How to start ,stop and restart a method while a program is still running.?? — Parallax Forums
msiriwardenamsiriwardena Posts: 301
edited 2014-03-10 19:13 in Propeller 1
Iam using Autodatalogger by SLRM to log RPM and pressure sensor readings.As I have it in the program it does logg RPM and the pressures continually for 1.0 min.I
can change the logging time prior to starting the program.
What wan't to achieve is to stop and re-start the Datalogger for couple of minutes(as it is now) to logg special events that occur that I need to at that time.
In other words I like to start and stop the Datalogger when necessary.
I tried to start and stop using a button but not successful.That is example: ina[BTN1] == 1 ---> start Datalogger --> cognew(Datalogger,@DataloggerStaclk) and
use the Datalogger Oblects - "stop method" at the end of the required time.This does not work.
I have attached archieved version of my project and The AutoDatalogger Object by SRLM.
I am using the "Memory Stick Datalogger - Prallax ID#27937"
Thanks for your help.
Siri
    edited 2014-03-03 17:50
    You look like you are using more than 8 cogs.
    It looks like when you launch the usb object, it sucks up the last of the cogs, so this code dosen't run at all.
      repeat num0 from 1 to 2
        num0[num0] := 3_999_999_999
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
          waitcnt(num0 += clkfreq)  'Seconds
      USB.stop
      repeat
    I suggest you adopt a new MAIN method strategy for keeping track of it all.
    VAR
      long  cogon[8], cog[8], pile[2000]   ' cog management
    PUB Start
      'Assuming that a 80 MHz core clock is being used, 800 cycles is about 10us.
      'waitcnt(800 + cnt)           'Wait for 10us      -100 khz  PASM
      'waitcnt(8_000 + cnt)         'Wait for 100 us    -10 khz   PASM
      'waitcnt(80_000 + cnt)        'Wait for 1ms       -1000 hz
      'waitcnt(800_000 + cnt)       'Wait for 10 ms     -100 hz
      'waitcnt(8_000_000 + cnt)     'Wait for 100 ms    -10hz human reaction speed
      'waitcnt(80_000_000 + cnt)    'Wait for 1000 ms   -1hz
      stop ' stop all cogs if running
      cogon[0] := (cog[0] := cognew(Read0, @pile[0]) > 0)
      cogon[1] := (cog[1] := cognew(Read1, @pile[200]) > 0)
      cogon[2] := (cog[2] := cognew(Read2, @pile[400]) > 0)
      cogon[3] := (cog[3] := cognew(Read3, @pile[600]) > 0)
      cogon[4] := (cog[4] := cognew(Read4, @pile[800]) > 0)
      cogon[5] := (cog[5] := cognew(Read5, @pile[1000]) > 0)
      cogon[6] := (cog[6] := cognew(Read6, @pile[1200]) > 0)
      cogon[7] := (cog[7] := cognew(Read7, @pile[1400]) > 0)
    PUB stop
    '' Unload timer object - frees a cog
      if cogon[0]~                                          ' if object running, mark stopped
        cogstop(cog[0])
      if cogon[1]~                                          ' if object running, mark stopped
        cogstop(cog[1])
      if cogon[2]~                                              ' if object running, mark stopped
        cogstop(cog[2])
      if cogon[3]~                                              ' if object running, mark stopped
        cogstop(cog[3])
      if cogon[4]~                                              ' if object running, mark stopped
        cogstop(cog[4])
      if cogon[5]~                                              ' if object running, mark stopped
        cogstop(cog[5])
      if cogon[6]~                                              ' if object running, mark stopped
        cogstop(cog[6])
      if cogon[7]~                                              ' if object running, mark stopped
        cogstop(cog[7])
    So to integrate it into your code.
    ''                 ************** Pressure Testing **********************
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
      MS_001   = CLK_FREQ / 1_000
      REFRESH_RATE = 16_000_000' 80_000_000/5
    con
      SCL    = 28             'I2C connections to pressure sensor - MS4515DO
      SDA    = 29
      id     = $51            'Device Read address  ---->provided by OEM
      data   = 13             'data in pin to pin 1 of MAX-7219
      clock  = 11             'clock signal in pin to pin 13 of MAX-7219
      load   = 12             'load pulse in pin to pin 12 of MAX-7219
      DP     = 000000      'decimal point
      minus  = 10          'MAX-7219 display code for a minus (-).
      rxpin     = 19             'Receive pin on the Propeller   ---> Datalogger
      txpin     = 18             'Transmit pin on the Propeller
      ctspin    = 17
      RevPin          = 6
      Baud            = 19200
      Lines           = 2
      INPIN           = 8      'RPM counter PIN from BLDC controller
      MotorPin        = 1      'Motor run/stop
      ExpSolenoid1     = 23     'Exhalation circuit solenoid  connected tp P 23 ---> also the pressure relief valve 1
      ExpSolenoid2     = 22     'Exhalation circuit solenoid connected to P 22 ----> also the pressure relief valve 2
      IntakeSolenoids = 21      'Opens in inspiration and closes during expiration
      Vac              = 14
    obj
      I2C  : "pasm_i2c_driver"
      Revs : "Debug_Lcd"
      Seg_7: "7_Seg_LED.Driver_V1.3"
      term : "fullduplexserial"
       USB : "Autodatalogger"
    var
         long RevCounterStack[100]
         long DisplayStack[100]
         long ControlStack[100]
         long waitUntil, inFreq
         long RPM
         long pressure, pressure1
         long filenameaddr
         long num0, num1, num2, num3
         long DataLoggerStack[100]
    PUB Main
      'MAKE SURE YOU COUNT TOTAL COGS IN USE.  Subobjects use cogs also!!!
       I2C.Initialize(SCL)        ' setup I2C buss (boot pins)                    '1-cog
       Revs.init(REVpin, baud, lines)    ' start Serial_LCD        **** 'Do these use cogs?
       Seg_7.Start(12,11,13)              'start 7 seg driver      **** 'Do these use cogs?
       pause(10)
      cogon[0] := (cog[0] := cognew(DataLogger, @DataLoggerStack) > 0)           '3-cogs
      cogon[1] := (cog[1] := cognew(Revolution_Counter, @RevCounterStack) > 0)   '1-cog
      cogon[2] := (cog[2] := cognew(ValveControl, @ControlStack) > 0)            '1-cog
      'cogon[3] := (cog[3] := cognew(Method3, @pile[600]) > 0)
      'cogon[4] := (cog[4] := cognew(Method4, @pile[800]) > 0)
      'cogon[5] := (cog[5] := cognew(Method5, @pile[1000]) > 0)
      'cogon[6] := (cog[6] := cognew(Method6, @pile[1200]) > 0)
      'cogon[7] := (cog[7] := cognew(Method7, @pile[1400]) > 0)
       pause(10)
       dira[MotorPin]~~
       pause(10)
       outa[MotorPin]~                       'Start BLDC motor
      Read_Display_Pressure '1-cog
       '----Total cogs in use: At LEAST :7
    PUB stop
        cogstop(cog[0])
        cogstop(cog[1])
        cogstop(cog[2])
        cogstop(cog[3])
        cogstop(cog[4])
        cogstop(cog[5])
        cogstop(cog[6])
        cogstop(cog[7])
    Pub Read_Display_Pressure              'READ AND DISPLAY PRESSURE ON THE 8 SEGMENT led DISPLAY
      repeat
        Seg_7.Clear(data,clock,load)              'Clear all digits - 7SegLED display
                  'read I2C
        I2C.Start(SCL)
        I2C.Write(SCL,$51)                        'write read address
        Pressure := I2C.Read(SCL,1)                  'read pressure value to variable "Value"
        Pressure1:= Pressure-31                          ' Error correction(31)on initial reading at atmospheric pressure
         Seg_7.CharOut(data,clock,load,Pressure1)      'send pressure data to 7Seg.LED
         pause(50)
    Pub ValveControl                           'CONTROL SOLENOID VALVES DURING INSPIRATORY & EXPIRATORY PHASE
        dira[21..23]~~                         'Set solenoid pins as outputs
        dira[14]~~
        outa[23]~~
     repeat
           If Pressure1  < 0
               outa[21]~~
               outa[22]~
               outa[23]~
               outa[14]~                      'Inspiratory phase Pump valve open/bypass valve closed and expiratory valves close
              'pause(10)
           ElseIf pressure1 > 4
               outa[21]~                     ' Expiratory phase ---> pump valve closes/bypass valve opens.
               outa[22]~~
               outa[23]~~
               outa[14]~~                    'BOTH Relief valves @22&23 open
               'pause(10)
       If Pressure1 > 3             'In case of inadvertant pressure rises > 5cm.H2O - pump is bypassed and
            outa[22..23]~~
            outa[14]~~                 ' both pressure relief valves opne to AIR
            pause(200)
    Pub DataLogger                             'DATA LOGGER CODE
      filenameaddr := string("Pressure.txt")
      num1 := num2 := num3 := 0
      waitcnt(clkfreq*6 + cnt)
      waitcnt(clkfreq*2 + cnt)
      USB.init(rxpin, txpin, ctspin, filenameaddr, 10_000)
      '           (address, digits, title)
      USB.addfield(@pressure, 2, string("Raw"))
      USB.addfield(@RPM, 4, string("RPM"))
      USB.addfield(@Pressure1, 2, string("corrected"))
       USB.start
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
      USB.stop
      repeat
    Pub Revolution_Counter
       Revs.backLight(true)
       Revs.cursor(0)
      ctra := 010 << 26 + INPIN    ' counter A in POSedge mode
      frqa := 1                       ' increment 1 per pulse  waitcnt(clkfreq + cnt)
    ' measure the input duty cycle using counters.
      waitUntil := cnt + REFRESH_RATE
      repeat
        phsa := 0                     ' reset count registers
        waitcnt(waitUntil+=REFRESH_RATE)
        inFreq       := phsa * (constant(80_000_000/REFRESH_RATE))         ' read the number of edges; convert to 1 second
        RPM:=(15*inFreq)
        Revs.CLS
        Revs.str(string("RPM :"))
        'waitcnt(clkfreq / 200 + cnt)
        Revs.dec(RPM)
    pub pause(ms) | t
    '' Delay program in milliseconds
      t := cnt - 1088                              ' sync with system counter
      repeat (ms #> 0)
        waitcnt(t += MS_001)
    dat
      Copyright (c) 2009-10 Jon McPhalen (aka Jon Williams)  AND Autodataloggeer V 1.0  By SRLM
      Permission is hereby granted, free of charge, to any person obtaining a copy of this
      software and associated documentation files (the "Software"), to deal in the Software
      without restriction, including without limitation the rights to use, copy, modify,
      merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
      permit persons to whom the Software is furnished to do so, subject to the following
      conditions:
      The above copyright notice and this permission notice shall be included in all copies
      or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
      INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
      PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
      HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
      CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
      OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    But the new code doesn't change the fact that you may be using all 8 cogs and requesting more.
    Try to merge two cogs functions into one, and see it it works.
    When I calculate that I've used at least 7 cogs, I usually try to knock the code around to maintain my 7 cog use so I always have 1 free.
    You are putting many different elements of code together, when you do this, its gets very confusing.
    Especially when you are using almost all cogs.
    Make a block diagram to help you understand your program flow, and cog usage.
    Take a look at one such block diagram I created for my own project that used 4 prop chips, and almost all cogs in them. 32 cogs... hahaha..
    http://forums.parallax.com/attachment.php?attachmentid=68222&d=1267464086
  • msiriwardenamsiriwardena Posts: 301
    edited 2014-03-03 18:33
    @Clockloop -The project does works it is but I only want to run the Datalogger when I wan't .As it is now the Datalogger starts with the program and stops after logging
    the required 2-3 min. but I wan't to re-start again at alater time.
    Siri
    edited 2014-03-03 19:06
    Siri
    oh.
    in that case.
    Looks like you repeat this sequence at the end of your code.
       USB.start
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
      USB.stop
      filenameaddr := string("Pressure2.txt")
       USB.start
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
      USB.stop
      Repeat
    I repeated the entire PUB Datalogger, but changed the second filename to Pressure2.txt
    Another way, neater.
       USB.start
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
      USB.stop
      DataLoggerR2
    Pub DataLoggerR2                             'DATA LOGGER CODE Round2
       USB.start
      num0 := cnt
      repeat 1
        repeat 60                 '1 Minute
      USB.stop
      Repeat
    How many times do you want to run it?
    So if looks like you are trying to run the datalogger when you press a button.
    And have it log the data to a new file name.
    That requires some code modification.. the string filename needs to increment..
    Another person needs to help you at this point.
    If the string you pass to the datalogger dosen't require anything but a number, you could try that.
    Just make a counter, and convert the decimal to string every cycle and feed that as the string for the filename.
    You will need to rename the filenames once in an os.
    So if ina[BTN1] == 1 is your trigger. .....?
    edited 2014-03-04 07:23
    @ Clock Loop- Thanks for trying to help.
    All i require is to run the datalogger with the same file name at different time because I will replace the thumb drive with different one,so the file name and else do not matter.
    I hope some one come up with a solution.
    Siri
    edited 2014-03-04 21:40
    Not sure I understand what you think the problem is. I prepared a simple example using a logger object which mimics Autodatalogger. This gets started and stopped repeatedly. Have a look and let me know if there are still questions. The data logger indicates active state by lighting LED16, the main object controls LED17.
    edited 2014-03-05 08:02
    @kuraneko - Thanks for helping me again.
    Since you helped me with logging -ve numbres, I came accross anther issue.
    Thae code as it is - loggs data for 1.0min and with the command "USB.Stop" the file is closed and the object/?cog - shuts down.
    When I wan't log another 1.0 min,I only way I know to do this is to turn off the prop board and power on again,then it will log data for 1.0min.
    What I an trying to achive is to re-start the Datalogger at random to logg the data for another minute- without shutting down the whole system.
    I have a pump and pressures sensors in the system and I do not want to stop them as I wan't to collect data from them at that instant.
    What your code does is to stop and start at specific or pre-determined intervals.
    I would like to start at random - example: When a switch is pressed --? ina[BTN1]==1, so when I need to logg data - i will only need to press the button to collect data for 1.0 min. then again at later time.
    I hope I explained clearly if not let me know .
    Siri
    edited 2014-03-05 12:16
    @Kuroneko- I am begining to think that this is a hardware problem.
    The USB drive is recognised only if it is plugged into the Memory Stick Datalogger(Parallax #27937) and then the prop board is powered.Then I see the power on LED sequence discribed
    in the user manual - (green & red flashes alternately x 2sec.) and once the usb drive is removed both LED's are off.If I re-insert the USB drive nothing happens.(no flshing Led's).
    May be I need to put a on/off switch to the power line to the Datalogger.Then ? re-start the Autodatalogger object and the Datalogger Method.
    I have the Memory Stick datalogger soldered on to the board so I have ordered anothe one then I can test and come up with the solution.
    I was reading the Vinculum data sheet which has a reset pin.It also says it can be used to by an external source.On the Memory Stick - there 3 pins labelled- Rest,
    Ground,Program.So is it possible to reset the Vinculum chip by pulling the Rest pin to ground(jump the 2 pins) and re-start the datalogger oblect .
    Please let me know what your opinion - that is if this can be resolved with software.
    Thanks again.
    Siri
    P.S : Attached is the Memory Stick Datalogger - Documentaion.and Viculum documentation.
    edited 2014-03-06 12:43
    @Kuroneko- The last 2 post were posted while at work and did not get a chance to work with your until to-day.Thanks for the patience.
    I edited the Autodatalogger - object and also edited my program.The data logger only writes the Header - File names only. No data was written.
    I also removed the thumb drive and re-inserted and it was not recognized.If the thumb drive is already inserted and then the prop fired - the
    data logger only writes the header and no data.
    Thanks again for you help.
    Siri
    Attached is the archived files.
  • PropGuy2PropGuy2 Posts: 365
    edited 2014-03-06 16:42
    I have used the data logger extensively and Yes you have to use the Reset pin to turn it "off" otherwise it is still active and will not re-start correctly. Furthermore you have to close the file properly at the end of each read and write file session. Remember also that the (CS) chip select is inverted from the usual CS used in most ICs BTW you have to experiment with the software demo to get multiple data writes (not just one ASCII character at a time) - I write 1000 characters at a time using a big LONG array (if you can spare the memory to do it) Ditto with trying to get the file date time stamp to work.
    edited 2014-03-07 11:55
    @PropGuy2- The Reset PIN is pulled up via 47K - when not in use and have to pull it low to reset so Do I have to pull it low with 10K with the prop and follow up with code to start the Datalogger.Do I have to re-initialize the object again prior to opning another file.
    The next question is - the Autudatalogger object does not have "PUB Closefile method or Pub Openfile method.So how do you use " Openfile/Closefile" to open
    a new file and close it when data is logged.
    The data is logged safely when "stop" method is called as in the Demo program.
    Siri
    edited 2014-03-08 05:34
    Apologies, the example uses fake pin numbers (0, 1, 2) and the addfield calls were bogus (0, 0, 0). The whole point here was to simply show the sequence of logging repeatedly rather than one off (I wasn't aware until recently that you actually remove the h/w).
    The expected call sequence is
    • init
    • addfield (1..N)
    • start
    • stop (optional)
    The init method will open the filename at SPIN level (and will add System Clock to the header), addfield will write the relevant header data for each field you add. Finally, start will close the file - at SPIN level - and give control to the PASM part which will open the file and close it again once the stop call has been received. IOW, when you follow the sequence listed above you won't have to worry about opening/closing the file manually. All you do is provide a filename to init.
    edited 2014-03-08 12:15
    @Kuroneko
    I have been trying to make it work as you sugested,I must be doing something wrong.
    Now writes the headder and write one set of data and quits.I have beev trying to log about one minute of data at different times.
    Siri
    Attached is the archived program and the copy of the Data file.
    edited 2014-03-08 15:09
    The log_start method has grown a usb.stop call which wasn't there before. So it's no surprise that the logger only ever manages to write one line. Also, as you are back to a single filename, I simply don't know what the re-open behaviour is for the real logger (append or overwrite) so that is something you must figure out.
    The manual mentions append mode (default) which suggests that only the first log attempt actually works (otherwise one would expect several header/single log line pairs due to the extra close call). Is there any error indication (e.g. LED) that subsequent log attempts fail (short of instrumenting the code yourself)? That said, you could manually send commands to see if consecutive open/write/close attempts work. Also, in the data logger there is a subroutine called reply which makes an attempt to analyze a potential error code. If so it calls critical_error which could be used to light an LED or something like that.
    As for calling it, you start logging with a sequence of init/addfield/start, i.e. call (the original) log_start. Then you wait for however you long you want to log. At this point you call log_stop. For the next logging sequence you repeat this sequence whenever you need it. I don't personally own a data logger of this type so in a way I must rely on your test results. HTH
    edited 2014-03-10 08:43
    @Kurneko,
    I tested the code exactly as you advised.I changed the "Data field : name byte "00000000.log" , 0 to ---> name byte "Pressure.txt" , 0 The title of the file remains- "00000000" - the name "Pressure" was not the title of the file.
    Although I added 3 more data columns ,they were not named but comma delineation was there.- you can see it on the attached text file which
    was logged.
    I was monitoring the progress via PST - which showed : 00000000.log
    00000001.log etc to 00000000A.log ---> 000000011.log etc.
    Thanks for your patience and great help.
    Siri
    P.S: The Datalogger Overwrites it does not append.
    That is correct. The first 8 characters of the filename are replaced with an 8 digit hex number which increases for each call to log_start.
    repeat 8
        [COLOR="#FF0000"]name[n++][/COLOR] := lookupz((index <-= 4) & $F : "0".."9", "A".."F")
      [COLOR="#020FC0"]index++[/COLOR]
    The logfile you sent (00000000.log) shows exactly what I expect with addfield(0, 0, 0), i.e. empty column headers and logging of long[0] (clkfreq) in autowidth mode. The logfile seems to contains 2.89 sec worth of data which is close enough for the intended 3 sec. In case there is a 00000001.log file could you attach it please?
    Then how do you explain that the column header is still there? The file gets closed (and re-opened) between header emission and actual logging.
    Anyway, lets resolve the issues raised by PM first and go from there.
