Can I name my XBee devices?
I have two XBee modules and an X-Stick so it would be nice to see them as "XBee 1", XBee 2" and "X-Stick" instead of their MAC address "0013A20040ABC4A4", etc. In the XCTU software I see a field labeled "Name:" but it is empty and I don't see anything in the configuration section. Can this be written to, if so how?
As you can see from my screenshot you want to set the "Node Identifier" field. This will then populate the name field for the module. I hope this helps.
