Resisted the inevitable for too long - scope purchase time.
Greetings!
I've now had two of my supposedly digital-only designs fail due to analog noise / levels issues that my current analog scope is not accurate / functional enough to diagnose.
From everything that I've read the Rigol scopes seem to have a good reputation. Really I looking for the analog equivalent of my saleae.com logic analyzer.
As well as being able to watch the world go by live I'd also like to be able to store, navigate and zoom through triggered events.
Budget is hard to swing right but 400 is the initial swing, but if doubling that will mean I don't have to re visit the purchase for a significantly longer time I may be able to swing it.
I keep looking at many contradicting reviews on the subject of USB scopes like the Picoscope. Thoughts?
Red
Red
Bean
If the budget can swing it, 4 channels would always be my preference.
DS1074Z at $585
Duane J
HP 1707B.
It's on its last legs. Connecting to the 1V 1khz "calibration" source and after 10 or so minutes the wave becomes less square and more "half-wave rectified" and the amplitude varies by unpredictable amounts.
I don't know which to distrust, the calibration osc or the scope itself. It also has **horriffic** astigmatism which is outside of the range of the astigmatism pot to fix.
I filmed this last night analyzing the modulation of a chain of WS2812s direct from a propeller. You can see that it's hardly a square wav.
http://www.eevblog.com/forum/testgear/
http://www.youtube.com/watch?v=_TSr9nFN1GU
Can't comment on those specifically - I have their Logic analyzer only, but I have the DS1102E which I'm happy with.
Certainly more than I need right now but something I'll grow into.
Red
4 channels seems to be a lot. Haven't seen any 4 channel scopes here.
For setting a budget, just consider how many hours you spent fixing the earlier problems...and what that time was actually worth.
Bet it was worth more than $400.
Have you considered renting a scope for a few weeks to finalize your design?
