building propgcc from source
ersmith
(This will only affect those adventurous individuals who build their own copies of PropGCC, for example to run on other platforms.)
There have been some changes to the way we build PropGCC on the default branch. David Betz contributed a very nice Makefile, which allows us to build individual projects like the loader or binutils. The old jbuild.sh and rebuild.sh scripts have been removed (you can always get them back via Mercurial if you need them).
Cross compilation from Linux to Windows or Raspberry Pi is now supported as well, so you can for example do:
make -j4
make -j4 CROSS=win32
make -j4 CROSS=rpi
to build all 3 platforms using 4 threads.
make -j4
make -j4 CROSS=rpi
Regarding ./configure ... is there a way to cache the result for the sub-projects?
When I was compiling with jbuild on eight cores, the ./configures were talking a big chunk of the total real time.
Yes, the configuration is cached (it is only re-run if you clean). Also, you can just build the parts you want, e.g. "make gcc" or "make gdb".
Thank you David Betz for the work on the Makefile, and of course anyone/everyone else that's put so much work into PropGCC.
I had to re-install Ubuntu 13.10 due to the latest nVidia drivers and lxubuntu hosing my previsous installation. This time I left out lxubuntu, and used the 4.03 Nvidia drivers.
Here is how to build propgcc on Ubuntu 13.10, including what is missing.
Install Missing packages:
sudo apt-get install mercurial
sudo apt-get install autoconf
sudo apt-get install bison
sudo apt-get install flex
sudo apt-get install libncurses-dev
sudo apt-get install libexpat1-dev
(From Wiki) Ubuntu 13.10 requires texinfo4.13 using these instructions:
wget http://ftp.gnu.org/gnu/texinfo/texinfo-4.13a.tar.gz
tar -zxvf texinfo-4.13a.tar.gz
cd texinfo-4.13
./configure
make
sudo make install
Now that we have pre-requsites, follow the Linux build instructions from:
https://code.google.com/p/propgcc/wiki/PropGccBuild
Except instead of using (the missing in current version) ./rebuild.sh
time make -j8
Build complete.
real 15m14.718s
user 27m9.442s
sys 13m44.044s
I was watching sysmonitor, almost half of the processor time was used running .configure for different subdirectories on a single core.
There still seem to be some dependancies on bstc...
make -C toggle/pasm_toggle
make[1]: Entering directory `/home/bhenning/propeller/propgcc/demos/toggle/pasm_toggle'
propeller-elf-gcc -Os -mlmm -mlmm -o toggle.o -c toggle.c
bstc -Ox -c -o toggle toggle.spin
make[1]: bstc: Command not found
make[1]: *** [toggle.dat] Error 127
make[1]: Leaving directory `/home/bhenning/propeller/propgcc/demos/toggle/pasm_toggle'
make: *** [all] Error 2
Demos that don't need bstc compile just fine!
Thanks for the info. I've checked in some Makefile changes to use spin2cpp instead of bstc; openspin should work fine as well (bstc was only being used to build .dat files, which both openspin -c and spin2cpp --dat can do).
Eric
I plan to add a 128GB SSD as a bcache to the system, that should speed up the system a lot more...
