Driving control lines with capacitance, do I need a buffer/driver?
I'm driving a Toshiba TCD1304AP CCD with my propeller, it seems to work OK, but I wonder if some glitchy behavior might be related to the capacitance of the control lines... I've read about this before with regards to switching losses in MOSFETs, but I imagine it could cause glitching if the slew rate was too low or something else maybe. The datasheet shows drivers/buffers, but I don't know how to figure out if the GPIO are just fine for driving these CCD control lines.The lines are:
MCLK typ 10pF
SH typ 600pF
ICG typ 250pF
How can I use this information? It must be given in the datasheet for some reason. right?
P.S. the datasheet doesn't mention slew rate or rise time, but the MCLK freq is between 0.8 and 2.4 MHz, and the SH is a 50% duty cycle pulse with a max freq of 100KHz... ICG is just a once-in-a-while pulse, with edges about 5 or 10 microseconds between them.Thanks!
MCLK typ 10pF
SH typ 600pF
ICG typ 250pF
The SH typ 600pF could be a problem.
The ICG typ 250pF maybe.
The best way to evaluate this would be use an O-Scope and measure the transition times.
A rough estimation can be made using the Prop pin source and sink currents.
Looks to be at least 20mA.
So Time = C*V/A = S
Lets say you need s change of 3V:
10pF * 3V / 20mA = 1.5nS
600pF * 3V / 20mA = 90nS
250pF * 3V / 20mA = 38nS
This is quite a crude calculation but should be in the ball park.
Duane J
