64 bit Ubuntu 13.10 + propgcc + OpenSpin + SimpleIDE — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2014-03-16 11:57 in Propeller 1
Subject says it all :)
I'm trying to get the above running on my shiny new Linux dev box, which does not run bst any more :-(
I figure if the combination works on my Pi, it should be possible to get it running under Ubuntu!
So far:
- I have OpenSpin compiled
- I am working on compiling the latest hg pull (happening as I post this) of propgcc
- SimpleIDE is next on my hit list
I'll keep updating this thread with my progress
  • jazzedjazzed Posts: 11,803
    edited 2014-03-09 12:17
    Hi Bill.
    I did this last week. The propeller-gcc wiki has an updated build requirements page.
    There are two build possibilities: release_1_0 and default branch.
    The release_1_0 branch is the blessed version. Use jbuild.sh with that.
    SimpleIDE is built using Qt with 4.8.0 or 4.8.3 libraries from the spinside branch.
    edited 2014-03-09 12:49
    Thanks Steve,
    That helped. I was trying to figure out the texinfo business when I read your post. Had to install a fre more pre-requisites too.
    I'll look up how to pull the blessed version, it has been a long time since I rebuilt gcc. My box is building the default I think right now.
    With jbuild.sh, should I be passing number of cores, or number of cores*2 for the fastest build?
    I plan to install bcache, I am curious what kind of a speed increase I can get by using a 128GB Sata 3 SSD as a cache for the hard drive I am using for the root filesystem.
    edited 2014-03-09 13:44
    To get release_1_0, just say $ hg update release_1_0
    In the release_1_0 branch it takes about 12 minutes if i use ./jbuild.sh 6 rm-all
    The jbuild.sh N specifies the number of cores ... I allocate 4 cores to my VMs.
    Use make on the default branch. It was added for cross-compiling mingw and other things. There is some rumor that cross-compiling arm may be available later.
    Last time I tested it, the default branch jbuild.sh did not produce a usable build. I'm not sure if jbuild.sh N has been fixed or not (or if it should be considering the make stuff).
    Not sure about SSD.
    edited 2014-03-09 13:48
    Thanks Steve.
    I just got a complete build done with the default ./rebuild.sh, it took 4o min 43.58 sec
    I'll grab the release_1_0 in a different directory, and try ./jbuild.sh 6 rm-all
    I am not ready to test the SSD yet, I want this system configured the way I like it first, back it up, then add the bcache.
    edited 2014-03-09 13:53
    Just move /opt/parallax to /opt/parallax-default
    Make a new /opt/parallax with correct permissions.
    Don't worry about ../build
    Do $ hg update release_1_0
    Then $ ./jbuild.sh 6 rm-all
    The default and release_1_0 are easily switched.
    I did have a source update related build error once in binutils. I just did this to fix it
    $ hg revert binutils
    edited 2014-03-09 14:56
    Thanks... will do that after I have a chance to re-install Ubuntu...
    The ./jbuild.sh 6 was MUCH faster, but the screen froze.
    Some investigation revealed that there is a bug in Unity, that causes X to freeze randomly.
    Disabling the screensaver lock helps some, but X locking up is unacceptable to me.
    Based on what I read after googling the issue, I decided to try to install the lubuntu desktop. It did not really work.
    Tried to install the newest nvidia drivers.
    Now X is totally borked, and the machine is somewhere between lubuntu and ubuntu.
    I am going to scrub the drive and re-install from scratch, and switch to gnome or lxde - supposedly that also fixes the freezing issue.
    edited 2014-03-09 16:09
    Bill, Now that you mention it, I had the same freeze problem once. I just disabled the screensaver since it's in a VM. I don't really like Ubuntu, but I need something new for new builds. I have Mint16 32 bit, but it freezes with 3D acceleration enabled. Not sure what I'll try next for 64 bit stuff.
    edited 2014-03-09 21:19
    Hi Steve,
    I got back from a family dinner about an hour ago, and re-installed Ubuntu 13.10 from scratch.
    This time I updated immediately after installing, and added xrdp, xfce4 (for use by rdp), and ssh.
    If X crashes now, I can ssh back in to shut down cleanly :-)
    Now I'll have to install OpenSpin, propgcc again, then start on SimpleIDE. I'll keep reporting on my progress in this thread.
    I am now also planning to install VirtualBox, with Ubuntu 12.04 / Windows 7 / Windows XP clients for the odd software that I can't get running natively.
  • ersmithersmith Posts: 6,281
    edited 2014-03-10 05:37
    jazzed wrote: »
    Cross compiling for raspberry pi is available now in the default branch. See the README.cross file for directions. The gdb build fails, but everything else builds and gets put into /opt/parallax-rpi/ on the host.
    edited 2014-03-10 08:55
    ersmith wrote: »
    Thanks Eric!
    edited 2014-03-10 09:14
    Thanks Eric, very good news.
    ersmith wrote: »
    edited 2014-03-11 10:17
    Hey Bill,
    I updated the OpenSpin source on github, can you see if that builds without modification on your linux setup?
    edited 2014-03-11 10:47
    Hi Roy,
    Will do, thanks (tonite when I am at that computer) - I finally got Ubuntu 13.10 re-loaded Sunday night after messing it up trying to get xrdp working right.
    Long story short... do not 'sudo apt-get install lubuntu' unless you want a mess, and especially don't install the nvidia proprietary drivers after that. Had to wipe and re-install.
    Instead do 'sudo apt-get install lxde', then install xrdp and set your .xsession to use lxde with xrdp... that is if you want to rdp into the box and get a desktop. Unity does not play well with xrdp.
    edited 2014-03-16 11:56
    I appear to have gotten the freezing under control ... the proprietary nvidia driver one rev back (4.04?) seems to fix it.
    jazzed wrote: »
    Thanks Roy,
    I'll try it right now!
    I just finished getting propgcc built again (had to scrub & re-install the box - long story)
    Roy Eltham wrote: »
    Hey Bill,
