Andy Please Help! Compiler/Syntax question
I got this e-mail from a dad of one of my students. He might as well be speaking Greek. What is the answer?
Does the compiler have a way to show what the syntax options are for the compiler?
Please salvage my pride so I don't have to admit I have no idea what he's talking about.
Diane
Diane
I think what he wants is live syntax checking, which SimpleIDE does not have. You have to run the program to check the syntax.
Diane
For reference, everyone has their favorites. My two favorite C language references are at IBM's site:
Language
http://pic.dhe.ibm.com/infocenter/iseries/v7r1m0/index.jsp?topic=%2Frzarg%2Fsc09785202.htm
Standard Libraries
http://pic.dhe.ibm.com/infocenter/iseries/v7r1m0/index.jsp?topic=%2Frtref%2Fsc41560702.htm
There's also info on the Simple Libraries that gets installed with SimpleIDE. Just click Help and Select Simple Library Reference. If nothing happens due to web browser incompatibility, you can use a file browser to open Libraries Index.html from the ...Documents\SimpleIDE\Learn folder.
Andy
P.S. For embedded developers:
Propeller library info is here:
https://sites.google.com/site/propellergcc/documentation/libraries
Pay special attention to propeller.h
https://sites.google.com/site/propellergcc/documentation/libraries/propeller-h-library
For newcomers reading this thread: to check for syntax and other compile errors, you don't have to run as in "download to a Propeller chip," but simply run as in "build."
Just click the Build Project button -- it is the little hammer icon on the top tool bar. You don't have to have a Propeller chip connected.
I think maybe what he meant was: what are the command line options that you can put into "Other Compiler Options", and perhaps "Other Linker Options"
There are hundreds of possible command line options to gcc and ld. Most of them you will never need if you're building programs from SimpleIDE. The official documentation is at:
http://gcc.gnu.org/onlinedocs/gcc-3.0/gcc_3.html (compiler)
and:
http://ftp.gnu.org/pub/old-gnu/Manuals/ld-2.9.1/html_node/ld_3.html (linker)
But there are probably other pages on the web that are easier to read and may have better information. Google for "gcc command line options" and/or "ld command line options".
===Jac
