Circuit board vise
MJHanagan
I'm thinking about buying a circuit board vise (my little bench-top vise doesn't cut it anymore). All my boards to date have been under 5" max length.
Any suggestions for the home hobbyist?
http://www.panavise.com/index.html?pageID=1&id1=1&startat=1&--woSECTIONSdatarq=1&--SECTIONSword=ww
RS just clearanced the Panavise setup you need...I would try checking at your local RS stores for one (it is not on the website any longer).
Clearance cost $20 or less...regular price close to $100.
Thank you, I'll check it out.
I found the link. IMO, it makes working on a board a lot easier. I like being able to flip the board while it's still secured in the holder.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_null_684844_-1
I like that! Thanks for posting.
I have the PCB Panavise head and it works best for larger boards.
if you don't do a lot of board soldering, just having something that holds the board tightly will suffice.
PanVise has always been a favorite of hobbyist.
But when I got to Taiwan, and looked around for a vise of sorts, I ended up buying a machinist vise that is just plain heavy and intended to be bolted to the table of a drill press or a milling machine. It is so heavy, I don't need to clamp it to my work bench.
Something as simple as what is in the attached photo is very handy.. works for me.
Another circuit board holder I like is the Visegrip sheet metal tool. Easy to flip, and it can be held in the drill press vise for added heft.
I guess you now know why I think Radio Shack a little silly. I was spoiled early on in geekhood.
Real electronics shops don't have everything in bubble packs, they know what's in stock, and customers are all smiles..
A nod to topic, they keep a collection of Panavise products clamped to a table up front. When choosing a vise (or vice?), it is helpful to see the selection and get a feel for how they work.
[video=youtube_share;FxwYCq1QPkA]
I haven't used anything else for small boards since.
