RFID tag reader coil size, how small can it be?
Hey Everyone,
I was wondering if anyone has had any experience with making their own RFID tag readers? I was wondering it was possible to make a reader that is smaller than the standard credit card size?
Thanks for your time,
Dave
Dave
Here is a link to a RFID project I did awhile back. The design uses a similar "Double D" approach to metal detecting, but the concept for creating your own "single" coil will be the same.
http://wiki.ohmspace.org/User:Bschwabe#OHM_Space_.28EM4100.29_RFID_reader
Thanks again for your help!
link:
http://forums.parallax.com/showthread.php/105889-World-s-simplest-RFID-reader
Etching coils on a PCB is possible, but you almost always need to do empirical testing first and take measurements. i.e. Design some test coils that are binary weighted in their values (number of turns) and note the differences in inductance between each coil. Then based on your results, and using the SAME manufacturing process, create a proper value coil, and then test again... :-)
I do have some code I will try to dig up and post later.
field strengths unless you reduce the current levels too. Of course you can vary the capacitance value too
to allow for different inductance, but the Q of the resonant circuit depends on losses in the various components,
so there are several variables that all go together and can't be considered in isolation. The current level in
the LC circuit depends on the Q as well as the driver current, for instance.
Mark_T is correct a larger coil and/or a larger capacitor tends to decrease the Q (Quality factor) ... in some cases where a tag might not be exactly 125kHz (due to damage) or the detector circuit might not be properly tuned, a lower Q could be beneficial because of an increased bandwidth... The caveat is a lower signal strength, so the benefit may be a moot point.
Attached is the program I used for the RFID reader you see in the video.
Thanks!
Dave
Link:
http://www.wikihow.com/Measure-Inductance
http://wiki.ohmspace.org/Determining_an_unknown_inductor_value_using_a_%27known%27_inductor_as_a_reference_value
