Gentleman Seeks 1PPS
tomcrawford
I just purchased a used hp5316B Universal Counter. It works fine and seems stable but I don't know what the absolute accuracy is. I would like to calibrate it by measuring a very good, preferable NIST-traceable timebase. If anyone in the Sacramento area has, say, a GPSDO 1PPS that I could bring my counter to, I would like to hear from you.
Tom Crawford
Tom Crawford
The best, and probably cheapest, way to get 1ppS pulses is from a GPS.
Not all supply this.
You need one that has a dedicated 1ppS pin on the connecter.
Some are better than others. However, all have a long term very high accuracy.
Way better than the oscillator in the counter.
BTW, I have one of those counters. I like it for the price. I paid about $75us as I recall.
Duane J
Think about renaming this thread "Waiting for Baudot".
Al
This looks like the best suggestion for a reasonable price. But a rubidium 10 MHz frequency standard sure would be cool!
I did some work on the FE-5680A rubidium standard to change it into a general purpose frequency generator.
See:
FE-5680A
Duane J
Good one, how about "Seeking Baudot" or "Searching for Baudot"
It looks to me like the oscillator in my counter is just about 1 part per million fast. The manual from hp tells you how to fiddle the osc but I think taking the cover off would be one of my dumber stunts. I'll just remember that 1.000001 is really 1.
I used to keep a sticker telling me the same thing on a homemade counter years ago. I'm a little surprised that HP didn't make this counter easier to adjust.
This module is replaced by the U-Blox PAM-7Q. And, we have a board for it coming out next month, too! It's the best GPS we could find for performance, cost and availability. We've grown tired of having multiple GPS units and obsolete parts, so this time we've chosen a mainstream supplier for the long haul. All of our GPS shall be consolidated into a single product around the PAM-7Q. You won't have to make any decisions about what to buy because we'll only have the best module (and no choices!).
No links yet ?
How do your tests compare with the one mentioned above ?
"The Fastrax UP501 is a cheap GPS module that has a 1 PPS output with extremely low jitter. "\
I found new data (7 Mar 2014) on the PAM-7Q, but tagged 'Advance Information' ?
See HP 5316B Operation on page "3-18" and figure "3-11".
Duane J
The specs on this look great, especially the lower voltage/current requirements and the programmable pulse output (.25Hz to 1KHz)
Gee, I guess it depends of what kind of stability you need. If I had known about the options, I would have gotten option 4, if I had found one. But I think I would have pretty much had to turn it on and leave it on to take advantage. The one I got doesn't have *any* option (not even TCXO) and the short term stability is good enough for me. And I can calibrate it with my fancy Fastrax whenever I feel the need. So you pays yr' money and you takes yr' choice.
I'll now await the arrival of the Parallax U-Blox PAM-7Q module, for 1pps and for knowing where the heck I am.
2 months later ..... I don't see these yet in the Parallax store, any news on when they'll be available?
Thanks!
-Katie
I am also interested.
As am I.
And who is the supplier of the GPS chip set?
As per Ken's post#13:
U-Blox PAM-7Q
