GPS & Antenna
I got the PBM-688 GPS and Antenna but don't know how to attach the Antenna to the GPS unit.
I first thought that it had threads but I'm not sure it's pretty small for my eyes.
Could you pls let me know if I should just push or screw it in or ?
The unit works fine o my desk but I would like to see if I can catch a few more Satellites
And BTW when the GPS Spec says Optional in Baud-rate and Output messages, what does
it mean? do you order a different unit to get those features or do you have to command the unit to provide these?
Thanks in advance
Preben
Thanks in advance
Preben
Not sure what you mean wrt GPS spec. Not all GPS chips implement all commands. Can you be more specific?
You might want to check out the zip file in Post #8 of this thread:
http://forums.parallax.com/showthread.php/125402-Can-t-Read-GPS?highlight=SiRF
It might have the software to change the baud rate. In the PDF, page 2-2.
and for Output messages it mentions optional VTG and Gll
I have the hunch that it means that it comes programmed to work at 4800 bps, and GGA,GSV,GSA,RMC
and that I have to command it to provide the other messages/baud rates.
I did end up pushing it in and it too works fine in my office 7 satellites in view
Thanks for inputs
Preben
Mainly baud rate, messages, sometimes frequency of the message, binary mode and so on.
You usually can also select if the unit updates the position continuously of only if there is a minimum delta between two reading.
What you can do and how depends on the GPS unit you have.
If I remember correctly Phil posted a spin program to enter binary mode, do some configuration stuff and go back to NMEA.... have yet to find it....
Massimo
http://forums.parallax.com/showthread.php/140908-Difficulty-transmitting-to-PMB-648-GPS
Although it is a different part number, they both use the samSiRF Star III chipset.
Massimo
much time to play. I will attempt to bring my prototype setup with me for the cold
evenings :-)
Thanks to you all for the inputs and guidance.
Preben
