Difference between simpletools.h SD card access and propgcc stdio.h implementation
I have an issue using the stdio.h implementation of propgcc for accessing a sd card.
I made a custom pcb board for my pinball project containing two propeller controller which communicate with each other and each controller has its own sd card, eeprom, flash and sram (flash currently not mounted).
Both controller have their own programming pin headers which can be connected to a prop plug.
All works well, programming hub ram directly, programming eeprom and executing XMMC mode from eeprom on both controllers.
But I have a problem accessing the SD card when using stdio.h. When using simpletools.h it works.
I use SimpleIDE version 0.9.45 (propgcc version propellergcc_v1_0_0_2162 which was in the SimpleIDE installer package).
When using simpletools.h, I can read/write to SD card in all modes (CMM, LMM, XMMC [eeprom]) but when I use stdio.h, access fails. When using stdio.h, I get the error message "File did not open."
The test code I'm using is as follows:
simpletools.h version
stdio.h version
Is there a known issue with regards to stdio.h and SD card or is there something I'm doing wrong?
I know when using stdio.h, I have to configure the SD pins in the board.cfg file which is selected in SimpleIDE. I made sure that the correct pins are configured.
The config looks as follows:
I really appreciate any input on what can cause the problem.
Christian
/* SD Minimal.side Create test.txt, write characters in, read back out, display. http://learn.parallax.com/propeller-c-simple-devices/sd-card-data */ #include "simpletools.h" // Include simpletools header int DO = 10, CLK = 9, DI = 8, CS = 7; // SD card pins uint8_t videoBuffer[1024]; int main(void) // main function { int a; for (a = 0; a < 1024; a++) { videoBuffer[a] = 65; } waitcnt(80000000 + CNT); print("Starting..."); int erc = sd_mount(DO, CLK, DI, CS); // Mount SD card if (!erc) { FILE* fp = fopen("test.txt", "w"); if(fp) { // Good, continue fwrite(videoBuffer, 1, 1024, fp); // Add contents to the file print("Buffer written..."); } else { // Bad, error message. printf("File did not open.\n"); } fclose(fp); // Clearing videoBuffer for (a = 0; a < 1024; a++) { videoBuffer[a] = 0; } fp = fopen("test.txt", "r"); if(fp) // Nonzero file pinter? { // Good, continue. print("Start reading buffer..."); int startCnt = CNT; fread(videoBuffer, 1, 512, fp); int endCnt = CNT; print("Read took ticks: %d", endCnt - startCnt); print("\n"); // With a newline at the end. } else // Zero file pointer? { // Bad, print error. printf("File did not open.\n"); printf("\n"); } fclose(fp); } else { print("Error mounting file system."); } }
stdio.h version
/* SD with Tests.side SD Minimal modified so that it tests for drive and file before performing any read/write operations. http://learn.parallax.com/propeller-c-simple-devices/sd-card-data */ #include <stdio.h> // Include simpletools header #include <stdint.h> #include <propeller.h> int a; int DO = 10, CLK = 9, DI = 8, CS = 7; // SD card pins uint8_t videoBuffer[1024]; int main(void) // main function { waitcnt(40000000 + CNT); //int erc = sd_mount(DO, CLK, DI, CS); // Mount SD card int erc = 0; if(!erc) // Error code = 0, good, continue { FILE* fp = fopen("test.txt", "w"); // Open a file for writing if(fp) // Nonzero file pointer? { // Good, continue fwrite(videoBuffer, 1, 1024, fp); // Add contents to the file } else // Zero file pinter? { // Bad, error message. printf("File did not open.\n"); } fclose(fp); // Close the file fp = fopen("test.txt", "r"); // Reopen file for reading. uint8_t videoBuffer2[1024]; // Buffer for characters. if(fp) // Nonzero file pinter? { // Good, continue. int startCnt = CNT; fread(videoBuffer2, 1, 1024, fp); int endCnt = CNT; printf("Read took ticks: %d", endCnt - startCnt); printf("\n"); // With a newline at the end. } else // Zero file pointer? { // Bad, print error. printf("File did not open.\n"); printf("\n"); } fclose(fp); // Close the file. } else // Mount error code not zero? { // Bad, display code printf("Error opening card."); printf("error code = %d\n", erc); } }
# pinballMCU.cfg clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: eeprom_cache.dat cache-size: 8K cache-param1: 0 cache-param2: 0 eeprom-first: TRUE sd-driver: sd_driver.dat sdspi-do: 10 sdspi-clk: 9 sdspi-di: 8 sdspi-cs: 7
Christian
I forgot using the following when using stdio.h:
When defining the drivers, the stdio.h version works in CMM mode. For LMM, the program gets too big and overflows hub by around 8k.
I can remember I used stdio.h sd card access many month ago in LMM mode and code didn't overflow hub.
Was there something changed that even such a "short" program will not fit into hub ram?
Christian
As far as I know SD access is handled by an external driver which runs in a cog regardless of the selected memory model. So I hooked up a logic analyzer and saw, that in both memory models the CLK frequency to the SD card is 4 Mhz. So same speed if selecting CMM or LMM.
Next I tried to get the stdio.h version below 32Kb by using the putStr and putDec functions instead of printf and that worked. The stdio.h version works in both modes CMM and LMM reliably.
I'd prefer the simpletools.h version because code size is much smaller even when using SD access.
Is there any known bug in the simpletools library? Because SD access speed is always the same by the "SD" cog, I think there might be a problem when handing over data from the program to the
"SD" cog.
Any ideas/help is appreciated. :-)
Christian
post if it works. I don't have luck using LMM mode, only CMM works.
Ray
These lines are equivalent.
putStr("hello\n");
putLine("hello");
The signals to the PMC SD card connector have the same CLK frequency, so I don't think it's a communication timing issue.
Were there any changes recently in the simpletools library regarding SD access I might not have? (Because it works well with propgcc stdio impl.)
Try it on a different board if possible just as a test ... preferably not a Quickstart ........
Any ideas what I can check? I have a scope and logic analyzer.
Quickstart is a noisy board ... the board that keeps on giving
One thing to try is to choose GENERIC as the board type instead of PMC. I ran into some interference with the "automatic" aspect of the underlying implementation. The other alternative is just to leave out sd_mount() all-together.
BTW, If you put your probe on a pin and suddenly everything starts working that is an indication of a hardware problem.
Thanks for your input! :-)
I´ll try out the GENERIC board type.
It doesn't make a difference if I attach a probe or not. It does not work in LMM. I will also try to leave out the sd_mount line... Do I have to include the drivers the same way as I would use stdio when I leave out the sd_mount line?
So it's interesting, that using another mount routine solves the issue. Does the propgcc implementation initialize the sd card in another way than the simpletools mount routine?
You don't need sd_mount(). It's just syntax sugar. The only time I've ever had a problems with sd_mount() is if I use a board-type that already has some SD card configuration that is in conflict with the parameters I pass to sd_mount().
If you have the right board-type, and add the driver struct like below, you get what you need (you don't really even need the mount() function in that code ... it's just a way for me to test with GENERIC).
The only issue with the driver struct is the serial driver needs to be replaced with _NullDriver so that only the simpletools stuff gets used without interference from the stdio serial driver.
I'd like to see the root cause of your problem, but I can't really duplicate it. Try this code for mounting with GENERIC board type and let me know if it works. Remove the mount() call if you use the PMC board type.
If I select GENERIC board type, I have to use the mount() call. If I use the board type I made for my own board (same as quickstart, but SD pins adapted), it also works and I can remove the mount() call.
So I have no issue. Why do I have a problem when I directly use the simpletools version without the mount() code in the main program? Does this make sense?
