Driving Noritake VFD displays from the Stamp: Code for ya
I've been playing with a new toy: the Noritake Vacuum Fluorescent Display. Nice display, good high-contrast, high-brightness display with a lot of options and a wide temperature range.
For anyone interested in driving it right out of the box (be sure you get the serial version and be sure you solder the jumper to set the baud to 9600!), here's a pack of code that covers setting display brightness, individual character brightness, cursor position, text magnification, character blinking, and a whole boatload of other stuff that can make a fun display.
Also I have attached the datasheet here. This is specifically for the Noritake CU24063-Y1A display. Be sure to order from Noritake, apparently there's a markup through the distributors.
Also note that this code was written for the BS2px, so be sure to change that line if you're using some other BS2 version. I think this display will work on any BS2. I've seen some posts that question the earlier BS2 chips ability to do 9600, but they've always worked for me. YMMV.
Have fun!
Dave
Have fun!
Dave
' File....... VFD_Demo_Only.bs2
' Purpose.... Basic functions for the Noritake VFD Serial 24 x 6 display, Noritake CU24063-Y1A
' E-mail..... xanatos@xanatos.com
' Updated.... 13 February 2014
' {$STAMP BS2px}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' Basic functions for the Noritake VFD Serial 24 x 6 display. Read the comments to see what each part controls
' -----[ Revision History ]------------------------------------------------
' 1.0: Initial release
' -----[ I/O Definitions ]-------------------------------------------------
LCD PIN 0 ' Serial LCD Display (NHD 4x20)
' -----[ Variables ]-------------------------------------------------------
secs VAR Byte ' Phony seconds counter
sBrite VAR Nib ' Screen Brightness Var
cBrite VAR Nib ' Character Brightness Var
' -----[ Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
T38K4 CON 84
#ENDSELECT
LcdBaud CON T9600
' -----[ Initialization ]--------------------------------------------------
Init:
PAUSE 50
SEROUT LCD, LcdBaud, [$1B, $58, $FF] ' Clear & reload jumper settings, interface, etc. Clear rx buffer.
SEROUT LCD, LcdBaud, [$14] ' Cursor Off ($13 is underline)
SEROUT LCD, LcdBaud, [$1B, $41] ' No Blinky
SEROUT LCD, LcdBaud, [$1B, $53] ' Flickerless Write mode ($1b, $45 is quick write mode)
SEROUT LCD, LcdBaud, [$1F, $01] ' Display set to Overwrite Mode.
Display_Welcome:
SEROUT LCD, LcdBaud, [$0C] ' Clear screen
FOR sBrite = $01 TO $04
SEROUT LCD, LcdBaud, [$1F, $58, sBrite] 'screen brightness incremented here. 01 = 25%, 2 = 50, 3 = 75, 4 = 100
GOSUB GreetScreen
PAUSE 500
NEXT
PAUSE 5000
' -----[ Program Code ]----------------------------------------------------
Main:
SEROUT LCD, LcdBaud, [$1F, $28, $67, $40, $02, $02] '2x magnify
SEROUT LCD, LcdBaud, [$0C, $0B, "System Ready"]
SEROUT LCD, LcdBaud, [$1F, $28, $67, $40, $01, $01] '1x magnify
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $02, $00, "2014/02/14 12:22:48"] ' Just some fake stuff to display that can be manipulated later
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $03, $00, "61", $F8, "F 34% RH 29.24", $22, " ", $5E] ' notice $F8 is the degree sign. $22 is " and $5E is the ^ for Rising baro.
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $04, $00, "118.4v 5.12v"]
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $05, $00, "System Status: "]
SEROUT LCD, LcdBaud, [$1B, $42] ' Blinky ($41 for no blinky)
SEROUT LCD, LcdBaud, ["Normal"]
SEROUT LCD, LcdBaud, [$1B, $41] ' No Blinky ($42 for blinky)
FOR secs = 0 TO 59 'This section just shows how to reposition cursor to a point on teh display and overwrite text.
SEROUT LCD, LcdBaud, [$1F, $24, $16, $00, $02, $00] '[$1F, $24, $charpos, $00, $linepos, $00] char = 00 to 23; line = 0 to 5
SEROUT LCD, LcdBaud, [DEC2 secs]
PAUSE 980
NEXT
PAUSE 10000
GOTO Display_Welcome
' -----[ Subroutines ]-----------------------------------------------------
GreetScreen:
SEROUT LCD, LcdBaud, [$0B, " XANATRONICS ", $0D]
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $01, $00] ' Set character position - 3rd byte is char (0-23, or 0-17h) 5th byte is line (0-5)
FOR cBrite = $08 TO $03
SEROUT LCD, LcdBaud, [$1F, $28, $67, $50, cBrite, $00, $00, "="] ' Set character brightness decrementing
NEXT
SEROUT LCD, LcdBaud, [$1F, $28, $67, $50, cBrite, $00, $00, "============"]
FOR cBrite = $03 TO $08
SEROUT LCD, LcdBaud, [$1F, $28, $67, $50, cBrite, $00, $00, "="] ' Set character brightness incrementing
NEXT
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $02, $00, " Voice Controlled and"]
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $03, $00, " Speech Responsive"]
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $04, $00, " Home Automation System"]
SEROUT LCD, LcdBaud, [$1F, $24, $00, $00, $05, $00, " V 2.0, February 2014"]
RETURN
' -----[ End of File ]----------------------------------------------------
Wayne
Just remember to solder J1 (top center of display board - SEE DATASHEET!) to make it 9600 baud. Load the code and run it. You'll see the boot screen for my home automation screen... But look through the code line by line and you'll see I've commented everything. The datasheet has a chart of how the codes control the display, and once you line up a few of mine to that chart, you'll get the picture pretty quick.
Really liking the display.
Also got an offer from Noritake today for a free 16 x 144 serial dot matrix display! So I've put my dibs in for one, and when I get it, I'll follow up on here with a similar BS2 coding example.
Have fun!
Dave
Wayne
But currently they are very expensive. For lower price, I can get 3.5' LCD from ebay+Maxim OSD chip and have much more featured display than this one.
Hi Curious,
You may have been seeing prices through distributors? Not sure - I paid $34.00 for the 24 x 6, which I really don't think is all that bad. But you have to order from Noritake-vfd.com direct - apparently there is about a 40% markup to distributors, according to the local Noritake rep.
For comparison, the 4 x 20 LCDs I use frequently I get from Newhaven Display, and they're around $25.00.
What OSD chip are you using - I'm actually interested in doing some graphic LCD work, looking for a good entry point...
Dave
If you pay less than this, such as off eBay (China), you will get garbage - slow updates, ghosting, poor contrast, etc.
Newhaven, Optrex, Microtips, Noritake, and other reputable brands make good displays.
Thanks for the code, I think I'll buy one of those VFDs, I've always like the way they look.
$34 for VFD display?
OMG
$25 for 20x4 LCD?
OMG X 2.
I' buy from ebay chinese 20x4 LCD's for around $7, and they have everything OK, including contrast, refresh rate and so on. If interested, can share a link.
Regarding the OSD, I'm using MAX7456 chip: http://www.maximintegrated.com/landing/index.mvp?lpk=198&CMP=4265
The basic stamp code is available here, and if you need, I've designed a breakout board for that chip, so it fits into standard DIP24 socket.
This chip, bundled with something like this: http://www.ebay.com/itm/3-5-Digital-TFT-LCD-Screen-Rear-View-Monitor-For-Car-Reverse-Camera-DVD-VCD-/161052693327?pt=US_Rear_View_Monitors_Cams_Kits&hash=item257f7d134f
provides much more flexibility than any graphic or character LCD for basic stamp; It has all user definable charset stored in eeprom. The display is "gapless", so you can draw graphical elements and you have choice of 3 colors, white, black and "transparent".
Are those SERIAL displays?
For $7 I'll order one and test it out, but your statement about different worlds may hold true for a very serious reason on my part - a lot of my products are used in the petroleum distribution industry, and I can't afford to have 30 displays in the field, and six months later, have those displays start croaking on me. So my thinking goes: Save $27, wait six months, spend $140.00 to service a bad display.
So yes, do field the link, and I will check. I'll probably hook the display up and have it hanging out of my window for a few months, and if it's still working, I may consider looking more closely at it
Dave
There is all the buzz about the Stamps not working well at 9600 and above, but that mostly relates to receiving data, not to sending. The Stamp would have trouble only with the Status Information Read command. Even at high baud rates, the Stamp can work fine if the pacing of incoming data is permissive.
Those VFD displays look good, and thanks for the demo code. I've been using the Newhaven I2C serial chip-on-glass LCD displays. Their big advantage for battery powered systems is 1mA current drain, 45mA with backlight on.
I too value reliability of the supply chain and support over cost. Time to develop the short-run systems for customers adds up much faster that the cost of the modules.
Actually I didn't try at the default rate - never even occurred to me to try it! I will with the next one, although 9600 is usually fine for what I am displaying... but if I don't have to solder a jumper, that saves me a step. Why do something unnecessary?
I'll have a look at those I2C CoG displays, though I do very little battery powered stuff at the moment. I do know the 4x20 with backlight on uses somewhere around 200mA if I recall correctly!
And yes - compared to the final system cost... $34 vs $7 is not even entering the picture! If I was mass producing thousands, though (wishing), then the difference could add up to someone's yearly salary. Let's hope I can get to that point! LOL
Dave
http://www.ebay.com/itm/LCD-2004-20x4-black-on-yellpw-backlight-/261121602730?pt=LH_DefaultDomain_0&hash=item3ccc0f74aa
Sure, I haven't did a mil-spec tests on them, but one of them installed in my wifes car for about 6 months and going just fine.
That links to a Parallel display, not a serial display. My application for this display doesn't have room for a fat ribbon, or a pair of 595s to do the P>S work... did you have a serial display from this guy as well?
