MimsMirror: Zero. It needs a program/suggestions.
Clock Loop
Please see project thread:
http://forums.parallax.com/showthread.php/154191-MimsMirrorZero-and-MimsMirrorOne-(it-blinks-rgb)
Posting here for feedback, as projects seems to be dead.
-once all colors work, color based communication.
-Smooth fades.
-MORE COLORS.
-Intelligent conversations using multiple colors.
-Detector limited to rgb, but rctime can give differing values based on intensity, so color could be decoded if rc values for intensity of each rgb, on each led. (calibrated using another zero?)
-etc...
Please suggest, make a program, comment.
Thank you.
The current program is very very basic because I haven't had much time with it, right now my head is too full of too many ways it could go.
I don't have time to do all this, got a MimsMirror: One, on the way... theres another can of worms as far as program directions, and possibilities.
PLEASE, HELP. This can be breadboarded, and the leds pointed at eachother!
If you make a program for it, I will run it, if you let me know what it should do, I'll even record it if its worth recording, and my videos are fairly boring, showing that the Zero's do in fact "ignite" when seeing red.
I understand spin, pretty well, but not prop asm, so if you write something in asm, don't expect me to keep up.
The method I am using to do detection of led works pretty well, a better engine could be made for the hardware, probably, but the rctime is already a asm object, and does very well.
I don't have blue and green working with rctime due to their high VF, ....during my initial pre-pcb design testing, my findings were that blue and green could possibly be dead detectors due to such a high VF.
I calculated a need for a 25 ohm resistor on the green and blue leds, just to get 15ma at 3.3v.
I'll keep working at getting blue and green to detect better, (i may need a parallel cap with each led) or something, but what I am not doing is making a program.
Too busy with hardware right now. But I can run a program, much easier than staring down code for 4 hours.
I know its hard to code for virtual hardware, you can make one with a prop and 8 rgb leds, and proper resistors for the vf of those leds. (it just won't be in my shape) you can simulate communications by having two props with 8 rgb leds each, pointing at eachother down the centerline of a breadboard. etc...
and....
-Smooth fades.
-MORE COLORS.
-etc...
Thank you.
and....
If you attach your code as a project, it would be easier for us to see what you're doing.
I wonder if you'd have better luck using the LEDs as sensors if you used sigma delta ADC technique instead of RC time?
I know I have a bunch of RGB LEDs and I've been meaning to try using a LED as a sensor so this project might be a fun way of trying it out.
I'm interested in seeing how you've made your MimsMirrorZeros. Could you take a couple of pictures showing how you've soldered the parts?
They don't have to be as small as you've made them do they? Do think one could breadboard the parts together to make a couple of these?
Sorry about the whole code, I figured the main loop was good. Yes, the rctime was made by yet another awesome person who contributed it into the obex.
Its written in assembly.
http://obex.parallax.com/object/495
This rctime can even detect a finger/metal touch. Its pretty nifty.
Not sure about the sigmadelta, will look into it, unless someone else gets to it before me.
The other two objects in the main code are the real random object: by CHIP!
http://obex.parallax.com/object/498
And the fullduplex serial object, but my code comments this out, because its just used as debug.
http://obex.parallax.com/object/245
And heres the main code
' ========================================================================= ' ' File...... Zero.spin ' Purpose... This program will run identically on infinite? Zeros programmed from a prop plug in proper parallel config or using a master prop.. It self generates a random "life" that it waits with. ' Author.... Clock Loop @ parallax forums ' E-mail.... thereisnoelectron@gmail.com ' Started... 1-Jan-2014 ' Updated... 25-Feb-2014 ' ' ========================================================================= CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 Blue1 = 27 Green1 = 30 Red1 = 31 Vpos1 = 25 Blue2 = 24 Green2 = 28 Red2 = 29 Vpos2 = 26 Blue3 = 20 Green3 = 21 Red3 = 22 Vpos3 = 23 Blue4 = 16 Green4 = 17 Red4 = 18 Vpos4 = 19 Blue5 = 11 Green5 = 12 Red5 = 14 Vpos5 = 15 Blue6 = 8 Green6 = 9 Red6 = 13 Vpos6 = 10 Blue7 = 4 Green7 = 5 Red7 = 6 Vpos7 = 7 Blue8 = 0 Green8 = 1 Red8 = 2 Vpos8 = 3 Tx = 30 'serial Rx = 31 'serial 'Eeprom = 28 'eeprom. 'Eeprom1 = 29 'eeprom. VAR long cogon[8], cog[8], pile[1000] ' cog management long blinkwait, readwait, random1 word random OBJ Comm : "fullDuplexSerial" 'Communication to pc serial. RC : "RCTIME3" rr : "RealRandom" PUB Start 'Assuming that a 80 MHz core clock is being used, 800 cycles is about 10us. 'waitcnt(800 + cnt) 'Wait for 10us -100 khz 'waitcnt(8_000 + cnt) 'Wait for 100 us -10 khz 'waitcnt(80_000 + cnt) 'Wait for 1ms -1000 hz 'waitcnt(800_000 + cnt) 'Wait for 10 ms -100 hz 'waitcnt(8_000_000 + cnt) 'Wait for 100 ms -10hz human reaction speed 'waitcnt(80_000_000 + cnt) 'Wait for 1000 ms -1hz 'waitcnt(80_000_000 + cnt) 'Wait for 1000 ms -1hz stop ' stop all cogs if running rr.start blinkwait := 750_000 'Repeat 3 Red Green Blue GetRandom 'rr.stop RedData := 0 cogon[0] := (cog[0] := cognew(Main, @pile[0]) > 0) 'cogon[6] := (cog[6] := cognew(Diag, @pile[800]) > 0) Pub Main Repeat If RedData > 0 random1 := 256 * random waitcnt(random1 + cnt) blinkwait := random1 'Repeat 10 Red Green Blue Red RedData := 0 GetRandom Read Pub GetRandom waitcnt(20_000 + cnt) random := rr.random If random < 100 GetRandom If random > 30_000 GetRandom Pub Read outa[Vpos1] := 0 dira[Vpos1] := 0 'waitcnt(100_000 + cnt) dira[Vpos1] := 1 If RC.RCTIME(Red1, 10, 1, 30) > 0 RedData := 1 outa[Vpos2] := 0 dira[Vpos2] := 0 'waitcnt(100_000 + cnt) dira[Vpos2] := 1 If RC.RCTIME(Red2, 10, 1, 30) > 0 RedData := 1 outa[Vpos3] := 0 dira[Vpos3] := 0 'waitcnt(100_000 + cnt) dira[Vpos3] := 1 If RC.RCTIME(Red3, 10, 1, 30) > 0 RedData := 1 outa[Vpos4] := 0 dira[Vpos4] := 0 'waitcnt(100_000 + cnt) dira[Vpos4] := 1 If RC.RCTIME(Red4, 10, 1, 30) > 0 RedData := 1 outa[Vpos5] := 0 dira[Vpos5] := 0 'waitcnt(100_000 + cnt) dira[Vpos5] := 1 If RC.RCTIME(Red5, 10, 1, 30) > 0 RedData := 1 outa[Vpos6] := 0 dira[Vpos6] := 0 'waitcnt(100_000 + cnt) dira[Vpos6] := 1 If RC.RCTIME(Red6, 10, 1, 30) > 0 RedData := 1 outa[Vpos7] := 0 dira[Vpos7] := 0 'waitcnt(100_000 + cnt) dira[Vpos7] := 1 If RC.RCTIME(Red7, 10, 1, 30) > 0 RedData := 1 outa[Vpos8] := 0 dira[Vpos8] := 0 'waitcnt(100_000 + cnt) dira[Vpos8] := 1 If RC.RCTIME(Red8, 10, 1, 30) > 0 RedData := 1 Pub Red dira[0..31]~~ outa[0..31]~~ '----------------------------------------- waitcnt(blinkwait + cnt) outa[Red1] := 0 waitcnt(blinkwait + cnt) outa[Red1] := 1 waitcnt(blinkwait + cnt) outa[Red2] := 0 waitcnt(blinkwait + cnt) outa[Red2] := 1 waitcnt(blinkwait + cnt) outa[Red3] := 0 waitcnt(blinkwait + cnt) outa[Red3] := 1 waitcnt(blinkwait + cnt) outa[Red4] := 0 waitcnt(blinkwait + cnt) outa[Red4] := 1 waitcnt(blinkwait + cnt) outa[Red5] := 0 waitcnt(blinkwait + cnt) outa[Red5] := 1 waitcnt(blinkwait + cnt) outa[Red6] := 0 waitcnt(blinkwait + cnt) outa[Red6] := 1 waitcnt(blinkwait + cnt) outa[Red7] := 0 waitcnt(blinkwait + cnt) outa[Red7] := 1 waitcnt(blinkwait + cnt) outa[Red8] := 0 waitcnt(blinkwait + cnt) outa[Red8] := 1 dira[0..31]~ Pub Blue '----------------------------------------- dira[0..31]~~ outa[0..31]~~ waitcnt(blinkwait + cnt) outa[blue1] := 0 waitcnt(blinkwait + cnt) outa[Blue1] := 1 waitcnt(blinkwait + cnt) outa[Blue2] := 0 waitcnt(blinkwait + cnt) outa[Blue2] := 1 waitcnt(blinkwait + cnt) outa[Blue3] := 0 waitcnt(blinkwait + cnt) outa[Blue3] := 1 waitcnt(blinkwait + cnt) outa[Blue4] := 0 waitcnt(blinkwait + cnt) outa[Blue4] := 1 waitcnt(blinkwait + cnt) outa[Blue5] := 0 waitcnt(blinkwait + cnt) outa[Blue5] := 1 waitcnt(blinkwait + cnt) outa[Blue6] := 0 waitcnt(blinkwait + cnt) outa[Blue6] := 1 waitcnt(blinkwait + cnt) outa[Blue7] := 0 waitcnt(blinkwait + cnt) outa[Blue7] := 1 waitcnt(blinkwait + cnt) outa[Blue8] := 0 waitcnt(blinkwait + cnt) outa[Blue8] := 1 dira[0..31]~ Pub Green '----------------------------------------- dira[0..31]~~ outa[0..31]~~ waitcnt(blinkwait + cnt) outa[green1] := 0 waitcnt(blinkwait + cnt) outa[green1] := 1 waitcnt(blinkwait + cnt) outa[green2] := 0 waitcnt(blinkwait + cnt) outa[green2] := 1 waitcnt(blinkwait + cnt) outa[green3] := 0 waitcnt(blinkwait + cnt) outa[green3] := 1 waitcnt(blinkwait + cnt) outa[green4] := 0 waitcnt(blinkwait + cnt) outa[green4] := 1 waitcnt(blinkwait + cnt) outa[green5] := 0 waitcnt(blinkwait + cnt) outa[green5] := 1 waitcnt(blinkwait + cnt) outa[green6] := 0 waitcnt(blinkwait + cnt) outa[green6] := 1 waitcnt(blinkwait + cnt) outa[green7] := 0 waitcnt(blinkwait + cnt) outa[green7] := 1 waitcnt(blinkwait + cnt) outa[green8] := 0 waitcnt(blinkwait + cnt) outa[green8] := 1 dira[0..31]~ Pub White 'waitcnt(blinkwait + cnt) 'outa[Red1] := 0 'waitcnt(blinkwait + cnt) 'outa[Red1] := 1 '------------------------------ 'waitcnt(blinkwait + cnt) 'outa[Blue1] := 0 'waitcnt(blinkwait + cnt) 'outa[Blue1] := 1 '------------------------------ 'waitcnt(blinkwait + cnt) 'outa[Green1] := 0 'waitcnt(blinkwait + cnt) 'outa[Green1] := 1 '-2--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red2] := 0 waitcnt(blinkwait + cnt) outa[Red2] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue2] := 0 waitcnt(blinkwait + cnt) outa[Blue2] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green2] := 0 waitcnt(blinkwait + cnt) outa[Green2] := 1 '-3--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red3] := 0 waitcnt(blinkwait + cnt) outa[Red3] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue3] := 0 waitcnt(blinkwait + cnt) outa[Blue3] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green3] := 0 waitcnt(blinkwait + cnt) outa[Green3] := 1 '-4--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red4] := 0 waitcnt(blinkwait + cnt) outa[Red4] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue4] := 0 waitcnt(blinkwait + cnt) outa[Blue4] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green4] := 0 waitcnt(blinkwait + cnt) outa[Green4] := 1 '-5--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red5] := 0 waitcnt(blinkwait + cnt) outa[Red5] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue5] := 0 waitcnt(blinkwait + cnt) outa[Blue5] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green5] := 0 waitcnt(blinkwait + cnt) outa[Green5] := 1 '-6--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red6] := 0 waitcnt(blinkwait + cnt) outa[Red6] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue6] := 0 waitcnt(blinkwait + cnt) outa[Blue6] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green6] := 0 waitcnt(blinkwait + cnt) outa[Green6] := 1 '-7--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red7] := 0 waitcnt(blinkwait + cnt) outa[Red7] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue7] := 0 waitcnt(blinkwait + cnt) outa[Blue7] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green7] := 0 waitcnt(blinkwait + cnt) outa[Green7] := 1 '-8--------------------------------------------------------------------------------------- waitcnt(blinkwait + cnt) outa[Red8] := 0 waitcnt(blinkwait + cnt) outa[Red8] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Blue8] := 0 waitcnt(blinkwait + cnt) outa[Blue8] := 1 '------------------------------ waitcnt(blinkwait + cnt) outa[Green8] := 0 waitcnt(blinkwait + cnt) outa[Green8] := 1 PUB Diag comm.start(Rx, TX, 0, 250000) Repeat 'This is all for debug, enable if you want it. 'in_pasm(1 + cnt) 'Wait for 12.5 ns -80 Mhz 'in_pasm(8 + cnt) 'Wait for 100 ns -10 Mhz 'in_pasm(80 + cnt) 'Wait for 1us -1 Mhz 'waitcnt(800 + cnt) 'Wait for 10us -100 Khz 'waitcnt(8_000 + cnt) 'Wait for 100 us -10 Khz 'waitcnt(80_000 + cnt) 'Wait for 1ms -1 Khz 'waitcnt(200_000 + cnt) 'waitcnt(800_000 + cnt) 'Wait for 10 ms -100 Hz waitcnt(8_000_000 + cnt) 'Wait for 100 ms -10 Hz human reaction speed 'waitcnt(80_000_000 + cnt) 'Wait for 1000 ms -1 Hz comm.str(string(16)) 'clear screen Comm.str(string(1)) 'home 'comm.str(string(13)) 'cr Comm.str(string("Red:")) Comm.dec(RedData) comm.str(string(13)) 'cr Comm.str(string("Blue:")) Comm.dec(BlueData) comm.str(string(13)) 'cr Comm.str(string("Green:")) Comm.dec(GreenData) comm.str(string(13)) 'cr PUB stop '' Unload timer object - frees a cog if cogon[0]~ ' if object running, mark stopped cogstop(cog[0]) if cogon[1]~ ' if object running, mark stopped cogstop(cog[1]) if cogon[2]~ ' if object running, mark stopped cogstop(cog[2]) if cogon[3]~ ' if object running, mark stopped cogstop(cog[3]) if cogon[4]~ ' if object running, mark stopped cogstop(cog[4]) if cogon[5]~ ' if object running, mark stopped cogstop(cog[5]) if cogon[6]~ ' if object running, mark stopped cogstop(cog[6]) if cogon[7]~ ' if object running, mark stopped cogstop(cog[7]) DAT RedData long 0 GreenData long 0 BlueData long 0 {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}My boardhouse promised me the gerbers but hasn't produced yet. I have asked multiple times.
I haven't made a circuit diagram yet, but its pretty simple. each led has a 100 ohm resistor on each leg, and the common of the rgb leds is + that also has a resistor going to a leg on the prop. (Vpos1)
Nothing complicated about the design at all, actually. Its so simple its dumb, the key is to find your VF of each led and use a resistor that limits it right at its max current. (dont go bigger than 33ma for any single prop leg) (you will only pwm the thing anyway) The idea is to make the resistor as large as you can, and still be able to have the rctime object see light properly. So you don't really want 33ma going through a led, half or 1/4 that... But if the led can handle it, then burn baby burn. (the cree leds have 25ma max(blue/green), 50ma(red) *when only one is lit, at 1/10 duty, etc....(which is not much)
IT CAN be built on a breadboard.
IT CAN be VERY LARGE, with VERY LARGE BRIGHT LEDS (but the vf might be different, etc, so not sure on different PARTS)
(very large, meaning, bigger circle, but then the leds get spread apart, so the whole device becomes less active, due to less sense and emit density.
More material, pics, schematics, archive, gerber, etc... will come in time, I really just got started on these... fresh outta the oven. I still have MimsMirror:One to get going also...
I working on it!
