motion sensoring — Parallax Forums
motion sensoring
ami85tami85t Posts: 1
edited 2014-03-13 09:19 in Accessories
Hi,
I have bought the MMA7455 3-Axis Accelerometer Module and I want to use it for a simple purpose
which is getting an indication that a movement of an object ( in which the Accelerometer is) has occurred upwards or downwards.
The Accelerometer needs to send the information to a PIC16f877. The thing is that the PIC is also
connected to another component which communicates only via SPI protocol.
can i communicate with both the components one after another? (twice SPI or SPI and I2C?)
what are the things that need to be done for enabling that?
Thanks, Amitai
    ami85t,
    Welcome to the forums!!
    Since the PIC is a single threaded device you will need to communicate one after the other and hope that you don't miss a signal in between... i.e. if the PIC is talking to the other component with SPI, it may miss the Accelerometer data entirely.
    At around $5 for a single threaded PIC16f877 processor, why not use an $8 Propeller with effectively 8 processor threads with available libraries for I2C and SPI?
    Propeller reference:
    http://www.parallax.com/product/p8x32a-d40
