Help me test some video formats (Mac and mobile)
GordonMcComb
I'm experimenting with video encoding settings for a project I'm working on. Mobile devices, especially, have difficulty decoding MP4 videos that desktop computers show with ease. This has to do with the parameters selected for encoding.
For those of you with Apple iPad, Apple 4 or 5 phone, Blackberry, and Android phones and tablets, if you have a moment could you test two short test videos at the following to see if they will play?
http://www.gmccomb.com/vids/
You should see picture and hear sound. The encoding bitrate is fairly low, and the original video is from a 20 year old 8mm tape, so the image quality isn't HD. However, please let me know if you see excessive "tearing" or jumping in the picture.
Also, I need to double check that they'll play under Quicktime on a relatively new Mac (OSX 10.8 or later). There's no reason I can think of that they wouldn't, but my Mac has an earlier release of OS X, and I'd like to make sure.
Thanks.
Thanks.
First play of first video, sound started before video started but it wasn't out of sync. No significant tearing or jumping that I noticed.
Second video nothing unusual noted.
There were a couple tears (not terrible) during the first 6 seconds or so of each - after that, I didn't see any. I didn't play them side by side but the quality was about the same on both.
Replay of first video, sound and video started at the same time.
This was all through Firefox - the videos started in the browser when I clicked on them.
On a MacBook Pro 17", OS x Mavericks 10.9.2 (latest), they play fine.
They also play fine on the latest iPad Air and iPhone 5.
Like you said, the quality isn't all that great, but there was no problem playing the videos.
I use Permute to encode all my videos. It has settings for iPads and iPhones and Apple TV. Don't know if there is a Windows version of it or not.
Kenny
You can tune all the options and it can make very small, high performing mobile friendly videos. I've used it for some projects that ended up on mobile. If you are interested in small sizes, this one packs quite a punch.
I will sometimes render the video with something mor capable as a production tool, then run it through Expressions to distill that down to mobile sizes.
Just FYI. My basic rule is 3-5 mins = 20Mb = fits in an email...
Kenny, in order to play on older iPhones and some earlier Android phones I have to use MP4 Baseline 3.0 profile, which reduces quality somewhat. Later phones can handle Main profile, which increases compression so you can effectively get more bits in there. At some point I'll probably add some server-side junk to detect the version of iOS and Android, and serve separate videos depending on the level of profile support.
The problem with Adobe Media Encoder -- the tool that I use -- is that while they have presets, they often don't work with older devices and they don't tell you why. But that's Adobe for you. I'd get Permute, but my Mac is an older G4 and won't run the software.
They both ran on a Android Samsung Galaxy Note 10.1 Tablet with no problems. As a matter of fact you could say it was child's play.
Agreed, it's very good. The encoding engine is basically from Windows Media Encoder, which I have and use from time to time. I've lamented MS's decision to move to encoding as a service, ending development of Expression Encoder. I guess that's the way of things these days.
Jim
OS: Android 4.1.1
Player: MX Player
Video had some horizontal lines (2 to 3 times) showing up for a very short while & quality a little jerky. The bottom horizontal line (about 1mm) is out of alignment.
Yeah, that's to be expected. My general site, which is on an inexpensive shared host, can't sustain 1 mbps video playback at peak times. If another site (of the 100+) on the host is very busy, throughput will be highly degraded. The videos will stream from a dedicated server and/or CDN, eventually.
Kenichi, the bottom of the screen is head switching noise on the original tape, fairly common in older 8mm recorders. This one dated back to the early 1990s. I still remember the horrendous amount of money I paid for it. Never be an early adopter...
Thanks, again, to everyone who has responded. Looks like these profile settings are working pretty well across devices.
