3 PCs 1 BS2
Hello,
I have a project where I want to communicate from 3 PC to a single BS2 circuit via RS-232. I have done RS-232 successfully using 1 PC with a BS2 but wonder how easy it would be using 2 and if there are any pitfalls I need to watch for.
Many thanks,
Al
Many thanks,
Al
The BASIC Stamp Module only has one RS-232 compatible interface. Any I/O pin can be a serial port, however you would need to convert your RS-232 signals to TTL serial. Even then, since the BASIC Stamp Modules do not have a UART or FIFO buffer the BASIC Stamp Module iteself would really need to drive the communication between the PCs. If the PCs were arbitrarily sending data to the BASIC Stamp Module it would most likely miss data while listening to another PC since it is a single-tasking MCU and can only perform one command at a time. On the other hand if the BASIC Stamp Module were to send a request for information to each PC one at a time and wait for a reply then you could ensure nothing was missed.
