Navigating with GPS
Does anyone have any code they will share to navigate from a current location to another with GPS? I've got my Stingray receiving strings from one of the GPS receivers from parallax. I don't really know where to go from there. Any example would be greatly appreciated. Thanks, jim.
http://forums.parallax.com/showthread.php/128884-integer-only-GPS-navigation-object
I assumed the Earth if flat, and used scaled integers only.
Erco pointed me to the Flat Earth society, in case you are interested :-)
If I remember correctly XTE was not working well, everything else proved good so far.
If you search the forum there are other posts and objects on the same topic with various approaches..
Massimo
