Sensor for detecting a person
                    Hi,
I want to detect a person(not in motion) who is standing in front of a door(lets say) using sensor. It will be very helpful for me if anyone suggest me which sensor can do this. I came across PIR sensors, but they detect when the person is in motion. Quick response is appreciated.
Thank you
Hema
Thank you
Hema
http://www.irisys.co.uk/people-counting
IRISYS designed their own sensor array. AFAIK, they don't just sell the sensor, it is only available as part of of a system. It has to be used with a suitable germanium lens.
I'm ordering a couple for my home automation system so the lights don't out if I'm not flailing about
Dave
If you just want to detect a person in a doorwall, could you use a simple ultrasonic sensor? Seems a ping or sr04 would be cheapest and simplest
Next, I posted a link above, http://www.digikey.com/product-highlights/us/en/omron-d6t-thermal-sensor/2745 - that is a second generation PIR sensor that detects people that are both in motion AND stationary. These are fantastic devices. While they do not distinguish between a human and a dog, for example, by themselves, a very little bit of creative programming can make them do so.
I became interested in these devices because I have had the experience of being in a room where they used Gen 1 PIR sensors... and after a minute or two of my sitting with relatively little motion, it suddenly switched off the lights!
These sensors do not do that. They remain aware of warm sources in their field of view, and you can do a lot with that data. Available in a 4 x 4 matrix, or a 1 x 16 linear configuration, you can figure just about any field of vision you need.
Check out the link at http://www.digikey.com/product-highlights/us/en/omron-d6t-thermal-sensor/2745 and see if you might find these useful. At $50 a pop, they are NOT cheap, but they are effective and the time saved in figuring out some sort of other scheme vs. just using these fantastic little devices, may be worth the investment.
Anyway - are you even still reading?
Dave
I just flashed on using a singing telsa coil as the detector. Do you require that the person detected survive detection? Just checking.
Did you play Red Alert? :P
