Bezel for the uLCD32-PTU
4D has just come out with a slick bezel for the 4.3 and 3.2" displays. The online cost is $9.99 BUT the shipping cost is $32.00 !! Insane !! Seeing as you guys carry the display can you also carry the bezels?? I have the display, I love it, and could really use a bezel to dress it up. I'll do with out though before I pay $32.00 shipping for a 9 dollar piece of plastic.
Mike B.
Mike B.
It seems we don't sell enough quantity in the displays to justify carrying accessories for the. I apologize, but the powers that be know best. Nonetheless, thanks for your suggestion! :thumb:
OK Chris. I found out why the shipping i8s so expensive from 4D direct, they're in Auzzie land down under !! I bought one from Mouser and should be here tomorrow..
Thanks for the effort anyway..
Mike B.
I got the bezel today (ordered it Monday !) and the display looks great in it. Mouser and Sparkfun both carry the bezels....
Mike (the happy camper) B.
If you get a chance and don't mind, could you post a picture of your setup? Looking at the raw bezel on the 4D site didn't really give me an impression of how it would look in a finished product.
OK Chris, I'll try and get the display mounted this weekend and take a pix of the display with my "splash" screen.. Probably won't be until Sunday as I am gearing up for another high altitude balloon launch from Western Carolina University... ( Saturday the 22nd @ around 0800 local EDT. Here's the link to the track for Saturday. K4WCU-11 is the balloon.
http://aprs.fi/#!mt=roadmap&z=11&call=a%2FK4WCU-11&timerange=86400&tail=86400
I'm one of the mobile trackers and recovery vehicles. )
Mike B.
Hop[e this is good enough for you purposes, if not let me know and I'll try and get a better picture
Mike B.
Ok, Chris. I'll try and get a better picture... Got to cut an opening for the thing to sit in. I'll try that here in a bit after lunch..
Mike B.
OK
Note: remove the .TXT extension on the STL file and it should be ready to import.
OK Chris, my pleasure. If you want to see the back side of the display I'd be happy to post another picture. The display screws to the bezel with four screws into 4 brass inserts with real screws and the bezel mounts into the panel with four spring clips that screw into for other brass inserts. It will mount into a panel up to 1/4" thick.
Let me know if you want the back side picture...
Mike b.
OK Beau. I will get the picture uploaded this evening as I'm off to work right now. By the way, what's a STL file?? Something for a 3D printer??
Mike B.
Reference:
http://en.wikipedia.org/wiki/STL_%28file_format%29
OK thanks Beau, I kinda thought that might be the case.
Here is a picture of the back side of the display mounted in my enclosure....
Let me know if you guys need anything else.
(P.S. Chris: How about a general purpose object for the VISIGenie display??)
If it would help in what ever you are trying to do I'd be happy to take a picture of the back side of the bezel without the display mounted so you can see the brass inserts.
Mike B.
The screw hole diameter is 2mm and should be able to accept a screw as long as it does not exceed 5mm in length.
Note: remove the TXT extension from the STL file.
Note: As far as a cutting template, all you need is a rectangle that is 100mm x 60mm where you want the display. The bevel provides a clearance of 4.4mm on the short ends and a clearance of 4.8mm on the long ends
