I Want To Say Good Bye To A Good Friend
I want to say good bye to my drill; it died today. It was the first drill I bought. I got it when I was in my teens; so it died around the age of 45 years old. It was all metal and it was a work horse. It went from a hand drill to being a drill press drill. No play in the chuck not like the drills of today! I had hand drills come and go but this one keep on going. If I remember right; I paid less then $10 for it. Sad to see you go old friend!
Al
Al
Worn brushes can be replaced.
I have a cool Black and Decker from the thirties with a 45 degree angle head.
Stole it in a garage sale once. Needed some care, cleaning, and lubrication.
Duane J
I wish, no the gear went. I opened it up just to make sure.
Al
Wow, never heard of such a thing! A drill of a rather different sort saved me once. A fallen tree had blocked my path. All I had was a .44 and a sack of reloads. It worked well.
I'm stashing this one away. I have occasion to remove trees in locations where a .44 wouldn't be welcome. Chain saws are high maintenance and they leave more of a stump than your method. And since you already have the drill out, you could just bore a few additional holes into the stump for some KNO3 (stump remover).
Hi:
I did see my drill on ebay but it didn't look in to good of shape. You have to remember that; that drill will also be around 45 years old. It just goes to show you good drills can be made for low cost IF they wanted to make them!!! Not like the junk they make now. I have a B&D drill I have only used a few times. I used it to take out a screw and I felt something snap in the drill and then I see the chuck fall off. So now it can only be used to drill (it can only go cw now or the chuck falls off).
I bought a small drill press. It was so badly made that just moving the belt to get a higher speed cause the motor not to spin. So I only used it on low speed and with small drill bits. Only after a few months the belt ripped apart. They wanted $19 for a new belt. I didn't want to spend $19 on a belt for a drill press that didn't work well to start with. Since I had nothing to loose; I glued two layers from a waist band from old underwear together and made a belt for the drill press. It's been working like that for about a year and a half now. What does that say about how things are made if a belt made from underwear can out last a belt that was made for the drill press!
Al
