Read long arrays spin to assembly — Parallax Forums
PrincPrinc Posts: 12
edited 2014-02-10 07:51 in Propeller 1
Hi,
i have got a problem with reading from spin
I have got defined array in spin like this
long pixel[16200]
and i would like to read long in assembly one by one
old one should be replaced with new long but i don´t now how to do it without shifting in spin
thanks for help
  • JonnyMacJonnyMac Posts: 9,835
    It's really not difficult. You need to pass the address of the array to the PASM code (using the par register). You can use rdlong to get a long from the hub, wrlong to write on back.
    BTW... there's only 32K (8K longs) of RAM in the hub, so you can't have an array that large.
