Hi, I was working on a project from the pe kit and need the "squarewave.spin" file for my library. I cant seem to find it in the obex. Does anyone know where I can find that? Thanks.
I'm having trouble opening the square wave file. It seems to be because its a .php file which adobe xI won't work with. I tried unsuccessfully downloading Microsoft php file manager. I don't recall having problems downloading files from parallax before, Is the .php newer? Has anyone had this Problem?
Click on the second link that Bob posted. That takes you to the forum thread: PE Kit Tools: Transmit Square Wave Frequencies
Scroll down to just before the section labeled: Square Waves in Differential Mode
Do that. ** Actually, I found out that the link was attached to this post, so just click on the link above, save it, and unzip it.
Be sure to unzip the file. I was not able to open SquareWave.spin from the zip file. But once I saved and unzipped it, I was able to open all the files.
Thanks Tom, I must be missing the program that unzips. I downloaded and saved it. The only options it gives me are adobe(which won't work yet) and search the internet. I'll try to find something to unzip it tonight. Thanks again.
Thanks for your replies. What would be a correct extension zip? I tried to download from the link on aribas post but I ended up in the same place where I was stuck.
How durable are the ir receiver modules? I'm trying to duplicate the square wave exercise from pe kit. I have it set up as per pe kit, although early on I had 1k resistor on data pin rather than the 10k. at some point I switched up and output 3.3v at 38 kHz to the output pin of the ir receiver mod. Not sure if I fried something, im not seeing any changes in the serial terminal as detecting anything. yesterday it would detect, but it was very jittery so not sure if it was a true signal because this happened even with ir led covered and also with ir detector covered.
Update...I know the ir led works, I slowed the freq down and can see it flash through the camera on my phone. somehow my computer crashed and works again, and now the ir detector as seen in the serial terminal is back to jittering. I tried a 10 k res. to grd and also to 3.3 (along with 1k to the prop pin for protection) to make sure the pin couldn't float but it still jitters. I also replaced the ir receiver with a pushbutton and everything else works correctly. The ir detector says it has an elliptical lens to block light below and above 38 kHz. I've tried different freq around 38 but am having no luck. sounds like a fried ir detector? Should I try something else?
I think the ir receiver I had was defective. I picked up another one and can see a reaction on the serial terminal from the tv remote. So I think the only thing left is that the ir led isn't pulsing at 38 kHz. Not sure how to check that. I don't have an o-scope. In the squarewave object there is this line .....PUB Freq(pin, module, frequency). I have it as per pe kit lesson, but not sure what "module" is. It has it as "0". I'm assuming its counter module but I thought those were referred to as "a" and "b".
I'm trying to see if the ir led is really getting 38 kHz with posedge counter, but I'm not sure if I have that right. Does this code look like it would work? phsb amounts to zero, I was hoping for 38k +/-.
CON
_clkmode = xtal1 + pll16x ' System clock → 80 MHz
_xinfreq = 5_000_000
OBJ
pst : "Parallax Serial Terminal"
SqrWave : "SquareWave"
PUB IrDetect | herz
'Start 38 kHz square wave
SqrWave.Freq(1, 0, 38000) ' 38 kHz signal → P1
dira[1]~ ' Set I/O pin to input when no signal needed
dira[12]~
ctrb[30..26]:=%01010
ctrb[5..0]:=12
frqb~
phsb~
pst.Start(115_200)
waitcnt(clkfreq*5+cnt)
dira[1]~~ ' I/O pin → output to transmit 38 kHz
waitcnt(clkfreq+ cnt) ' Wait 1 ms
dira[1]~ ' I/O pin → input to stop signal
herz:=phsb
pst.dec(herz)
I think this new receiver is ok. It will respond to a Sony remote and Samsung , the 2 that I tried. When I get home I will change frqb and try again. Thank you.
I corrected the frqb, and the ir led put out 38001 hz. Still nothing, so I rearranged the circuit on the breadboard and now it works. I'm not sure if the wires were inducing a signal upon each other, but they are separated now and it works. Thanks for the help.
http://forums.parallax.com/attachment.php?attachmentid=60200&d=1240110501
This is the reference page:
http://forums.parallax.com/showthread.php/112118-PE-Kit-Tools-Transmit-Square-Wave-Frequencies
About 4 lines above that section title is :
P······ Download and unzip PE Kit Tools Square Wave Frequencies.zip.
Hope this helps
Tom
Them show up as attachment.php and you have to 'save as' and add the correct extension '.zip' by yourself.
Enjoy!
so when you click on 'SquareWave.spin' replace 'attachment.php' by 'SquareWave.spin.'
when you click on 'SquareWave.Zip' replace 'attachment.php' by 'SquareWave.Zip.'
Enjoy!
Just bending pins cab cause internal damage.
CON _clkmode = xtal1 + pll16x ' System clock → 80 MHz _xinfreq = 5_000_000 OBJ pst : "Parallax Serial Terminal" SqrWave : "SquareWave" PUB IrDetect | herz 'Start 38 kHz square wave SqrWave.Freq(1, 0, 38000) ' 38 kHz signal → P1 dira[1]~ ' Set I/O pin to input when no signal needed dira[12]~ ctrb[30..26]:=%01010 ctrb[5..0]:=12 frqb~ phsb~ pst.Start(115_200) waitcnt(clkfreq*5+cnt) dira[1]~~ ' I/O pin → output to transmit 38 kHz waitcnt(clkfreq+ cnt) ' Wait 1 ms dira[1]~ ' I/O pin → input to stop signal herz:=phsb pst.dec(herz)Load the IR remote control object and set a TV universal remote to Sony.
See if the detector detects that?
