Decimal to hex conversion and beyond
What the program below does is converts a decimal number to hex, and then converts the hex back to a decimal number, verifies that the conversion is correct.
What I really want to accomplish is convert feet to mm, convert it to a hex, convert upper byte and lower byte back too decimal contained in separated variables. As an example:
6' * (12*25.4)= 1828 mm
7 24 - conversion to hex
7 36 - conversion to decimal
upbyte = 7
lowbyte = 36
The problem that I am having is splitting the 724 into 7 and 24 for conversion back too decimal. I looked at the printf docs, and it shows '*' too declare how many characters to display, but I am not sure how that would apply too what I want too accomplish. Any help would be appreciated.
Ray
upbyte = 7
lowbyte = 36
Ray
/* dectohex.c */ #include "simpletools.h" int main() { // Add startup code here. pause(1000); //dec to hex char outStr[256]; int inDec; inDec = (6 *(25.4 * 12)); // Calculates feet to mm. sprintf(outStr,"%X",inDec); printf("%d in hex is %s\n",inDec,outStr); // Convert hex back to dec long int numValue; numValue = strtol(outStr,NULL,16); printf("decimal value %d\n",numValue); while(1) { // Add main loop code here. } }
low byte
(variable & 0xFF)
high byte
(variable >> 8) & 0xFF
Are you making a table for inclusion into a C program or a human readable table?
The computer cares not what radix you use, if you split a 2 byte value into a high and low table, it's a byte either way.
Why do you want to convert radices?
This code converts the input into a upperbyte and lowerbyte variable.
When I do the conversion of 1828, I get a hex value of 724, I guess each value of 724 is a byte, so, in the program, right now, I capture the 2 and 4 values. What I need to do is capture the x24 or the first two values as the lower byte, the next two values xx7 as the upper byte. Sorry for the wrong information. When I start to do some negative conversions like (-1828), then the hex values will be something like (...FFFFFF8DC), so in this case the upper byte will be F8=248 and the lower byte will be DC=220, I hope this not too confusing.
Ray
You are working on the micro level and trying to diagnose micro problems.
Describe at the macro level what you are trying to accomplish, because what you've discussed so far sounds way off in left field.
opcode: 156
serial sequence:[156] [Distance high byte] [Distance low byte]
Distance data bytes 1-2: 16-bit signed distance in mm, high byte first (-32767 - 32768)
Example, 40 cm travel: [156] [1] [144]
There are at least five other commands that use this format, so I will need this to be automated within the C control program that I am working on. For the time being I am doing a manual calculation for the values needed, but as this project moves along, and I decide too keep pursuing this, I will have too automate.
At the moment I am testing too see if this would be a good choice for an autonomous robot. At the moment I am using the PropBOE board because I can pick up 18V @ 1.5A power source, from the robot, which would be sufficient to power a Raspberry Pi, via the PropBOE, for an additional processing source. I still have a lot of testing to do before I can make a decision as to whether this robot could be used. So, as you can see, I can use all the help I can get on this one.
Ray
I think I came up with a solution, by accident of course, but first can somebody explain to me the magic of 'variable & 0xFF' and (variable >> 8) & 0xFF'. For instance if I use a variable like 255 then I get, high byte- 0, low byte- 255, but if I use 256 then I get, high byte- 1, low byte- 0. What kind of black magic is this?:-)
Ray
if you use 16 bits to represent it, 255 decimal is 0x00FF and 256 is 0x0100 - now do your masking and shifting
variable & 0xff is 0x00ff & 0xff yields 0xff which is 255
00FF
00FF
AND
00FF
with variable = 0x0100, (variable >> 8) gives you 0x0001 in variable, then variable & 0x00FF give you 0x0001
0001
00FF
AND
0001
It's not black magic, just how binary and logical operators work and in this case you are using hexdecimal, so you work in 4 bit nibble for each hex digit, you can work in binary or octal if you'd prefer.
Ray
* Shift the high byte left 8 times
* OR the high and low byte.
1 << 8 = 0x0100
0x0100 OR 0x90 = 0x0190 = 400
If this is a correct interpretation of getting the high byte and low byte, and then reversing the process to get the original number back, I have not seen this done in Spin, maybe a Spin expert could show how this would be done in Spin?
Ray
Shifting a base2 number to the left one time is the same as multiplying by 2.
%0010 (2)
%0100 (4)
Shifting a base2 number to the left 8 times is the same thing as multiplying by 256. In post #10 we could have multiplied by 256 instead of shifting.
%0000_0000_0000_0001 = 0x0001 = 1
%0000_0001_0000_0000 = 0x0100 = 256
Shifting a base10 number to the left is the same as multiplying by 10.
05
50
Ray
