Increasing # of NTSC greyscale levels by paralleling two video generators
Tubular
At the moment we have 6 usable NTSC grey levels, generated by one cog with 3 resistors forming a DAC
If I generate synced video in a second cog, with an additional 3 resistors representing new LSB's (2k2, 4k4, 8k8, roughly), could I expect to get 8x the number of levels (=48)?
Any video experts know if this might work? How could I sync the two video generators?
Regarding the color, shouldn't it still be possible to have the same range of NTSC colors from the "master" cog, provided the "slave cog" is outputting % 000 at the same instant and not interfering?
edit: that is, for one portion of the screen displaying 48 level greyscale, and another separate region displaying ntsc color text or button graphics, for instance.
I was thinking of putting the LSBs on P16~18 so a "circuit" can be plugged into an existing demo board's connectors, but the chroma would appear on P19 via the 240 ohm blue vga resistor. Having a modified driver for the slave(s) is no big deal, I guess.
Thinking about it some more, if tv monitors really do saturate at 1.0 volt it would be more like 41 grey levels (+some colors) with 1 slave, or something like 286 levels (+some colors) with 2 slaves, which would be nice. Might need to tweak resistor values, or go with a R2R ladder
1. Sync two video generators, as you are considering. However, I think you may still run into some sub-pixel bleed because the two PLLs won't be 100% balanced.
2. Run PLLA at 14.3181818 MHz and generate the Y + U / Y + V signals directly. I did this for my mega-sprite driver.
3. Do something with outboard electronics.
I'll look at the VGA greyscale DAC option too. I think it'd be good for up to 169 usable levels? (92.5 IRE /140 * 256), which would be plenty
It'll be interesting to see how much bleed occurs, whether it's noticeable.
