Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Propeller_Board of Education VGA connection — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Larry Sutherland
77
2014-03-16 20:49
edited 2014-03-17 08:07
in
Propeller 1
Is there any info for connecting BOE to a LED monitor TV? Going thru Propeller Tutorials help and at Chapter 9.
ericball
774
2014-03-17 08:07
What inputs does the TV support? I'm assuming it doesn't support VGA, because the BOE has a VGA port. In which case you can use the breadboard area to connect build the 3 resistor DAC with an RCA jack for composite output. See
http://www.parallax.com/sites/default/files/downloads/32100-Propeller-Demo-Board-Schematic-RevG_0.pdf
for the standard wiring.
Sign In
Register
to comment.
