Absolutely. I'll get an update out before the USB/SERDES work commences.
Chip,
May I ask that you please add the one USB instruction before you release the fpga code?
If it is not that simple, then maybe the following fpga release. I don't require pnut as I can hand code the longs.
Reason: Add new pin-pair instruction for use with USB bit-banging receive (similar to GETP/GETNP)
The S value (sub-instruction bits) "yyyyyyyy" would use the next available slot after CACHEX
Thread: [URL="http://forums.parallax.com/showthread.php/151904-Here-is-the-update-from-the-Big-Change!!!?p=1222515&viewfull=1#post1222515"][COLOR=#4366fb]http://forums.parallax.com/showthrea...=1#post1222515[/COLOR][/URL]
1111111 ZC L CCCC DDDDDDDDD xyyyyyyyy GETXP [#]D [WZ],[WC] ' set flags for the pin-pair for usb bit-banging
' D = PINx (0..127), PINy := PINx XOR $1 (it's complementary pin-pair)
' C = C XOR PINx via WC
' Z = !(PINx OR PINy) via WZ (ie ZERO if both PINx and PINy are both ZERO == SE0 in USB)
PINx and PINy are a pair of pins. If PINx is even then PINy := PINx + 1 else if PINx is odd then PINy := PINx - 1
The allowance for the PINx/PINy pair to be reversed is for USB LS & HS where J/K are effectively swapped between D-/D+.
WZ & WC would normally be used.
Chip,
Yes, I've been really meaning to get to that. It should be no problem.
Today, I got the register-to-INDA/B done and the static register remapping. I'm just mulling the final approach on the task save/restore now.
Chip,
BUT -- don't You need any SETXP instruction to send on that pair?
I had proposed a method to change the pin instructions such as SETB etc to use the WC & WZ to be able to set pin pairs.
However, from what I understand we can output complementary pairs using the builtin PIN modes. Alternately we can use XOR with PORTx to achieve this. The transmit side is much easier. If I find I need something like that later, I will ask. Currently I am more concerned with getting the read done, followed by the simple CRC bit routine.
With these under my belt, I can proceed. While I do this, SERDES can happen SEDES will take some time.
======================================================================================================= Reason: Add new pin-pair instruction for use with USB bit-banging receive (similar to GETP/GETNP) The S value (sub-instruction bits) "yyyyyyyy" would use the next available slot after CACHEX Thread: [URL="http://forums.parallax.com/showthread.php/151904-Here-is-the-update-from-the-Big-Change!!!?p=1222515&viewfull=1#post1222515"][COLOR=#4366fb]http://forums.parallax.com/showthrea...=1#post1222515[/COLOR][/URL] 1111111 ZC L CCCC DDDDDDDDD xyyyyyyyy GETXP [#]D [WZ],[WC] ' set flags for the pin-pair for usb bit-banging ' D = PINx (0..127), PINy := PINx XOR $1 (it's complementary pin-pair) ' C = C XOR PINx via WC ' Z = !(PINx OR PINy) via WZ (ie ZERO if both PINx and PINy are both ZERO == SE0 in USB) PINx and PINy are a pair of pins. If PINx is even then PINy := PINx + 1 else if PINx is odd then PINy := PINx - 1 The allowance for the PINx/PINy pair to be reversed is for USB LS & HS where J/K are effectively swapped between D-/D+. WZ & WC would normally be used. =======================================================================================================Yes, I've been really meaning to get to that. It should be no problem.
Does this pin-pair read instruction need a complementary version for output to pins ?
