What is the current best graphics display? — Parallax Forums
lmclarenlmclaren Posts: 104
edited 2014-04-16 13:42 in Propeller 1
A bit more information.
I currently have a coffee roaster running in a single prop that is using the VGA64 Tilemap Engine, it works very well but I am out of space with all of the other parts of the code.
I have decided to split the project into a two prop design, one will do all the control and automation, the other will do the display.
The current display offers colour per character and a single font.
What I would really like, is at least 2 fonts, colour per character and an area I can do a per pixel graph on.
I don't mind if the display prop uses all of the cogs and memory, as long as I have a little left for a serial connection to the control prop.
Is there such a thing? I know when the next prop arrives it should become a lot easier. I did consider using a raspberry pi to do the display but I prefer the fast start-up and reliability of using props.
Lee
Current Display
    edited 2014-04-13 14:03
    I am not aware of any single driver that will do what you want, but it might be possible. It really depends on the exact details of the look and positioning of the two fonts and pixel graphics. If you post details of the screen layout you may get more help.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2014-04-13 17:21
    VGA.spin or VGA_<resolution>_tile_driver_with_cursor.spin would probably be best. They both work the same way, one just has a higher resolution, takes more than 1 cog, and optionally can have a cursor for a mouse. You can set up part of the screen to point to a bitmap buffer. If you want a second font, you'll have to store it in ram and load it with a DAT block full of "long %%data". I attached a spin file that uses vga.spin and graphics.spin to do graphics and text (if it works), but it only has one font (no, wait, there's the graphics font! But you only want that if you want text on your graphics). It will overwrite your graphics area with text if you're not careful. I don't have a propeller I can hook up to a VGA monitor right now to test it, but it does compile. If someone else could test it, I would greatly appreciate it.
    electrodude
    EDIT: fixed a bad bug
    new part:
      'init tile screen
      repeat dx from minx to maxx
        repeat dy from miny to maxy
          screen[dy*vga_hc+dx]:=display_base>>6 + (dy-miny)+(dx-minx)*gr_y_tiles + (17<<10)            'base>>6 + index + color<<10
  • lmclarenlmclaren Posts: 104
    edited 2014-04-13 20:32
    Thanks Electrodude,
    I will put it through its paces tonight and report back.
    Lee
    edited 2014-04-14 04:41
    Hi Electrodude,
    I tested the version you attached, it showed some promise but there was some text overwriting and it only filled about 50% of the screen area in the centre but a good start, thankyou.
    I tried your suggestion to use one of the other tile drivers, VGA 1280x1024 Tile Driver w/Cursor with the graphics addition. I am having a few problems and need to spend some time to understand it.
    I will report back how I go.
    thankyou for putting me on the right track.
    Lee
  • RaymanRayman Posts: 16,248
    edited 2014-04-14 05:00
    Using the build in tile drivers is the simplest approach...
    If that's not good enough, I have some SSD1963 based boards that can do WVGA fullscreen graphics.
    Still, if most of you display is text and you just need a tiny graphics area, the tile driver is the way to go.
    edited 2014-04-14 06:32
    It worked? A miracle! That was probably the only thing I ever wrote that was more than 30 lines that worked without having to fix something.
    Vga_1280x1024_tile_driver_with_cursor.spin works the same way as my example - just get rid of the vga params in the var and dat blocks (leave colors!), and start the new vga object with vga.start(16, @screen, @colors,0,0,0). You might not want the first two of the last three zeros in that line to be zero, read the vga object's start method's comments, it will tell you. You probably want the last parameter to be zero, because it gives better control over the screen (16x16 instead of 16x32). Make sure you change x_tiles and y_tiles to equal vga#xtiles and vga#ytiles.
    About the overlapping text, replace
        'display some text
        txt_x:=0
        txt_y:=1
        dec(i++)
    with
        'display some text
        txt_x:=0
        txt_y:=2          ' each character is 2 tiles tall!
        dec(i++)
    Each character is 2 tiles tall, but I only moved the cursor down 1 tile for the next line; move it down 2 tiles instead.
    Notice that you can change xmin, xmax, ymin, and ymax to change the size of the graphics area in 16x16 tiles.
    Also, try changing the graphics colors (last actual line of code in the file) to something else like
    long    %%3000_3000_0030_1110   'graphics
             'rgb  rgb  rgb  rgb
    to give the graphics area a different background color so you can tell it apart. The first 4 digits are the color you get from gr.color(3), the next 4 from gr.color(2), the next 4 from gr.color(1), and the last 4 from gr.color(0). Gr.clear fills the screen with color 0, which is grey with this modification and not black. That leaves the text background as black.
    Did you find the graphics font thing yet? It's gr.text(x, y, strptr). I left some setup code in my file (the gr.textmode(3,3,6,%0101)), so you should just be able to put a gr.text somewhere and it should work. Notice that (0,0) is at the center of the graphics area. To change that, change gr.setup(gr_x_tiles,gr_y_tiles,gr_x_tiles*8,gr_y_tiles*8,bitmap_base) to gr.setup(gr_x_tiles,gr_y_tiles,0,0,bitmap_base). That will put the origin at one of the corners - I suspect it might be the top left, and y coordinates will have to be negative. If you want the origin at another corner, just mess with those two zeros - they determine where the origin is.
    electrodude
    EDIT: You probably don't want vga_1280x1024_tile_driver_with_cursor.spin because it's such high resolution that you'll only be able to have a tiny graphics area.
    To make VGA.spin take up the whole screen, change vgaparams in the DAT block to read:
    vgaparams               long    0               'status
                            long    1               'enable
                            long    %010_111        'pins
                            long    %0000           'mode
                            long    0               'videobase
                            long    0               'colorbase
                            long    x_tiles         'hc
                            long    y_tiles         'vc
                            long    1               'hx
                            long    1               'vx
                            long    0               'ho
                            long    0               'vo
                            long    512             'hd
                            long    10              'hf
                            long    75              'hs
                            long    43              'hb
                            long    480             'vd
                            long    11              'vf
                            long    2               'vs
                            long    31              'vb
                            long    20_000_000      'rate
    and make x_tiles = 32 and y_tiles = 30. It's also not a bad idea to add "vga_rate := clkfreq >> 2" to the line before vga.start in PUB start, in case you're not using an 80MHz clock. These new settings were slightly modified from VGA_Text.spin.
    I attached the updated file. It might not display anything, though, because I'm not sure your monitor (or anyone's) will understand a signal using those vgaparams. I'll be able to test it later today.
    I edited this post many times, so beware.
    edited 2014-04-15 03:00
    Thankyou again,
    I have had a chance this afternoon to spend some time with the display, the original had a few small problems (but far better that I would have managed in under a week!) The character text was only showing half a character and there where some stray characters instead of blank screen, I made some tweaks as per the first lot of code attached which was closer.
    A bit more thinking and a few more tweaks and I had the result now shown in the second photo.
    I am not sure if I have accomplished this in the best way but I think I can get this to do what I want.
    I think I will use the graphics area at the bottom for a graph to show the temperature and will try to add a smaller font for the majority of the display with the standard being the big font for the main temperatures.
    Thankyou Electrodude, I would not have got this far without you assistance.
    The 2 version is the first
    VGA_graphics_text_mix (2).spinVGA_graphics_text_mix (3).spin
    edited 2014-04-15 13:18
    I finally got a chance to hook up a propeller to a monitor, so I could actually fix some bugs.
    I saw you had a gr.colorwidth(10,2). Color 10 is invalid - you can only have 4 colors (0,1,2,3) in graphics mode per 16x16 area. You would set the color set used by a tile in the init tile screen section by replacing the 16<<10 (I accidentally put 17!) with (colorset)<<10. If you need to change a color set while running, you would simply re-init just that tile. The color sets are at the bottom of the file.
    I changed the graphics origin to the bottom-left, which is probably what you want. Notice the extra zeros in gr.setup - they pick the origin. I also changed the graphics text mode to be bottom-left justified (instead of centered horizontally and vertically), and made the text smaller (the ones in gr.textmode change the size and the 00 changes the justification).
    You took the graphics text stuff out of the loop, but it has to be in the loop or it will only get drawn once if you continue to use double-buffering and redraw everything every frame. You could consider only single-buffering the display, which would take half as much memory, but then you would have to worry about drawing deltas, which is a headache you want to avoid at all costs.
    You had a bunch of off-by-one errors, I fixed them. I also modified the text functions so you could use 16x16 tiles instead of 32x32 tiles.
    I added 2 bar graphs as an example of how to make things that update.
    electrodude
    edited 2014-04-16 05:37
    It is a thing of beauty!
    I have ran it up and it is working well, I will spend a lot more time on it tomorrow.
    I may investigate using a different font, if I understand correctly, I could use a non internal font and then get twice as many characters? Is that correct? Could I mix and match?
    Sorry for so many questions.
    many thanks
    Lee
    edited 2014-04-16 13:28
    Your welcome! I'm happy to hear its working! Yes, you could use your own font, just store it in DAT sections the same way the internal font is stored. You could also have your own graphics font, using gr.pix or (preferably) gr.vec. However, unless you have a really small graphics area, you probably won't have enough ram for that. You could try single-buffering the display - it's not as bad as I previously said - to get half of your ram back, but it can be scary if you don't pay really close attention when you write your code (unless you like displays that flicker or have lots of artifacts).
    It is possible to have multiple graphics areas, although I've never tried it. They should all use the same backbuffer to save ram. You would have one back buffer (bitmap_base) for everything and then one front buffer (display_base) per graphics area. This would be easiest if all of the graphics areas were the same size, otherwise you would have to run gr.setup between areas. This would save lots of ram because you only have a backbuffer for part of the display and not all of it.
    gr.clear   'clear bitmap_base
    'draw stuff for first graphics area here
    gr.copy(display_base1)   'copy bitmap_base to display_base2
    'draw stuff for second graphics area here
    gr.copy(display_base2)   'copy bitmap_base to display_base2
    electrodude
    Thanks, I go on leave from my day job for the next few weeks so will have some time to get my teeth into this.
    Thanks for the help, it would have taken me ages to get this far and a lot of frustration.
    best regards
    Lee
