Need help on decoding a program for a Propeller project.... — Parallax Forums
jknightandkarrjknightandkarr Posts: 234
edited 2014-04-10 00:12 in Propeller 1
Does anyone here know the Motorola 68HC11 programming language? I'm trying to decode a project so I can start a propeller based version of it. The project is actually the Chevy TBI ecm for my 89 305 TBI Trans-Am and I need to create a working Propeller version of the ecm before I can go farther and where I want with my project. I have the ecm program itself as well as the calibration file, but I'm having trouble trying to learn the language at all, so I can learn what all math the ecm does with the Cal. Data to control the engine.
Joe
  • sidecar-racersidecar-racer Posts: 82
    edited 2014-04-09 09:48
    Joe,
    The best way to start is to get a manual for processor (68HC11). Figure out where start of program is and create a flow chart of program. One approach could be to write a "disassembler" that would take the object code from 68HC11 and create the program and data flow.
    Any questions from this vague, let me know. I've done a few of these in the long past :), they can be a challenge.
    Rick Murray
    edited 2014-04-09 10:01
    Joe,
    Took a quick google, manual is not a problem. Also you need to trace every i/o pin to determine what's being read/controlled (and what kind of electrical interface is needed). Such as FI drivers, cam and crank timing, etc. If any A/D involved, then external circuits for prop are needed.
    Looking a 68HC11 specs, shows 8K of ROM, is there another ROM chip in ECU (seems small, Denso ECUs are 256K to 384K)?
    It looks like 8 A/D channels, external chip likely required for prop. I/O count seems good.
    Prop speed and 32 bit data will be a plus (68HC11 is 8 bit and much lower clock speed)
    What budget do you have?
    Rick Murray, PE
    RGM Engineering
    edited 2014-04-09 10:20
    Here is one disassembler software solution, there maybe others.. try a search
    http://www.retro.co.za/disasm11.html
    Seems to need DOS, but you can get FREEDOS to boot from a CD. Maybe a LInux version as well.
    And go here for more support.
    http://www.faqs.org/faqs/microcontroller-faq/68hc11/
  • jknightandkarrjknightandkarr Posts: 234
    edited 2014-04-09 12:31
    I already have the manual, but no direct source code, just whats already been disassembled, I can read the file but I'm having a hard time understanding it. What is a data flow chart?
    I can do the tracing, but some of the circuits I have no clue what the IC chip's are. It could take awhile. I figured the Prop could run like 50 to like 33 times faster then the GM unit. The 68hc11 seams to run either 2 or 3 Mhz, so the prop with its 8 cores can get data, perform calcs & outputs much faster then gm unit, though i figured I'd use multiple props n network em togeather.
    Thanks for the links, I'll have to check em later, time for work.
    Joe
    edited 2014-04-09 13:53
    Joe,
    A data flow chart is a pictorial version of how the code works; Let's say you find the starting location of program (ei Hex 100), first instruction is to jump to another location, you then go to that location and determine what that instruction is doing; ie a test of a pin status, then the program goes one way if pin is high and another way if pin is low. The program may reference a memory location and use the number(s) for a math function (ie; FI duration=preset mixture and throttle position and rpm). Not a simple job. You need to understand the code AND the function of the box. If the original code was written is assembly (unlikely in today's world), reading it won't be too bad. Normally the code is created with a compiler; C, etc. and can be very weird.
    edited 2014-04-09 23:02
    I forgot the budget, Right now, just planning, but when I build, it's going to be I'll get stuff as I can. I think I understand what you mean on that. I've started by making a list of the EQU what I think are Named Lables that are directed straight to a hex address ranges $00 to $FF, I'm going to try n figure out what the named lables are, but they just listed starting L0000 & increasing. All while trying to get math formulas & table addresses & then move onto the code itself.
    Joe
  • cavelambcavelamb Posts: 724
    edited 2014-04-09 23:52
    It's a really cool old antique chip.
    But this is a seriously serious job.
    And you are in over your head, you know?
    Print out the disassembled files and tape them to the wall.
    Get your box of multi-color highlighters and go at it.
    Search the machine readable file to locate references and mark them on the paper.
    Identify all I/O pins. There are some options depending on the model. So this could be a trip.
    Also the pins themselves can be in or out depending on how they are initialized.
    Some of the external circuitry can be identified by how the software interacts with it.
    That might tell you something useful.
    Identify important memory references.
    See which memory locations are related to what I/O pin usage.
    Tables are often accessed by index (offset) reference.
    Check the use of the X and Y registers (16 bit).
    On-Chip ram is from 0000 to 00FF (256 bytes)
    Special registers from 1000 to 103F
    ROM or EEPROM options depending on the specific model of the ship.
    Identify that first.
    If it has 2K EEPROM that will be located F800 to FFFF
    Otherwise probably just 512 bytes of EEPROM from B600 to B6FF
    FFC0 to FFFF are reserved for interupt vectors.
    Rice University -
    https://www.clear.rice.edu/elec201/Book/6811_asm.html
    From time to time I have been involved in converting old assembler programs into a higher level language so that they can be compiled to run on different machines.
    For example one project wast to make a C version of some control code written in 8080 assembler. Even starting from the original source code this took myself and another guy, working full time ,over a year to get working!
    That was a simple case. When you have to figure out what is going on with on chip timers, external logic, interrupts etc etc and don't have the original source code things get exponentially more difficult. And it get's increasing harder to know if your recreation actually does what the original did correctly.
    I would not dream of taking on a job like this as a hobby project unless I was at least twice as nerdy as I am and had nothing else to do for a year or so.
