg
Here I am running a fundamental program to test the PING, LEDs, Piezo speakers, neck and head servos and wheel servo motors ...
https://www.youtube.com/watch?v=Gx-N6vRkfAQ
Eventually I will write a roaming program for all this and maybe one or two other types of roaming programs with a menu selection through the IR sensor ... for now, here is the code I've started with for the video test;
' PING-HeadBOE-Bot-v02.bs2
' by Walt Perko the SolidWorksMagi
' {$STAMP BS2}
' {$PBASIC 2.5}
LED0 PIN 0
LED1 PIN 1
LED2 PIN 2
IR PIN 7
PIEZOL PIN 8
PIEZOR PIN 9
srvohd PIN 11
srvonk PIN 15
wheelL PIN 12
wheelR PIN 13
i VAR Word
j VAR Word
' PING Conversion constants for room temperature measurements.
PINGR PIN 14
DistanceF VAR Word
DistanceD VAR Word
DistanceL VAR Word
DistanceR VAR Word
' Default Settings
CmConstant CON 2260
InConstant CON 890
cmDistance VAR Word
inDistance VAR Word
time VAR Word
' Variable Assignments
DistanceF = 10
DistanceD = 10
DistanceL = 10
DistanceR = 10
' START Main Program Body * * * * * * * * * * * * * * * * * * * * * * * * * *
DO
' R we near a tables edge?
GOSUB tabletest
GOSUB fwrd
GOSUB PING
GOSUB flash
GOSUB lookL
GOSUB PING
GOSUB flash
GOSUB lookR
GOSUB PING
GOSUB flash
GOSUB closest
'PAUSE 500
LOOP
' END Main Program Body * * * * * * * * * * * * * * * * * * * * * * * * * * *
' Subroutines * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
' Flash the LEDs
flash:
FOR i = 0 TO 1
HIGH LED0
PAUSE 30
LOW LED0
HIGH LED1
PAUSE 30
LOW LED1
HIGH LED2
PAUSE 30
LOW LED2
PAUSE 25
HIGH LED2
PAUSE 30
LOW LED2
HIGH LED1
PAUSE 30
LOW LED1
HIGH LED0
PAUSE 30
LOW LED0
NEXT
RETURN
' START TableTopTest * * * * * * * * * * * * * * * * * * * * * * * * * * * *
tabletest:
GOSUB lookdn
GOSUB PING
'GOSUB flash
IF DistanceD > 5 THEN GOSUB backup
RETURN
' END TableTopTest * * * * * * * * * * * * * * * * * * * * * * * * * * * * **
backup:
' Tables Edge has been Detected ... BackUp and Turn about 30°
GOSUB warning
GOSUB stepB
GOSUB warning
GOSUB stepB
RETURN
END
warning:
GOSUB lookU
FOR i = 0 TO 1
PULSOUT srvonk, 375
HIGH LED0
LOW LED1
HIGH LED2
FREQOUT PIEZOL, 100, 3200
FREQOUT PIEZOR, 100, 2500
PULSOUT srvonk, 1000
LOW LED0
HIGH LED1
LOW LED2
PULSOUT srvonk, 750
NEXT
RETURN
lookdn:
DEBUG CLS, "Look Down"
FOR j = 0 TO 50
PULSOUT srvonk, 750
PULSOUT srvohd, 1200
PAUSE 20
NEXT
GOSUB PING
DistanceD = cmDistance
RETURN
lookU:
DEBUG CLS, "Look UP"
FOR j = 0 TO 50
PULSOUT srvonk, 750
PULSOUT srvohd, 350
PAUSE 20
NEXT
RETURN
fwrd:
DEBUG CLS, "Look Forward"
FOR j = 0 TO 50
PULSOUT srvonk, 750
PULSOUT srvohd, 650
PAUSE 20
NEXT
GOSUB PING
DistanceF = cmDistance
RETURN
lookL:
DEBUG CLS, "Look Left"
FOR j = 0 TO 50
PULSOUT srvonk, 1200
PAUSE 20
NEXT
GOSUB PING
DistanceL = cmDistance
RETURN
lookR:
DEBUG CLS, "Look Right"
FOR j = 0 TO 50
PULSOUT srvonk, 325
PAUSE 20
NEXT
GOSUB PING
DistanceR = cmDistance
RETURN
' START Drive the Wheels * * * * * * * * * * * * * * * * * * * * * * * * * **
stepF:
DEBUG CLS, CR, "Step Foward ... ", DEC distanceF
IF distanceF < 10 THEN GOSUB stepR2
FOR j = 0 TO 89
PULSOUT wheelL, 800
PULSOUT wheelR, 700
NEXT
RETURN
stepB:
DEBUG CLS, CR, "Step Back ... ", DEC distanceF
FOR j = 0 TO 199
PULSOUT wheelL, 800
PULSOUT wheelR, 700
NEXT
RETURN
stepL:
DEBUG CLS, CR, "Step Left ... ", DEC distanceL
'IF distanceL < 10 THEN GOSUB stepR
FOR j = 0 TO 89
PULSOUT wheelL, 700
PULSOUT wheelR, 700
NEXT
RETURN
stepR:
DEBUG CLS, CR, "Step Right ... ", DEC distanceR
'IF distanceR < 10 THEN GOSUB stepL
FOR j = 0 TO 89
PULSOUT wheelL, 800
PULSOUT wheelR, 800
NEXT
RETURN
stepR2:
DEBUG CLS, CR, "Step Right2 ..."
FOR j = 0 TO 89
PULSOUT wheelL, 800
PULSOUT wheelR, 800
NEXT
FOR j = 0 TO (3 * distanceF)
GOSUB stepF
NEXT
RETURN
' END Drive the Wheels * * * * * * * * * * * * * * * * * * * * * * * * * * **
' START Closest Object to Move Towards Until TOO Close. * * * * * * * * * * *
closest:
DEBUG CLS, "CLOSEST", DEC cmDistance
IF (distanceF < distanceR) AND (distanceF < distanceL) THEN stepR
IF (distanceR < distanceF) AND (distanceR < distanceL)THEN stepR
IF distanceL < distanceF AND (distanceL < distanceR)THEN stepL
RETURN
' END Closest Object to Move Towards Until TOO Close. * * * * * * * * * * * *
PING:
'DO
FOR i = 0 TO 9
PULSOUT PINGR, 5
PULSIN PINGR, 1, time
cmDistance = cmConstant ** time
inDistance = inConstant ** time
DEBUG HOME, CR, CR, DEC3 cmDistance, " cm"
DEBUG CR, DEC3 inDistance, " in"
PAUSE 100
NEXT
'LOOP
RETURN
END
' START SONY TV IR remote variables * * * * * * * * * * * * * * * * * * * * *
irPulse VAR Word ' Stores pulse widths
remoteCode VAR Byte ' Stores remote code
'IR PIN 7
DEBUG "Press/release remote buttons..."
DO ' Main DO...LOOP
remoteCode = 0
DO ' Wait for end of resting state.
RCTIME IR, 1, irPulse
LOOP UNTIL irPulse > 1000
PULSIN IR, 0, irPulse ' Get data pulses.
IF irPulse > 500 THEN remoteCode.BIT0 = 1
RCTIME IR, 0, irPulse
IF irPulse > 300 THEN remoteCode.BIT1 = 1
IF irPulse > 300 THEN remoteCode.BIT2 = 1
IF irPulse > 300 THEN remoteCode.BIT3 = 1
IF irPulse > 300 THEN remoteCode.BIT4 = 1
IF irPulse > 300 THEN remoteCode.BIT5 = 1
IF irPulse > 300 THEN remoteCode.BIT6 = 1
' Map digit keys to actual values.
IF (remoteCode < 10) THEN remoteCode = remoteCode + 1
IF (remoteCode = 10) THEN remoteCode = 0
DEBUG CLS, ? remoteCode
LOOP ' Repeat main DO...LOOP
' END SONY TV IR remote variables * * * * * * * * * * * * * * * * * * * * * *
END
C U L8r, ...
