Programming Prop over RS232
I have followed these two threads in order to implement programming of the Prop via a MAX3232 chip.
http://forums.parallax.com/showthread.php/84909-Serial-link-via-MAX3232-IC
http://forums.parallax.com/showthread.php/84805-Propeller-Serial-Programming-Adapter-Testing/page2?p=581926#post581926
My problem seems to be that the implementation of the DTR line from the output of the MAX3232 via the NPN transistor is not working correctly. So I the ability to reprogram only works intermittently if at all.
If I use the Parallax Serial Terminal and tick the DTR box then the prop resets on release of the DTR line but the unit then sends strange characters to the terminal before the system boots properly. If I do the same with the FTDI USB prop plug then there are no strange chars.
Am I doing something wrong?
Cheers
Helen
Cheers
Helen
Do you have the "BOEn" pin tied to ground, which is the normal configuration? This action changes how the reset pin is configured, from memory.
I'd suggest looking at PhiPi's Propstick design, that had the MAX3232 and reset transistor. I've put Propsticks all over the place using RS232 and they've always worked well.
It'll be something simple.
http://elmicro.com/files/parallax/propstickkit-v12.pdf
I have used the transistor schematic with great success.. even adapted the whole to be a reciever for RS485 over 100' of wire. There are several adaptations of the how to wire that RTN. Phil's may serve you better.
Cheers
Helen
