Muscle from fishing line
See this? It was on Hack A Day, now it in the newspaper.
http://www.palmbeachpost.com/news/news/national/researchers-make-artificial-muscle-fishing-line/
Ferb, I know what we're going to do today!
http://hackaday.com/2014/02/21/
So, would we heat the fish line with parallel nichrome wire or what? I think I have a Stickito kit that wants to play....
Paint the wire black and shoot a laser at it?
Find a pigment that heats up when exposed to uv or ir...
I can't read the original article.
The hackaday reference states the work done is 5.3kW/kg. However, this makes no sense as kW is a unit of power.
I suspect it should be 5.3kWhr/kg.
The comparison to muscle is a bit problematic though. Muscle is powered chemically and moves electrolytically. This process is quite efficient.
The Fishing Line muscle is powered thermally and I suppose moves by thermal expansion. I doubt it is very efficient.
It is essentially a Brayton Engine.
The problem: since the Nylon itself has thermal mass heating this mass is wasted energy. Only the energy causing expansion is useful.
A very good example of a BAD DESIGN is the Wally Minto's Wonder Wheel. This link goes to my friend Steve Baer's patent for a similar device with much better efficiency. I put Minto's wheel in with Steve's patent as Minto didn't patent the wheel.
I don't want to be a wet blanket on interesting ideas but some may just be impractical, like the Minto wheel.
Duane J
I guess they were trying to compare the power to weight ratio and just worded it wrong.
http://www.sciencemag.org/content/343/6173/868
If you somehow embedded a small wire into the fishing line to apply current to heat the wire, you could induce contraction electrically.
Or not.
Hi Doc! We've missed you.
"Or not."
I tried the Nitinol thing long ago ... that ate lots of batteries
Bicycle brake wire is good for servos. I wonder if loose tube fiber optic cable could be used instead.
I would also imagine cooling attempts to relax the 'muscle' would be analogous to lactic acid buildup.
I think the video mentioned poly propylene? But I'd need to watch it again. What is the loose tube fiber optic cable made of. I just assumed it was glass.
@Beau - I had the same thought about heat build up. Your lactic acid analogy is spot on.
I saw a follow up vid where they used red and blue dyed water to heat and coole the filament to produce contraction/relaxation. So moisture doesn't affect it to the extent of hampering the function.
It occurs to me that the first tube volume of liquid would be the same actuation temperature, and might be recycled.
Also 1 or 2 volumes of liquid would be needed to reach the opposing target temperature. Perhaps careful control of these could minimize heating and cooling of the medium. I bet one could monitor and control that with a microcontroller fairly easily.
Based on that led me to the question .... "Wonder if humidity would contribute a significant amount to the level of contraction" ... if not for repeatability in "muscle" control
