Does PropellerTool keep a history for file changes?
Hi everyone,
I discovered a strange behavior this morning:
I copied my library folder (../Parallax Inc/Propeller Tool v1.3/Library) to another location in order to copy it to my laptop.
I noticed that changes I made to files in the library were gone.
I did a little testing and recognized, that the file date does not change if I make a change and then save the file. If I double click that file in the library folder, the changes are there -> OK
If I copy this file to any location different from the library folder and then double click on it, the changes are gone.
And also, if I open the file from the library folder (remember, that is the file where I made the changes and that are still there if I double click on it), the changes are already gone. I disabled "Enable auto recover" and "Retain undo history" but that doesn't change anything.
So I assume that Propeller Tool does save a history of changes somewhere and inserts them when a file is opened.
Has anyone discovered something like that before? BTW: Win 8 (not 8.1), Prop Tool 1.3.
Akk4rin
Akk4rin
Solution is to install PropTool and Libraries somewhere else, not in Program Files.
Enjoy!
If this library is a sub folder of your "My Documents", then that is actually in C:\Users\(your user name)\Documents. I have never understood why they felt the need to obfuscate file locations this way. Nevertheless, any files you save in either location should be correct and not be changed by anything other than you saving new data.
This is how it works in Windows 7 anyway, I have no idea what kind of craziness might be going on in Windows 8. Might be similar or could be something different.
thank you guys. I'll have a look at this.
Windows just gets more and more brain damaged.
I found the folder:
C:\Users\MYUSERNAME\AppData\Local\VirtualStore\Program Files (x86)\Parallax Inc\Propeller Tool v1.3\Library
crazy!!
In both cases I bought the new computer to run one specific program, which would not run with UAC enabled, so the other stuff being disabled represents little lost value.
What file system does your removable device use?
Personally, I would always have at least one device in a system that uses fat 32, this is one way to strip all the so-called security overhead imposed by NTFS (which for most users is just a pita). If you have ever moved an NTFS formatted drive from one computer to another and found you can no longer modify any of the files on it, then you know of what I'm speaking. takeown anyone?
Rick,
I use fat 64 exclusively on my working computer. So far I have not yet encountered a situation where fat 32 was required.
I foresee never taking any thumb drives farther than my little storage rack on a shelf above the computer.
